Administrator
    1,479
Everything posted by Line6Tony
  1. Symptom: User cannot complete the login for the WiFi update process. Helix Stadium customer connects to preferred WiFi network, and tries to login for updates. The login screen shows a blank QR code (_ _ _ _ _ _). After clicking on 'Login with Username', the user's credentials are entered and highlighted in green once complete. The Login button does not move the process forward. Workarounds: 1. Set the Date/Time to OFF within Global Settings, then set it manually to today's date. After that, try the login with the WiFi connection still on within the Stadium login screen. 2. Some users have found that toggling the WiFi feature OFF, then back ON should allow them to re-connect to login screen, and the QR code will then appear. Allow for login. Ignore the following step until the first two options are tried and produce no results. 3. Install the latest firmware with Line 6 Central via USB-C cable. For Windows, it’s good to install the Helix Stadium app first, but it doesn’t allow for updates. You’ll need to use Line 6 Central 1.04 for the update process. Once they have both installed, only open Line 6 Central. When Stadium XL is connected, click on the option to download the latest update. The update goes in two parts: first it downloads, then it ask to “Perform” the update.
  2. Stadium should work with all the expression pedals that Helix and HX products work with. Helix/HX is fully compatible with the Line 6 EX-1 and Mission Engineering's EP1-L6 external expression pedals. Other pedals may work with Helix, although they may not be fully compatible or tested, such as the Dunlop DVP1XL. Some pedals (like those from Dunlop) have dip switches that allow it to work with Helix/HX/Stadium, but there are still others that don’t. This is due to an industry-wide lack of consensus between manufacturers. In some cases, the pedals internal dip switches may need to be adjusted to ensure proper polarity. If you experience trouble with inaccurate expression pedal swing, try adjusting any internal or external dip switches the pedal may have. Also note that any expression pedals that appear to work backwards can be set to work properly by setting Global Settings > Switches/Pedals > EXP 2 Polarity to “Inverted.”
  3. Updating the firmware directly from your Helix Stadium is strongly recommended as the best way to update. However, if you’re using Line 6 Central or the Helix Stadium application to update, always update the application first. If your Helix Stadium attempts to update the firmware and throws the message "Download Failed. Error code: -16", you need to log in. On Windows, users will need to install the Helix Stadium ASIO Driver or Helix Stadium application for Line 6 Central to connect with their Stadium. Both of those installers include the required WinUSB driver. The driver install requires a reboot. If any type of unexpected behavior occurs, including partial or failed updates, try updating with the latest version of either the Helix Stadium app or Line 6 Central. If you are running into issues logging in on the device or connecting to the Helix Stadium app, disconnect from your Wi-Fi network on the device and reconnect to it. We've seen some users see success with a USB-A Ethernet adapter for the Stadium XL. Also, your system's security settings may affect Wi-Fi connectivity. If the login QR code is blank, exit to the Home Screen and try again, or login manually, or connect to the Stadium app. If you are experiencing an odd behavior with a particular preset, try exporting it and reimporting it using the Stadium app to see if that solves the issue. Hardware Reset: hold down the HOME and SONG VIEW buttons while powering on. In the maintenance window, click on "Restore Factory Defaults" then press OK to confirm. Restart the Helix Stadium hardware. The Helix Stadium application connects over Wi-Fi for editor and librarian features. For now, Stadium XL editing over USB is not supported. Updating to Helix Stadium/XL from Helix/HX: https://line6.com/support/page/kb/effects-controllers/helix_130/updating-to-helix-stadiumxl-from-helixhx-devices-r1100/ CustomTone access - At the moment, CustomTone does not support Helix Stadium presets. If you have a registered Helix Stadium, CustomTone will show compatible tones. Unfortunately, as of this writing, Helix Marketplace assets are only compatible with Helix, HX and POD Go products. If you purchased Marketplace assets specifically for Helix Stadium, we’re more than happy to refund your purchase. To control your amp from Helix Stadium: The Control A/B (and the Helix Stadium XL Control C/D) jacks can be configured for “Ext Amp” via Global Settings > Switches/Pedals > Control (Tip) and Control (Ring) options. The Remote Access PIN on Helix Stadium XL can be viewed by clicking “Set PIN” in Global Settings > Preferences. It is overwritten by inputting characters. With the Preset Knob you can scroll directly to your User Presets, bypassing the need to scroll through endless Empty slots. The L6 Link connection is not available yet because the D10 Expand box has not yet been released. For now, the only options for connecting Helix Stadium XL to the PowerCab 112 and PowerCab 212 PLUS is the 1/4" or the XLR cable connections. Those connections don't have any additional 'controller' features. Helix Stadium Video Playlist: https://www.youtube.com/playlist?list=PL9lmrxAADINixJKFQjmxqKe9P1Xg8V9xg
  4. We have some important info for those of you planning on updating to Helix Stadium/XL from Helix/HX devices: *Make sure your Helix/HX has been updated to 3.50 or newer firmware BEFORE you export any of your stuff *Helix Stadium cannot import full-state BACKUPS from Helix/HX. However, you can extract Presets, IRs, and Favorites (which all CAN be loaded into Helix Stadium) from a backup file via HX Edit, even if you don’t have Helix/HX hardware. From HX Edit’s File menu, select "Extract Files From Backup.” *If you still have your Helix/HX hardware (or Helix Native), presets, IRs, and even favorites can be dragged out of HX Edit/Helix Native to your desktop or any finder window and then dragged back into Stadium via the Helix Stadium app *We’ve mentioned this before, but note that the older Hybrid cab engine is NOT in Helix Stadium—only the new cab engine that came with 3.50 and later builds. Any presets with Hybrid cabs will automatically load an equivalent new cab, which will sound different. *Also note that, at least at launch, Stadium won't be able to automap your IR library to existing presets, due to its all new, much more powerful file system. Unfortunately, you'll need to write down which IR(s) each preset uses. We're hoping that automapping might work in a future FW rev (depending on how annoying it is), but there's no promise—much less timeline—implied. *There are a few other minor caveats (select HX EQ models appearing as our new 7-band Parametric, EQ bandwidth and slope improvements, pan laws, parallel vs. serial levels, single vs. dual cab levels, etc.) but we're currently working on a document (and accompanying video perhaps?) called something like "Getting Ready For Helix Stadium” which will provide details So while transferring presets from Helix/HX to Stadium may not be perfectly seamless, Helix/HX presets are actually sounding a bit better in Stadium, which can be apparent in reverb tails, noise level, headroom, etc.
