Giorgos02 Posted April 6, 2015 Share Posted April 6, 2015 After installing firmware 2.61 and loading the full amp packet I noticed that when I am tweaking the amp/cab DEP knobs I can't see their percentages on my POD HD500X Edit software. Also some patches have no sound. When I load them, I get no sound. And the last bug I noticed is that sometimes when I am doing a dual amp setup and save it, every time I try to load it, the second amp has all its knobs on the amp section at 0% for no reason. 3 Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 6, 2015 Share Posted April 6, 2015 Did you also install the updated version of HD500 Edit? Quote Link to comment Share on other sites More sharing options...
janjanives Posted April 6, 2015 Share Posted April 6, 2015 Which patches have no sounds? Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 6, 2015 Author Share Posted April 6, 2015 Did you also install the updated version of HD500 Edit? what do you mean? Which patches have no sounds? just some random patches have no sound and some other have sound like they used to. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 6, 2015 Share Posted April 6, 2015 If you have already installed Line 6 Monkey, run it with your Pod connected via usb. If you don't already have it, go to the Downloads section of this website (under the Support tab above) and download Line 6 Monkey. Then run it. It will help you obtain and install the updated HD500 Edit program. Some of the factory presets are designed for vocals, or for JTV guitars. In these cases the Input will not be set for the guitar input; hence you will not hear any sound from your guitar. Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 6, 2015 Author Share Posted April 6, 2015 If you have already installed Line 6 Monkey, run it with your Pod connected via usb. If you don't already have it, go to the Downloads section of this website (under the Support tab above) and download Line 6 Monkey. Then run it. It will help you obtain and install the updated HD500 Edit program. Some of the factory presets are designed for vocals, or for JTV guitars. In these cases the Input will not be set for the guitar input; hence you will not hear any sound from your guitar. Why should I download and install HD500 Edit? I have a pod HD500X and I have updated everything about it. Quote Link to comment Share on other sites More sharing options...
powerwindows Posted April 6, 2015 Share Posted April 6, 2015 I had this very problem with sound and new patches. I am no expert but noticed that these patches had a volume pedal on the patch. I deleted the pedal and 'Bingo'. There was sound B) Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 6, 2015 Author Share Posted April 6, 2015 I had this very problem with sound and new patches. I am no expert but noticed that these patches had a volume pedal on the patch. I deleted the pedal and 'Bingo'. There was sound B) I have never placed any volume pedal to any of my patches. Quote Link to comment Share on other sites More sharing options...
powerwindows Posted April 6, 2015 Share Posted April 6, 2015 Sorry I thought you had down loaded the troublesome patch Quote Link to comment Share on other sites More sharing options...
brue58ski Posted April 6, 2015 Share Posted April 6, 2015 So it sounds like you do your editing from the HD500X itself and not from a computer you have your HD attached to. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 6, 2015 Share Posted April 6, 2015 Why should I download and install HD500 Edit? I have a pod HD500X and I have updated everything about it. Then download 500x Edit. Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 6, 2015 Author Share Posted April 6, 2015 Then download 500x Edit. But I have downloaded the latest 500X Edit. Am I the only one that has these bugs? Quote Link to comment Share on other sites More sharing options...
duncann Posted April 6, 2015 Share Posted April 6, 2015 After installing firmware 2.61 and loading the full amp packet I noticed that when I am tweaking the amp/cab DEP knobs I can't see their percentages on my POD HD500X Edit software. Also some patches have no sound. When I load them, I get no sound. And the last bug I noticed is that sometimes when I am doing a dual amp setup and save it, every time I try to load it, the second amp has all its knobs on the amp section at 0% for no reason. The no percentage thing, yes, I get this too. And I have to say, this really needs to be fixed. It used to be that a percentage toottip popped up when adjusting it. Now it doesn't. :angry: The no sound on patches might be something with the input setups global setting? Or a volume pedal somewhere in the chain where if the pedal is in the heel position there will be no sound? I use a lot of dual amp patches and haven't noticed anything like this yet. Quote Link to comment Share on other sites More sharing options...
ryechua Posted April 7, 2015 Share Posted April 7, 2015 After installing firmware 2.61 and loading the full amp packet I noticed that when I am tweaking the amp/cab DEP knobs I can't see their percentages on my POD HD500X Edit software. yup. the parameters in the cab doesn't show the values in the edit software when you turn the knobs. i had to look at the pod unit's screen to see what the exact values are while i turn the knob in edit. Quote Link to comment Share on other sites More sharing options...
ivanmongiardo Posted April 7, 2015 Share Posted April 7, 2015 Same thing here.. after upgrading my PODHD500X with the last firmware, I cannot see percentage while tweaking amp parameter...It seems like there is a bug in the last firmware.. Quote Link to comment Share on other sites More sharing options...
