wizardman
How do you import 3rd party IR's to the powercab plus?
Does anyone know how to import 3rd party ir's to the powercab plus? I have purchased liveready ir's and the M britt helix presets but the Powercab editor app will now allow me to import any of the ir's.
Any help much appreciated!
I am having the same problem. I get a message that says...
"Impulse response Import failure.
Impulse response Import failed. Please try Again".
Try to download Powercab Firmware 2.0 that was released today. Maybe that helps …
New firmware doen't help. The Powercab only accepts IRs with specific properties, namely "48kHz, 24-bit, mono, 2048 samples". I have a bunch of IRs that are useless with Powercab + because they won't import.
I tried it out a few days ago, either – the PC+ did accept most of the IRs that I use with my Helix, but there comes no sound out of the Powercab. The feature of imported IRs is really useless.
I'm having the same problem.
I have two PowerCab Plus's and did the update without issue, upgraded my PowerCab Edit software but now can't load IR's into either unit. I downloaded the manual to make sure I'm not doing something wrong, but still no luck.
I tried to load the Allure IR's just to make sure that wasn't the problem and those also fail to load. The IR's are the same ones I have loaded in my Helix. This is the error message I see:
I know there's a lot going on right now with the new new Helix firmware but has anyone confirmed whether this is a bug not being able to import IRs to the PowerCab Plus? Would just like to know if it's a problem specific to my setup or a general defect. I used the same setup to update the Helix and was able to get through that process.
Thanks
Thanks
48kHz, 24-bit, mono, 2048 samples... that's the only type of IRs it will take.
I have loaded Ownhammer, 3Sigma, Celestion and ML Sound Lab IRs into Powercab + without any problems. Those companies provide different folders with different sample rates and bit-rates. Just pick 48k, 24-bit.
I had problems loading the Allure IRs I downloaded for line 6 as well. Weird. I know.
No problems here as well so it can’t be a bug. Just really picky about sample rate etc.
Same problem here. I bought Celestion IRs and tried to import both the Line6 formatted IRs and 48k, 24 bit, but can't even select the file from the import screen since its greyed out. Also tried the Allure IR wav files which came pre loaded in the Power Cab +. but those won't load either.
Seems to work for me. I am able to load Celestion IRs into my PowerCab 112 Plus. But they must be 48k, 200 ms, and Mono. Any of the other Celestion IR formats fail to load.
Has anyone has tried first loading the IRs that are not working in the Powercab to their HX device, e.g. Helix? Let the Helix do the IR conversion to its native format as it accepts a wide range of IR formats. If it exports into Helix's preferred format(48kHz, 16-bit, mono, up to 2048 samples) then an export of the IR from the Helix and load into the Powercab might work just fine.
Ideally the exported IRs from the Helix will match the format required by the Powercab. The spec required for IRs appears to be the same for both the Helix and the Powercab so I suppose it may come down to the backup format Line6 uses when it exports IRs from the Helix. If anyone tries this please let me know if it works. My Powercab is still on the way. If it does work my only concern would be that the  IR export from the Helix remained a high quality and fairly accurate representation of the original IR.
It doesn't work. The exported IR is probably the original file non-truncated.
Thanks for trying! Disappointing and surprising that doesn't work. Maybe a third party convertor is going to prove to be the way to go until and if Line6 widens the breadth of IRs it can import on the PC+.
Don't think the exported IR is a non-truncated version though, more likely truncated and potentially format modified, at least from stereo to mono, depending on what was originally imported. Who knows what goes on behind the curtain though. I've actually been curious for a while about what exactly the Helix exports in its IR files as I wondered if it was better to load the original IRs or the backups. Probably doesn't make a difference unless the Helix converts its IR backups again when they are loaded and makes each iteration of load slightly more different from the original. Seems unlikely.
I was a bit dissapointed about it at first. I have all these Freman IRs that really sounded great that I couldn't load into the PC. I actually found some other IRs that work really well with the Powercab, so its all good.
I purchased some from Sonic DNA.  The eddie3 cabs sound great, based on EVH 4X12.  And I bought from 3 Sigma Audio the updated Mesa Boogie pack.  I Love my metal so Vintage 30s are my liking.
How can i tell if the ir's i purchased are 48k, 200 ms, and Mono? I purchased the Workhorse and none of them work
Just keeping this tread alive.  This is a real problem.
I also cannot get IR's that work in both Helix and HX stomp to load into PC+ 112. I get the same Import error message on computer as those above.
I also tried importing the IR's into Helix, letting Helix "process" them, exporting the "processed" IR's from Helix, then importing into PC+ for use with my HX Stomp to save blocks/processing.
What type of file are you trying to import? .wav or .hir? If it is .hir, they will not load into the the PC+. Those will only work in the Helix. We all found this out the hard way. Market place does not tell you this.
I exported an IR from Powercab and compared it to a OH-IR.
The OH-IR is MONO 32 bit float / 48 kHz
The PC-IR is MONO 32 bit / 48 kHz
Looks like the Powecab do not accept float.
I was able to open and save the files without 'float' using WaveLab, and then use mp3tag to make sure all converted files had the correct 'title'.
Then they all did import without error to my Powecab.
Yeah so just got a Powercab, I love it and it looks and sounds great.
Sucks that the HXStomp doesn't have a link out but more bizarrely that the IRs I bought from Line6s store won't work on it.
Are we going to get an update for this? If so when. Thank you