  5. Older generations of some Line 6 products are is not updateable with a download and requires the installation of an E-Prom to update the firmware. Unfortunately, Line 6 no longer offers EPROM upgrades. Technology life cycle has made it not viable to buy the blank EPROMs through normal commercial channels any longer. Here is a list of such products: AxSys AX2 Flextone I/II POD/POD Pro 1.x BassPOD/Bass POD Pro 1.x HD147
  6. HX One’s sample rate is 48kHz for analog-to-digital and digital-to-analog conversion. HX One’s processing is 32-bit floating-point.
  7. Is Relay G50, G55, and G90 still manufactured? No, G50/55 are no longer manufactured as of 9/1/23, and G90 is no longer manufactured as of 3/1/23. Despite this, retailers may still have units in inventory over time. Why are they no longer manufactured? Typically, as with many companies, the decision to end the manufacture of any YGG product is based on one or more of these factors: a lack of market demand, a planned successor product, or because the parts to manufacture it are no longer available. What product will replace them? For a number of reasons vital to our business, we can't comment on future product releases, but follow us on social media or sign up for our email list to receive new product announcements. Q: Why are they at a lower price? You may find Relay G50/55/90 at a lower price at retailers to allow them to clear their inventory of this discontinued product. Q: If I buy one, will you honor the warranty? Yes. The full warranty applies if bought as new from an authorized Line 6 retailer and a receipt copy is furnished. See our Warranty page for details. Q: In what ways will the discontinued product be supported? You can find manuals on our Legacy Products page, additional information at our Knowledge Base, tutorial videos on our YouTube Support channel, and our Customer Support team can be reached from our Contact Us page.
  8. As of late 2024, online purchases generate about 22 billion packages each year! However, not all reach their intended destination. Package thieves – known colloquially as “porch pirates” – steal many deliveries right from our doorsteps and yards. Porch pirates stole $12 billion in packages in 2024, and as many as 58 million Americans have become victims. Criminals seem to target certain residential building types more than others; homes with more occupants tend to experience higher theft rates. Line 6 requires a signature for Helix product family and guitar purchases made at our branded online shops. For further protection, we encourage you implement one or more of these general "porch piracy" prevention measures: Get security cameras. Install external lights and/or signs. Use tracking apps. Sign up for UPS My Choice: View and Track All Shipments With UPS My Choice® | UPS - United States. They offer a free version and a Premium version. Make sure someone is home at the time of delivery. Coordinate with your neighbors and let them know you have a high-value package coming. Have the package delivered somewhere else if you suspect you may be targeted. Request a signature confirmation. Send the package to a remote pick-up location provided by the carrier. Purchase a package guard or porch pirate bag, a nylon bag that locks to your front door or gate. Instruct the courier to place your package inside and close it using the combination lock. Get Amazon Key (driver puts your package in your home). What to look into if your package is stolen: Track the package. Check if your neighbors saw it or held on to it for you. Contact the seller or retailer, as their relationship with the carrier may offer additional resources than they'd offer a recipient. File a claim with the shipping company. Use the purchase protection features on your credit card. File a home insurance claim.
  9. Attention HX One users: We have discovered a preset corruption issue with HX One Firmware 3.80. We are resolving this issue and expect to post updated HX One firmware with the fix soon. We recommend continuing to use HX One Firmware 3.71 until then.
  10. Some Android mobile devices do not fully support "USB Host mode", which is required for the Spider V Remote app to communicate with Spider V amplifiers. We have found that the Google Play store offers free third party "USB Host Diagnostics" utility apps that may identify potential issues with USB Host mode support. While we do not officially endorse any such app, we suggest utilizing YouTube as a tutorial resource for working with your choice of app.
