DaveLeeNC Posted May 25, 2016 Share Posted May 25, 2016 I recently acquired a new HD500X and (before I knew what I was doing) I permanently changed a couple of the original presets that come on the HD500X. I assume that there is some kind of "factory reset" capability here where I could get those back. But is there a 'bundle' available with all the presets that come installed on the HD500X? Thanks. dave Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 25, 2016 Share Posted May 25, 2016 Don't think there's a bundle anywhere. Back up your patches and do the factory reset if you really want them back. Don't know what you'd do with them anyway, though. They're all f$!#/!g awful....unless you need a reminder of what NOT to sound like. I say good riddance. 2 Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 25, 2016 Share Posted May 25, 2016 You need to reinstall the firmware to restore the factory presets. There is no bundle available for download directly but I know some users make backups of the factory bundle after a firmware update. Perhaps one of those users will read this and post their bundle here for you. 1 Quote Link to comment Share on other sites More sharing options...
DaveLeeNC Posted May 25, 2016 Author Share Posted May 25, 2016 Thanks for the comments. On a related note, two additional questions regarding the 'Vintage Pak" (which I own). 1) If I do a reset will I be able to simply reinstall the Pak (via Monkey I would assume)? 2) The amps in the Vintage Pak only show up in the Windows Editor when the HD is connected. Is there a way to get those 'into' the Editor? Thanks. dave 1 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted May 25, 2016 Share Posted May 25, 2016 Thanks for the comments. On a related note, two additional questions regarding the 'Vintage Pak" (which I own). 1) If I do a reset will I be able to simply reinstall the Pak (via Monkey I would assume)? 2) The amps in the Vintage Pak only show up in the Windows Editor when the HD is connected. Is there a way to get those 'into' the Editor? Thanks. dave 1) Yes. I actually believe they will stay. 2) No, you have to have the HD connected 1 Quote Link to comment Share on other sites More sharing options...
duncann Posted May 25, 2016 Share Posted May 25, 2016 On a related note, two additional questions regarding the 'Vintage Pak" (which I own). 1) If I do a reset will I be able to simply reinstall the Pak (via Monkey I would assume)? Thanks. dave The only way the pack will vacate the HD is if the HD is connected to your computer, the license manager is running, and you manually deauthorize the pack. So the answer is yes. The only ambiguity about this is if you deathorize the pack using your support account on Line 6's website, instead of the license manager. Then run the license manager and log in with the HD connected. It might automatically deauthorize the pack on the device itself. Not sure. Running the editor or the Monkey program won't do anything to the packs. In fact, I remember doing a firmware flash, followed by a reset, and all the packs were still accessible. 1 Quote Link to comment Share on other sites More sharing options...
DaveLeeNC Posted May 25, 2016 Author Share Posted May 25, 2016 Thanks for the additional info. FWIW, if you are connected to your HD (with the Vintage Model Pak, for example), and turn off your HD device while in the editor any amp models that 'used to be in the editor' are now gone. Interesting. dave ps. Duncann, you used the term 'vacate the HD' in your response. I'm curious as to why you used that terminology as I was not interested in getting something 'off' the HD, I was simply interested in the Editor treating the Vintage Pak amps/cabs in the same way it treats the default set. It never occurred to me that this process might involve removing something from my HD. Quote Link to comment Share on other sites More sharing options...
duncann Posted May 25, 2016 Share Posted May 25, 2016 Thanks for the additional info. FWIW, if you are connected to your HD (with the Vintage Model Pak, for example), and turn off your HD device while in the editor any amp models that 'used to be in the editor' are now gone. Interesting. dave ps. Duncann, you used the term 'vacate the HD' in your response. I'm curious as to why you used that terminology as I was not interested in getting something 'off' the HD, I was simply interested in the Editor treating the Vintage Pak amps/cabs in the same way it treats the default set. It never occurred to me that this process might involve removing something from my HD. The graphic images are still there, but the text is gone. Haha. Not very nice of it. And if you try and load a preset in offline mode that has any of the model pack amps in them, it will replace those amps with something else. For example the 5150 is replaced with the Solo-100 overdrive. That's one of the things I never like about the model packs. There's no offline mode for them, as Brue58ski pointed out. No reason really for the word choice. Sometimes a strange, and probably incorrect way, of phrasing things pops into my head and I act on it without much thought. I do the same thing with guitar phrasings. :) Nothing's really removed from the device itself when getting rid of the model packs, they are always there. It's just the authorization to use them goes away. I mentioned it earlier because it actually takes effort on your part to remove that authorization, so a simple reset or firmware flash won't affect them, they'll still be there. Quote Link to comment Share on other sites More sharing options...
DaveLeeNC Posted May 25, 2016 Author Share Posted May 25, 2016 Got it - thanks. dave Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 26, 2016 Share Posted May 26, 2016 Hello I saved my bundle you can download it : https://www.dropbox.com/s/qxrq9f2oeox8kxt/POD%20HD500X%20Bundle%202015-Oct-15.5xb?dl=0 Greetings Quote Link to comment Share on other sites More sharing options...