jandrio Posted April 7, 2015 Share Posted April 7, 2015 After installing firmware 2.61 and loading the full amp packet I noticed that when I am tweaking the amp/cab DEP knobs I can't see their percentages on my POD HD500X Edit software. Also some patches have no sound. When I load them, I get no sound. And the last bug I noticed is that sometimes when I am doing a dual amp setup and save it, every time I try to load it, the second amp has all its knobs on the amp section at 0% for no reason. do u mean that those patches sounded ok PRIOR the update, but AFTER the update they have no sound? ΓιώÏγο, can u pls post those no-sound-patches ? Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 7, 2015 Author Share Posted April 7, 2015 do u mean that those patches sounded ok PRIOR the update, but AFTER the update they have no sound? ΓιώÏγο, can u pls post those no-sound-patches ? exactly that, but unfortunately I can't post these specific patches because they are not mine. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 7, 2015 Share Posted April 7, 2015 double check the input, I've had this happen to me, where i was using the variax and the input was set to guitar. Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 7, 2015 Author Share Posted April 7, 2015 double check the input, I've had this happen to me, where i was using the variax and the input was set to guitar. I have the Input 1 to guitar always and input 2 to variax or variax mags Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 7, 2015 Share Posted April 7, 2015 did you reset the globals? (hold direction key left while powering on) Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 7, 2015 Author Share Posted April 7, 2015 did you reset the globals? (hold direction key left while powering on) Yes I did. Quote Link to comment Share on other sites More sharing options...
videoman77 Posted April 7, 2015 Share Posted April 7, 2015 did you reset the globals? (hold direction key left while powering on) Is resetting the globals always necessary when doing firmware updates? This might fix some of my issues i have listed in another post. Does resetting globals reset all your patches to factory? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 7, 2015 Share Posted April 7, 2015 good practice not always required... and it will not affect your patches... your setlist names may change... but the patches will remain the same. Quote Link to comment Share on other sites More sharing options...
videoman77 Posted April 7, 2015 Share Posted April 7, 2015 good practice not always required... and it will not affect your patches... your setlist names may change... but the patches will remain the same. Thanks for the info. Also is it a good idea to have the firmware overnight everything then reload your bundle? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 7, 2015 Share Posted April 7, 2015 won't make any difference. Thanks for the info. Also is it a good idea to have the firmware overnight everything then reload your bundle? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 7, 2015 Share Posted April 7, 2015 i think he meant overwrite Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 7, 2015 Share Posted April 7, 2015 that would make more sense! and not a bad troubleshooting method to determine if you tones are the issue or the pod. i think he meant overwrite Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 7, 2015 Author Share Posted April 7, 2015 i think he meant overwrite that would make more sense! and not a bad troubleshooting method to determine if you tones are the issue or the pod. What are you talking about guys? Quote Link to comment Share on other sites More sharing options...
videoman77 Posted April 7, 2015 Share Posted April 7, 2015 Yeah i meant overwrite not overnight...LOL Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 8, 2015 Share Posted April 8, 2015 Thanks for the info. Also is it a good idea to have the firmware overnight everything then reload your bundle? i think he meant overwrite that would make more sense! and not a bad troubleshooting method to determine if you tones are the issue or the pod. What are you talking about guys? got it? Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 8, 2015 Author Share Posted April 8, 2015 got it? "Also is it a good idea to have the firmware overwrite everything then reload your bundle?" Still didn't get this part. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 8, 2015 Share Posted April 8, 2015 when you install the firmware, you have the option of keeping your files or not. Don't keep them. Quote Link to comment Share on other sites More sharing options...
jandrio Posted April 8, 2015 Share Posted April 8, 2015 when u get this dialog box during flash update, u must answer "NO" Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 8, 2015 Author Share Posted April 8, 2015 when you install the firmware, you have the option of keeping your files or not. Don't keep them. when u get this dialog box during flash update, u must answer "NO" I said no as well... Still got the bugs... Quote Link to comment Share on other sites More sharing options...
jandrio Posted April 8, 2015 Share Posted April 8, 2015 i suggest u raise a support ticket. Quote Link to comment Share on other sites More sharing options...
videoman77 Posted April 8, 2015 Share Posted April 8, 2015 yeah in the setlists I'm still not seeing the Variax set list that has the presets for the new amps. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 8, 2015 Share Posted April 8, 2015 The Variax setlist does not have presets for the new amps. It has presets that include Variax guitar settings with existing amps, mostly providing good tones for popular cover songs. Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted April 8, 2015 Share Posted April 8, 2015 and you won't get that setlist name until you reset the globals.... and won't get it at all if you keep your existing tones..... Quote Link to comment Share on other sites More sharing options...
videoman77 Posted April 8, 2015 Share Posted April 8, 2015 Oh ok thanks! Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted April 9, 2015 Author Share Posted April 9, 2015 Seems like the new update is addressed to these bugs. Thanks line 6 :) http://imgur.com/SaR78r5 Quote Link to comment Share on other sites More sharing options...