  11. All Line 6 hardware and software work as expected with Sequoia, and there have been no unexpected compatibility issues while updating hardware in Sequoia. Below are all known issues regarding Sequoia compatibility: POD HD, POD HD Pro, POD HD Pro X, POD HD 300, POD HD 400, POD HD 500, POD HD 500X and Variax Workbench HD Editors: The apps launch and are functional, but they have special characters in the menu toolbar where the app’s name should be. This only happens on the first run of the app. Driver Issues: Incorrect driver version is displayed in Control Panel (TonePort and POD HD) Unable to select Sample Rate/Buffer Size in Standalone apps (Helix/POD Go used with Metallurgy and SVT Suite) POD Farm, Amp Farm and Echo Farm Continue to Work in Rosetta Mode: Starting with Big Sur macOS 11, Apple introduced Rosetta v2, which allows applications to run in an emulated mode. Rosetta runs automatically with our software that is NOT a plugin. To use Rosetta with our plugins, locate your DAW in the Applications folder. Use command ⌘+I and check the “Open in Rosetta” box. You may have to rescan your plugins afterwards. Legacy System Extension Warning After Updating to Sequoia: Anyone who updates their system to Sequoia will be greeted with the same one-time alert that Line 6 users experienced while updating to Ventura or Sonoma. No action other than clicking "OK" is needed.
  12. Unfortunately, production of the Lithium-Ion battery packaged with the JTV, Shuriken, and Variax Standard has been discontinued by the manufacturer. For US/Canadian/EU/UK customers, although it is not an official Line 6 part, we’ve found that the Cameron Sino battery model CS-LNE100SL works as a generic replacement to the original Gen 2 Variax battery. Performance may vary between units. This battery can be found with a Google search at multiple online retailers, but for simplicity, here is the Amazon link: https://www.amazon.com/LIONX-CS-LNE100SL-Standard-Shuriken-98-034-0003/dp/B0CGRT3K8X Model Number CS-LNE100SL in detail:
  13. Line6ers, We've come to the point where Line 6 Monkey will no longer be available. The Line 6 Monkey codebase is very old and no longer works with the latest Operating System SDKs. Until we completely remove Monkey from our Downloads page, we have a workaround that will allow you to use Monkey: Download and install Line 6 Monkey (Windows) from line6.com/software. Download the firmware you want to install from line6.com/software. Download your device's drivers from line6.com/software and install them. Launch Monkey. Click on the Monkey icon in the upper left and select "Diagnostics…". Click OK to the window that opens. In the Explorer window that appears (C:\Users\yourname\AppData\Roaming\Line 6\Line 6 Monkey), remove any .cfg file that may be present. Copy the attached "default.cfg" file into the above location. Quit Monkey. Power your device. Relaunch Monkey. You'll know this change worked if you can see a full list of devices to update. You should now be able to connect your device to Monkey and perform an “offline” firmware installation. When you click on "Firmware", then the "Update Selection" button, point Monkey to the location on your computer where you downloaded your device's firmware, such as your Downloads folder or your Desktop. If you run into trouble, you can always reach our support team at www.Line6.com/company/contact. We expect the workaround to work on macOS 10.14 and earlier, since that was the last one to support 32-bit apps such as Monkey. "Diagnostics" is in the Line 6 Monkey menu. default.cfg
  14. Please see the information below if you experience any issues when updating your Relay G10TII transmitter. If a transmitter has a very low battery state, please make sure to charge it for several minutes before updating the firmware. If an update is attempted on a discharged transmitter, it is possible the update process may fail and may then require repeated attempts to recover. If a transmitter has a very low battery state, it may not always charge correctly upon its initial docking. Please make sure that after inserting the transmitter, you check after another minute elapses to make sure its LED is still indicating flashing red (or flashing green or solid green). If the LED is not indicating after a minute, then the transmitter is likely not charging due to a very low battery state. In this case, it may be necessary to un-dock/re-dock the transmitter repeatedly in the receiver device before it resumes charging correctly. Transmitters that are very discharged can be a special challenge with respect to updating, as they may initially be “stubborn” when attempting to charge. For this reason, it is important for the user to make sure that the transmitter that is to be updated has at least a small amount of charge before initiating the update. To ensure this, before updating, a user should dock the transmitter in the receiver device and wait for a period (at least one minute) to observe that the transmitter LED is continuing to consistently flash red (it is of course, also okay if the transmitter is flashing green or solid green after that minute, as those LED states indicate a sufficient level charge). On the contrary, if the transmitter LED is not giving any indication (either flashing or solid) after one minute has elapsed after docking, this may imply that the transmitter is very discharged. In such a case, it may be necessary to undock/redock the transmitter again (perhaps multiple times), until its LED begins to flash consistently and continuously while docked. Please note that in some specific cases after a firmware update has already failed, the transmitter LED may indicate a very faint red or amber color. In these cases, the transmitter may not flash when docked (until after a successful firmware update has been completed). Furthermore, if a transmitter has both failed an update and has a very discharged battery, it may require several attempts to successfully update again. Also note, that if an update fails, the user should always undock the transmitter and disconnect the receiver device from the computer before reconnecting the receiver device and re-docking the transmitter to try another update attempt. If a firmware update of the G10TII fails, recovery may require one or more attempts and may depend on the situation. For example, if a transmitter was very discharged prior to attempting an update that failed, the recovery process may be more challenging than if an update had failed due to other reasons, such as accidental disconnection before completing the update.