DaveLeeNC Posted May 26, 2016 Author Share Posted May 26, 2016 Hello I saved my bundle you can download it : https://www.dropbox.com/s/qxrq9f2oeox8kxt/POD%20HD500X%20Bundle%202015-Oct-15.5xb?dl=0 Greetings PB - THANK YOU! For some reason I just wanted "all the originals", even though I haven't found one I like. dave Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 26, 2016 Share Posted May 26, 2016 PB - THANK YOU! For some reason I just wanted "all the originals", even though I haven't found one I like. dave If you do find one to your liking, you'd be the first. We'll write a book. ;) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 27, 2016 Share Posted May 27, 2016 I want the originals because I'm selling the unit - replaced with a HD Pro X with FBV. When I downloaded the above bundle, all I got was blank presets.. Quote Link to comment Share on other sites More sharing options...
Punkyboy Posted May 27, 2016 Share Posted May 27, 2016 I want the originals because I'm selling the unit - replaced with a HD Pro X with FBV. When I downloaded the above bundle, all I got was blank presets.. Serious? I just check it and 100% working for me! Don't forget that's the original bundle, and it's normal that user 1,2 and 3 list are empty. PB Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 27, 2016 Share Posted May 27, 2016 I want the originals because I'm selling the unit - replaced with a HD Pro X with FBV. When I downloaded the above bundle, all I got was blank presets.. If you are selling it.... 1. who cares what you have on it, because the first thing a new user is going to do is come here and ask what to do and we are going to tell him to reinstall the firmware to start from scratch. 2. why wouldn't you just reinstall the firmware to get everything back to factory default, not just the patches. As to the 'blank' presets... Those are 'the original' presets. If you kept up to date with the firmware, there are different presets that come with. And, of course, there's that whole 'global eq' that gets added with the newer firmwares. Quote Link to comment Share on other sites More sharing options...
DaveLeeNC Posted May 27, 2016 Author Share Posted May 27, 2016 I want the originals because I'm selling the unit - replaced with a HD Pro X with FBV. When I downloaded the above bundle, all I got was blank presets.. That is odd as I downloaded them and got what surely looks like the original set of presets to me. dave Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted May 27, 2016 Share Posted May 27, 2016 I want the originals because I'm selling the unit - replaced with a HD Pro X with FBV. When I downloaded the above bundle, all I got was blank presets.. It's a whole lot of effort for something that you're about to part with. Let the guy buying it worry about the presets... Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 27, 2016 Share Posted May 27, 2016 If you are selling it.... 1. who cares what you have on it, because the first thing a new user is going to do is come here and ask what to do and we are going to tell him to reinstall the firmware to start from scratch. 2. why wouldn't you just reinstall the firmware to get everything back to factory default, not just the patches. As to the 'blank' presets... Those are 'the original' presets. If you kept up to date with the firmware, there are different presets that come with. And, of course, there's that whole 'global eq' that gets added with the newer firmwares. 1) Obviously, some people DO care, which is how this thread got started in the first place. Buying a used unit with the latest firmware (I HAVE kept up with the updates), pedals calibrated and whatever version of the factory presets I can find will at least give the new owner a running start, which might be nice if he's a newb. 2) Because restoring a bundle is a lot easier. It's a whole lot of effort for something that you're about to part with. Let the guy buying it worry about the presets... Maybe I'm just a nice guy. Punkyboy: My bad! I was going by what the editor said after i sent the bundle to the POD. I should know better than that! The original presets installed fine. Thanks for saving that, for anybody who wants it for whatever reason. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 27, 2016 Share Posted May 27, 2016 If you were really a nice guy, you would reinstall the firmware (which would include the patches). Because the factory settings (not just factory patches) are always a good place to start. I don't know what changes you made. You could even have the GEQ at some awkward sounding tin can level. Variax as Input 1. Mic as Input 2. Pedalboard mode. 50hz hum for the Brits. LCD contrast... do you even remember what all you've changed? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 27, 2016 Share Posted May 27, 2016 Pianoguy - That's right, you don't know, so why do you keep assuming that no one else knows? Not only will I go the extra mile to make the next owner's life easier, I'll take the time (if he's a newb) to give him a brief overview with the benefit of my experiences. I'm sure you'll have some smarmy comment about that last line, but dig it - I DON'T CARE! Cruisinon2 - No offense intended, I should've added a smiley face :) ! 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 27, 2016 Share Posted May 27, 2016 Yes, you're right. I do have a smarmy comment. If you want to be the nice guy that puts forth the effort, re-install the firmware. It will take everything, not just patches, back to factory default. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 27, 2016 Share Posted May 27, 2016 Here's some of the stuff you don't know. The fw was reinstalled 3 weeks ago when the POD seemed to be misbehaving (Win10 problem), before I decided to get the PRO X (eliminates the excess cabling required for 4 cm, provides a simple dry out solution). I reinstalled my own presets, which is why I didn't have the originals. I haven't made ANY significant changes since then. I'd know. So there, smartypants, lick that lolli! :) ;) :P Dude, this is silly. I'll admit that I don't know everything. Will you? Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 27, 2016 Share Posted May 27, 2016 How is it our fault that you left out that little piece of information. Not that it should really matter. I wouldn't know how someone could have gone 3 weeks without changing the settings to what they needed. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 27, 2016 Share Posted May 27, 2016 All I was looking for was a link to the factory presets. How is anything beyond "I don't know" relevant? The answer to "who cares" is "I care" and you should've quit there. I even tried to make peace, but you just won't let it go. Insulting to the last. I've seen posts by you where you actually offered good solutions. You've even helped me out a couple of times. I think you mean well. Do you have to be so consistently rude and insulting? Maybe you don't see yourself in that light, but I do, and I can't be the only one despite your 233 up votes. Look, just think about it. You can have the last word if you like, I'm unfollowing this topic as it's already wasted too much of my time and energy - and besides, I got what I came for! Peace! 1 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted May 28, 2016 Share Posted May 28, 2016 I wonder when we changed the definition of the word 'insult' to be something that it is not. Quote Link to comment Share on other sites More sharing options...