  15. When attempting to update the TBP516G transmitter using Windows, some users have reported that the device either does not establish a connection via USB, or loses the connection during the update. It is worth noting that Windows supplies the driver for this Relay device. There are two scenarios where the Relay device is not recognized by the updater app after connecting via USB: the updater is launched before the Relay device drivers have finished installing. This may occur more often on slower computers, computers that already have several open windows or processes, or with machines that have a slower internet connection. the "Driver not successfully installed" message appears. In this case, click "Change settings" then choose "Yes, do this automatically (recommended)" in the Device Installation Settings dialogue box, then select "Save Changes". In the event the "Driver not installed" message box is not present, you can navigate to Device Installation Settings using the following steps: Click Start, type "devices and printers" in the search box, and then click Devices and Printers. Under Devices, right-click the icon for the computer, and then click Device installation settings. Choose "Yes, do this automatically (recommended)" and select "Save Changes" button. After changing this setting, remove the USB cable, then insert it again so that Windows can detect the Relay device and install the driver for it. It is possible to see the Relay device update fail shortly after it starts. This can occur if one of the Relay device drivers has not finished installing before you initiate an update. In this case, the updater will typically display that the firmware version is unknown. The workaround here is to wait until the driver completes installation, or disconnect the USB cable, reconnect it, then start the update again. Lastly, it is worth noting that some USB cables are charge-only, so a change in cables may help. Also, trying all ports and even a different computer may resolve the issue, based on various USB port configurations.
  16. Please review this link as a further explanation on topics that are covered in the document below: http://www.churchproduction.com/story/main/a-small-churchs-guide-to-working-with-wireless/3 As the environment is the biggest factor in wireless audio performance, there is a chance that certain environments and circumstances will not allow for satisfactory performance. This can be verified by successful performance in a different environment. This is an extremely informative video on how all wireless gear works in a WiFi rich environment Note: If you have multiple members in your band with Line 6 wireless, everyone needs to be on the same RF mode. Pre-Qualification: First Things To Rule Out: Use the factory power supply Try on more than one channel! Try in more than one place/venue Check the transmitter LEDs during drops/interference. RF dropouts result in the green LEDs going completely off. Even one green LED means the signal is present and something other than the wireless system is causing the problem. If you see full red LEDs followed by quickly shifting back to green, it means that the system has re-synced (normal if the dropout is too long). The red LEDs come on only if the intended signal from a Line 6 transmitter is not present. In this case, they are showing RF competing for the same space. Interference: Symptoms Reduction of RF LEDs on the front panel that indicate usable RF signal strength Audio signal muting Possible causes Trying to function at too great a distance Having unintentional transmitters, such as walkie talkies or in-ear monitors, too close to a receiver Significant amount of close-by RF signals within the same 2.4GHz range (Wi-Fi, microwave ovens, etc.) Suggestion "Walk test" your system in advance of an event over the entire desired range to verify that sufficient RF signal is available to avoid mutes from occurring With transmitter off and receiver turned on, scroll through the channels. Red LEDs indicate stray RF on that channel. Choose channels that exhibit the least red LEDs. Note: Line 6 wireless WILL still operate but at reduced range. Decreased Range Symptoms Reduction in range in general Reduced range indoors vs. outdoors Possible causes Blocked "Line of Sight" between the receiver and the transmitter Barriers such as walls or air-curtains can impede the path of radio waves Transmitter strength reduced if it must pass through walls Transmitting through earth (receiver in basement) Human bodies absorbing RF energy Receiver is very close to other intentional radiators in the same frequency band such as Wi-Fi wireless access points Suggestions Improve "Line of Sight" Elevate the receiver Weak Audio (thin audio output compared to other wireless systems) Symptom Weak and/or noisy audio output Possible causes Gain/trim settings on mixer need adjustment Plugging into a "line level" input Plugging into a channel with pads engaged Using a TRS plug in the 1/4" unbalanced output Suggestions Adjust gain/trim as if using a wired microphone Connect the XLR output on the receiver to an XLR input on the mixer Use a mono plug in the 1/4" unbalanced output, never a TRS plug Dropouts ("Audio" vs "RF" dropout: different paths to correct) Symptoms Audio signal interrupted Possible causes Local conditions in one or more venues, e.g. a large Wi-Fi installation in close proximity, metal walls/roof Instruments or amps being used are faulty Signal chain issue Blocked "Line of Sight" between the receiver's antennas and the transmitter's antennas Other XD-Vs/Relays operating on the same channel Receiver near any transmitters such as walkie-talkies, In-Ear Monitors, etc Using a substitute power supply Suggestions Try a different venue to reproduce problem Try multiple instruments/amps to reproduce problem Trace signal through chain one component at a time. "Audio" LED lights when signal is received. Improve "Line of Sight" by moving receiver to 6-8 feet high while avoiding obstacles such as metal posts, walls, etc. Ensure each system has its own unique channel to operate on Move intended transmitter closer to receiver than unintended transmitter to eliminate "near/far" issue. Provide ample distance between the receiver and other transmitters. The distance will depend on the strength of the transmitter and the gain of the transmitting antenna. Use the factory power supply or one that can supply the required 9v DC current. If you are using a pedalboard supply, it must be able to supply this amount of power to the receiver in addition to whatever else you have plugged into it. Q: Does USB 3.0 create interference in the 2.4GHz frequency range? A: USB 3.0 computer cables and peripherals, including hard drives, are known to emit radio frequency interference throughout the 2.4GHz band, which results in reduced range and/or performance for any 2.4GHz device in its proximity (including wireless keyboard or mouse, WiFi, etc.). We recommend placing any digital wireless receivers at least two meters away from the USB 3.0 device and its cabling. Below is a link to a study by Intel regarding this interference. http://www.intel.com/content/www/us/en/io/universal-serial-bus/usb3-frequency-interference-paper.html References for working with wireless systems http://en.wikipedia.org/wiki/Non-line-of-sight_propagation http://www.djsociety.org/Wireless.htm
  17. Q: Are XD-V Wireless Products still manufactured? A: No, XD-V Wireless Products are no longer manufactured as of January 2024. Despite this, retailers may still have units in inventory over time. Q: Why are they no longer manufactured? A Typically, as with many companies, the decision to end the manufacture of any YGG product is based on one or more of these factors: a lack of market demand, a planned successor product, or because the parts to manufacture it are no longer available. Q: What product will replace XD-V Wireless Products? For a number of reasons vital to our business, we can't comment on future product releases, but follow us on social media or sign up for our email list to receive new product announcements. Q: Why is XD-V Wireless Products at a lower price? You may find XD-V Wireless Products at a lower price at retailers to allow them to clear their inventory of this discontinued product. Q: If I buy XD-V Wireless Products, will you honor the warranty? Yes. The full warranty applies if bought as new from an authorized Line 6 retailer and a receipt copy is furnished. See our Warranty page for details. Q: In what ways will the discontinued product be supported? You can find manuals on our Legacy Products page, additional information at our Knowledge Base, tutorial videos on our YouTube Support channel, and our Customer Support team can be reached from our Contact Us page.
  18. Q: Is Amp Farm and Echo Farm still available for purchase? I don’t see them on the web shop. A: The Amp Farm and Echo Farm plug ins are no longer available for purchase as of March 31, 2024. We encourage any potential users to consider Helix Native. Q: Why is it no longer manufactured? A: Typically, as with many companies, the decision to end the availability of any YGG product is based on one or more of these factors: a lack of market demand, a planned successor product, or because the parts to manufacture it (or support the software) are no longer available. Q: What product will replace it? We encourage interested parties to check out our other Software titles, all available at https://line6.com/software-apps/ Q: If I already own it, how will I get upgrades/support? The final version of the software will still be available to download from our Software Downloads page. For existing Amp Farm or Echo Farm users, we are offering a special upgrade path to our Helix® Native plug-in, which delivers the authentic sounds of classic amps, cabs, mics, and effects. You can find the special upgrade version of Helix Native HERE. Q: In what ways will the discontinued product be supported? You can find manuals on our Legacy Products page, additional information at our Knowledge Base, tutorial videos on our YouTube Support channel, and our Customer Support team can be reached from our Contact Us page.
  19. What is Catalyst CX? The CatalystT® CX family of combo amplifiers represents both a physical update to the original Catalyst family, as well as a firmware update. What does the new Firmware offer? · Catalyst CX doubles the number of amp voicings to 12 (compared to the 6 in the original Catalyst) and includes many of our Original Amp Designs—ranging from pristine clean to modern high-gain—with all amp models derived from the Helix® family of amp and effect processors. · Catalyst CX allows for the use of simultaneous effects (Boost, Effect 1, Effect 2) · The effect selection process has been simplified, with the “audition” time for selecting effects extended. · Added visual cues to identify when you enter/exit Effect selection mode, Preset Bank selection, and more. · Additional default deep-parameter settings optimize each amp voicing when in MANUAL mode. · Expanded functionality of the optional LFS2 footswitch (accessed through the free Catalyst Edit software). · Updates to Catalyst Edit software to capture the new firmware functionality. What are the physical differences? · A new custom black & tan grille cloth provides a more traditional look. · Subtle two-tone piping (cream with an enclosed gold braid) outlines the grille cloth, adding to the “boutique” design style. · Updated silk art on the control panel is designed to enhance the user experience by calling out some of the key updates related to the 2.01 firmware. What amps and effects are included? The amps in Catalyst CX are split into 2 groups of 6: the 6 original Catalyst