apx20 Posted September 2, 2017 Share Posted September 2, 2017 I believe you can reset by unplugging power, hold down "L" arrow on the button Right of the screen AS you plug in the power. Mine instantly restored OE patches. :) I know this is a year later but I just picked up an HD500x..so.. Quote Link to comment Share on other sites More sharing options...
TZBassGuy Posted September 27, 2017 Share Posted September 27, 2017 I just bought a used HD500x. When I flashed the firmware ALL patches in the unit disappeared. Thanks to the above post I was able to restore them by holding the Left arrow key on the right side of the screen as I powered on again. THANKS FOR THE TIP: 1 Quote Link to comment Share on other sites More sharing options...
mara17 Posted October 20, 2019 Share Posted October 20, 2019 On 9/2/2017 at 3:34 PM, apx20 said: I believe you can reset by unplugging power, hold down "L" arrow on the button Right of the screen AS you plug in the power. Mine instantly restored OE patches. :) I know this is a year later but I just picked up an HD500x..so.. Thanks, this was really valuable tip for me. Just got second hand hd500x, and it was full of presets which were something else than originals. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 20, 2019 Share Posted October 20, 2019 1 hour ago, mara17 said: Thanks, this was really valuable tip for me. Just got second hand hd500x, and it was full of presets which were something else than originals. Do you remember that scene in Harry Potter when Fred and George were going to enter the Tri-Wizard Tournament? Hermoine said.... "It's not going to work" oh, and just as a point of reference: There's 24 comments that come before that one that tell you how to do it. Why choose that one. You quoted someone that has one post on the entirety of the L6 board. He made one post to a thread a year and a half after it had been last used. And then he disappeared. Two years and counting, never heard from again. Of course, having numerous posts doesn't make someone a genius. But when your choice is 2 dozen posts all telling you one of two things.... why pick the 3rd option Quote Link to comment Share on other sites More sharing options...
mara17 Posted October 23, 2019 Share Posted October 23, 2019 On 10/20/2019 at 1:23 PM, pianoguyy said: oh, and just as a point of reference: There's 24 comments that come before that one that tell you how to do it. Why choose that one. You quoted someone that has one post on the entirety of the L6 board. He made one post to a thread a year and a half after it had been last used. And then he disappeared. Two years and counting, never heard from again. Of course, having numerous posts doesn't make someone a genius. But when your choice is 2 dozen posts all telling you one of two things.... why pick the 3rd option Those 24 comments before did not contain that tip. Quote Link to comment Share on other sites More sharing options...
crossthestyx Posted August 12, 2020 Share Posted August 12, 2020 1) Unplug the unit. 2) Hold down the directional button to the Left towards the screen. (the button just to the right of the screen in between where it says "Enter" above, and "Move" below.) 3) Plug the unit back in, continuing to hold the button down left. **This does a hard reset, and you will get all the original factory presets back. You will have to "deauthorize" the unit in "License Manager", then "re-authorize" to get back software "bundles." Obviously you're going to lose any patches you've created. Save them if you need to before hand. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted August 12, 2020 Share Posted August 12, 2020 46 minutes ago, crossthestyx said: 1) Unplug the unit. 2) Hold down the directional button to the Left towards the screen. (the button just to the right of the screen in between where it says "Enter" above, and "Move" below.) 3) Plug the unit back in, continuing to hold the button down left. **This does a hard reset, and you will get all the original factory presets back. You will have to "deauthorize" the unit in "License Manager", then "re-authorize" to get back software "bundles." Obviously you're going to lose any patches you've created. Save them if you need to before hand. nope. wrong on so many levels. Quote Link to comment Share on other sites More sharing options...
lbridwell Posted November 5, 2022 Share Posted November 5, 2022 On 5/26/2016 at 2:01 AM, Punkyboy said: Hello I saved my bundle you can download it : https://www.dropbox.com/s/qxrq9f2oeox8kxt/POD%20HD500X%20Bundle%202015-Oct-15.5xb?dl=0 Greetings Any small chance you still have the bundle saved and can re-upload it? Accidentally overwrote an entire preset setlist and can't get it back by updating firmware because Line 6 Monkey doesn't work with Mac OS Monterey. Quote Link to comment Share on other sites More sharing options...