amps are in group 1, and 6 NEW amps are in group 2. You can switch between them by pressing the Ch A and Ch B buttons simultaneously: · Boosts—Just like the original Catalyst, there is a customized boost to match each of the 12 amp voicings · All of the original 24 Effects from Catalyst are present, and now can be accessed any 2 at a time. (also all taken from the Helix family of products) * PLUS a Built-in adjustable Noise Gate Can I edit them beyond just effect mix? Yes, deep editing of effects is available in Catalyst Edit, available FREE on macOS, Windows, iPhone, iPad, and Android devices. https://line6.com/software/index.html Does it take pedals well? Absolutely – external effects can be placed in front of the amp input, in the effects loop, or run an external modeler into the power amp in jack. Are there presets like other Line 6 products? Catalyst stores 6 banks of presets with 2 channels each, for a total of 12 presets. Presets can also be edited/saved using Catalyst Edit software. I have the original Catalyst amp. What about me? All of the new firmware features (new amps, and more) are available to ALL original Catalyst amp owners as a free download (Firmware 2.01) HERE: https://line6.com/software/ Is there a Footswitch for Catalyst CX? Yes, the Catalyst & Catalyst CX amps have a standard ¼” input for the optional LFS2 footswitch. The 2-button LFS2 is a roadworthy metal latching footswitch that provides stock control of Channel and Effect on/off status, while both footswitches may be reassigned via the Catalyst Edit app to control a number of other functions, including Boost on/off, Reverb on/off, Tap Tempo and more. A ten-foot/3.3m right-angle/straight TRS cable is included. When is Catalyst CX shipping? March 2024, worldwide. Where can I learn more? https://line6.com/find/dealer/ KNOWN ISSUE (CATALYST EDIT only) - Currently, there is an issue with disabling the Cab simulation on the direct output within Catalyst Edit. We encourage users to leave cab sim enabled on. The issue is being evaluated for update in a future release. Bug Fix - (for Catalyst CX users only) - In Firmware 2.0 (the factory default firmware for Catalyst CX), If the CLEAN AMP in group 2 is selected, there is audible hum which is part of the model default. Updating to 2.01 firmware will eliminate the issue.
  20. Windows drivers with support for Core Isolation with Memory Integrity are now available with Driver version 2.00.0.0 or greater for the following device families: Line 6 Helix Line 6 POD Go Line 6 HX Stomp Line 6 POD Express Line 6 Spider V Line 6 Powercab Line 6 Firehawk Line 6 AMPLIFi We recommend enabling Core Isolation with Memory Integrity prior to installing your Line 6 driver. Please review the following if Windows will not enable Core Isolation with Memory Integrity after Line 6 2_5 drivers are already installed: • In some cases, the Core Isolation system page was blank/not available, therefore leaving the user with no way to verify incompatible drivers, or the ability to enable memory integrity. https://answers.microsoft.com/en-us/windows/forum/all/windows-11-core-isolation-page-not-available-the/a3498971-7c1c-49a1-b6c8-a57c25f215e2 • User uninstalls unsupported 3rd party drivers and various files (ex. AvsFilter.sys) remain listed as incompatible. With this outcome is advised to install DriverStoreExplorer and remove (force delete) the driver which is listed by vendor in the app. https://github.com/lostindark/DriverStoreExplorer • All incompatible drivers were removed and are no longer displayed as incompatible, yet the user was unable to enable memory integrity (shaded button). This is a registry issue where the “HypervisorEnforcedCodeIntegrity” folder’s contents need to be edited, or perhaps even created. Any registry edits are at the users risk. https://www.syxsense.com/wp-content/uploads/syxsense-securityarticles/windows_configuration/syx-1009-12236.html
  21. Q: I’ve connected everything correctly to my POD Express/POD Express Black/POD Express Bass and it is powered on – why is there no audio? A: Please make sure to turn the volume thumbwheel on the left side of the unit to set the overall output level for the OUT & PHONES. Q: What kinds of batteries are recommended? A: Alkaline batteries are recommended. Non-alkaline batteries such as NiMH or Lithium rechargeable batteries may be used, but the indication of remaining battery life may not be reflected with accuracy and performance expectations may vary. Q: What is the expected operating time with battery power? A: The performance expectations may vary depending on whether headphones are connected (and even the type of headphones can affect this), how much DSP is in use, how frequently the user interacts with the UI, etc. The operating time is typically a minimum of 6 hours when using alkaline batteries (but under ideal conditions, this can be up to 10 hours). Q: What other ways can the POD Express/POD Express Black/POD Express Bass be powered? A: POD Express/POD Express Black/POD Express Bass can be powered by a 9V DC power supply, such as the optional Line 6 DC1g. The product cannot be powered over USB. Q: How can I use my POD Express/POD Express Black/POD Express Bass as an audio interface? A: Power your POD Express/POD Express Black/POD Express Bass with batteries, or with a 9V DC power supply. Connect the product to your macOS or Windows computer with a USB-C cable (not included). Q: Do I need a driver to use this with my computer? A: For low latency USB audio operation on Windows computers (required for most Windows DAW applications), you must first download and install the Line 6 POD Express ASIO® driver from https://line6.com/software/. For macOS computers and iOS or Android mobile devices, there is no Line 6 driver installation necessary—POD Express/POD Express Black/POD Express Bass support the class compliant driver. For details on driver support with the latest operating systems, please visit line6.com/support. Q: What firmware is included on the product? A: As of October 2024, POD Express/POD Express Black/POD Express Bass ship with firmware version 2.00.0 installed. Please visit https://line6.com/software/ to download the Line 6 Central updater application. This can be used to update the firmware for POD Express and POD Express Bass when any new firmware versions are released. Q: How can I update my POD Express firmware or check for new releases? A: You will need to use Line 6 Central version 1.02.0 or later. This is available from https://line6.com/software/. Q: Can I use TRS cables with the Main Output jacks? A: Yes. Q: What if I am connecting to a balanced input. A: If you are connecting a TRS or TS cable to a balanced input, the result will be 6dB lower than if connecting to an unbalanced input. Q: If the batteries have run down but are still installed in POD Express, the device may still power itself on momentarily. Is this normal? A: Yes. Once the batteries reach a low level, the unit will power off. Given time, batteries may “rebound” to a higher voltage. This may cause the unit to momentarily power back on while drained batteries are still installed in the unit. Additional Specs (subject to change) The frequency response on all outputs is 20Hz – 20kHz. There is about -2dB of attenuation around 20Hz that gradually evens out at 50Hz and is then flat up to 20kHz, where it rolls off sharply. The headphone output is load dependent and is specified for a load range of 8-1000ohms. Maximum power output is approximately 120mW Power output with a 32ohm load is approximately 85mW. Sample Rate is 48kHz
  22. Catalyst 2.01 includes six additional amp models derived from our Helix® family of processors, along with the ability to use any two of the 24 on-board effects at a time. There are also some improvements in how you access the different effects, and new visual cues for the different amp functions. How do I update to 2.01? Go to Line6.com, click on “Downloads”, and install Line6 Central to your computer. This is an application that will facilitate this and future updates. Connect your Catalyst or Catalyst CX 60, 100, or 200 amplifier to your computer and launch Line 6 Central. Log in with your Line 6 credentials (or create a new account if you don’t have one). The software will walk you through the entire procedure for updating the firmware. Power on the Catalyst or Catalyst CX amplifier with the master volume all the way down. The screen will show your product and which version of the firmware is currently loaded. It will also say “UPDATE AVAILABLE”: Clicking on the amp image will take you to the Update page: Click on “PERFORM UPDATE” and accept the terms and conditions. You will receive a message that your amp is restarting in Update Mode. When the update is successful, you will see a message like this: Click OK and you are complete! Anything else I should know? If you’d like to use the new factory presets, please follow these instructions to perform a factory reset…(Be sure to make a backup of any of your current presets in Catalyst Edit before performing the factory reset.) · Power down your Catalyst /Catalyst CX amplifier. · While holding the Channel “B” and “Manual” buttons, power your amplifier back on. That’s it – this will allow access to the new factory presets. Download the Catalyst Edit application from Line6.com if you haven’t already. Open the Editor. In the upper left corner, click and select BACKUP. This will create a backup of your current presets and settings. You can also just save INDIVIDUAL presets by selecting SAVE CURRENT PRESET TO FILE. This will allow you to load the presets individually. After the backup is complete, Power down your Catalyst amplifier, then “RESET” the amplifier by holding down the “Channel B” and “MANUAL” channel buttons while turning the power switch back on. This will load the NEW factory presets, including presets with the new amp voicings. You can of course then load your previous individual presets from your previous backup. I updated my firmware—now how do I access the six new amplifiers? There are two Amp Groups, each containing six Line 6 Amp Voicings—one each for the slots on the Selector. Group 1 are the six original Amp Voicings. Group 2 are the new Amp Voicings: Press both the CHANNEL SELECT CH A & CH B buttons together to toggle between Amp Groups. · The full LED SELECTOR RING flashes once to indicate you are selecting Amp Group 1 and twice for Amp Group 2. · Turn the SELECTOR encoder to load an Amp Voicing within the current Group. What if I want to use amps in both groups for my presets? NO problem! When you create and save your presets (either on the amp or within the editor), the amp will remember which amp the preset is created with. For example, you can create a preset in Bank 1 CH A using an amp from Group 1, and CH B using an amp from Group 2. What’s different about the Effects? While the original firmware let you combine any one effect (grouped into three Effect Categories) with a Reverb type in the independent Reverb section, 2.0 Firmware enables you to combine any two effects from any two of four Effect Categories. In other words, you can combine a Delay effect with a Modulation effect (but not two Delay effects or two Modulation effects), a Pitch/Filter effect with a Reverb effect, a Modulation effect with a Reverb effect, etc. - loaded into the EFFECT and REVERB locations. Use the EFFECT 1 and REVERB controls to load the two different effects: Press the EFFECT or REVERB button to enable the loaded effect. The current EFFECT category is indicated by the color of the button’s LED (Delay = GREEN, Modulation = BLUE, Pitch/Filter = PURPLE, Reverb = ORANGE). Press and hold the EFFECT or REVERB button for two seconds to enter Effect Selection Mode. The SELECTOR’s full LED RING will blink twice. TIP! Use the Catalyst Edit application to adjust “deeper” parameters such as Delay Time, Modulation Rate, etc. To change EFFECT models, turn the SELECTOR to select one of the six different effects available within the currently selected Effect Category (your selection is indicated by the illuminated LED RING segment). To select different Effect Categories, press the TAP button to scroll through the other available options. Press and release the EFFECT button to save the selected effect within your preset. The full LED RING will blink three times to indicate you are exiting Selection Mode. After exiting Effect Selection Mode, press and hold the CH A or CH B button to save your settings to that preset location, or save via the Catalyst Edit software. We’ve added some new visual cues that apply when you are doing things such as switching in and out of Effect Selection Mode. You can find the details in the updated Catalyst/Catalyst CX Pilot’s guide. KNOWN ISSUE (CATALYST EDIT only) Currently, there is an issue with disabling the Cab simulation on the direct output within Catalyst Edit. We encourage users to leave cab sim enabled on. The issue is being evaluated for update in a future release. New Amps in 2.0/2.01 CLEAN – Archetype Clean Mod. Based on* a modded version of the Paul Reed Smith Archon. “The Clean channel is rich and dimensional and stays clean to almost full volume. The versatility of the three-band EQ lets you dial in tones from across decades and genres.” —Ben Adrian, Sound Design Manager BOUTIQUE - Grammatico GSG. Based on* the Grammatico GSG100. "The Grammatico GSG100 is an amp created after a study of legendary amps built around 1980. This model aims to capture all of the unique details of the circuits in those amplifiers, many of which are quite different than those in popular guitar amps from the major companies. The GSG100 is a feature-rich and complicated amp.” —Ben Adrian, Sound Design Manager CHIME - Line 6 Elmsley. A Line 6 Original. "The Line 6 Elmsley is a Line 6 original amplifier that employs a parallel distortion topology that layers distinct saturation characteristics across the lower and upper registers. The Elmsley features a smooth and present bottom end with some exceptional sparkle and definition all through the midrange and above. The result is an amplifier that is dazzling across the full spectrum, and the amplifier plays very well with pedals. "A key feature of the Elmsley's power amp section is the Negative Feedback parameter (NFB)—utilized in the Boost function for Catalyst CX—where the amount of feedback within the power section's response can range from wild and unhinged to tight and punchy.” —Sam Hwang, Sound Designer CRUNCH - Brit 2204 MOD. Based on a custom-modded version of the classic Marshall JCM800. Turn to this Amp Voicing to conjure up tones of the coveted JCM 800, one of Marshall's most iconic amps. This updated version of the Plexi supplied the additional gain, and edge, sought by a new generation of rock guitarists. One of the biggest differences here is that the tone controls are located after the preamp tubes. DYNAMIC – Ventoux. A Line 6 Original. “This model comes from a physical amp idea I had a while back. I was originally going to build it as a tube amp, but there are only so many hours in a day. The idea was to create a ‘coveted boutique amp’ that had a different origin story. Most coveted boutique amps come from modified black-panel Fender or modified Marshall circuits. I wanted to do the same thing, but base it on the early-’70s Orange circuits and the mid-wattage ‘tweed’ circuits. “Ventoux has a unique topology. In an indirect way, every knob is kind of a gain/drive control. The tone controls adjust the character and/or amount of the overdrive in those frequencies. This might be seen as complicated by some, but I find it exciting and full of possibilities." —Ben Adrian, Sound Design Manager HI GAIN – Badonk. A Line 6 Original To create the Line 6 Badonk, the Big Bottom model from the XT code was rebuilt using new tools, so that the overall EQ and pre/post distortion filtering matched. The previous tone stack was a little limited, so it was tuned up to have more range and provide a realistic and interactive response. To make this model feel more like a full amp, the power amp from the Fatality model (Mesa Rectifier mod) was added then tweaked slightly to reinforce the overall EQ curve of the Big Bottom.” —Ben Adrian, Sound Design Manager *NOTE: All non-Line 6 original product names used in this document are trademarks of their respective owners and neither Yamaha Guitar Group nor Line 6 are associated or affiliated with them. These trademarks appear solely to identify products whose tones and sounds were studied by Line 6 during sound model development.
  23. A Catalyst may seem "dead" if a firmware update fails to complete itself. If the Catalyst fails to update: Power down the amp and close the Updater app. Open the Updater again, then power up the Catalyst while holding A and B to put the unit into bootloader mode. You will then need to manually select the correct Catalyst product from three choices presented by the Updater. Select the latest firmware version, then accept the Terms and Conditions. After the update is complete, power down your Catalyst amplifier, then “RESET” the amplifier by holding down the “B” and “MANUAL” channel buttons while turning the power switch back on.
  24. Nice work! As with anything else, this device/design is not officially endorsed or tested by YGG/Line 6, use at your own risk.
  25. Hey silverhead. This is not specific to your system. I was told that a user cannot update a Variax via a Helix, instead they must use an HD 500x or the VDI USB device. I was told Variax was never supported for updates via Helix. Nevertheless, we have a bug in for this.
