EdwinV Posted April 24, 2016 Share Posted April 24, 2016 Hi all, I'm really enjoying my Helix. I think it's a great sounding tool and super easy to use. Currently, I'm using firmware 1.10.0. During booting, I see the message "Rebuilding Preset 664" and "Rebuilding Preset 668". If I'm correct, this means preset 24 and 28 of setlist 6. These are presets I imported from Customtone. Is there a way to correct this, or should I just delete these presets? Thanks! Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 24, 2016 Share Posted April 24, 2016 Do those presets work? In my experience, if there's actually a corrupt preset, the Helix locks up when trying to go to them. If they work, perhaps just re-saving them might be all you need to do. Quote Link to comment Share on other sites More sharing options...
TLF2007 Posted April 24, 2016 Share Posted April 24, 2016 I actually have a whole bunch of presents that " rebuild" at startup. Why is that? Quote Link to comment Share on other sites More sharing options...
RRMark Posted April 24, 2016 Share Posted April 24, 2016 Me too, approx 448-490, then 735-780. Just from my memory, something like that. Everytime since the upgrade to 1.10 7th April, can't say I noticed anything before then. Have tried reset 10+11 'upgrade presets to latest format'. Everything seems to work ok though. Quote Link to comment Share on other sites More sharing options...
duncann Posted April 25, 2016 Share Posted April 25, 2016 I remember seeing something similar after several of the firmware updates. It happened to all of the presets immediately after the update and then once more after a power cycle for only some of the presets. Don't know which ones, but I think they were the ones I work on in a user setlist. I've also noticed it the next time I powered it on after rearranging things in a user setlist. Never had any problems associated with the rebuilding though. I just figured it's doing something it's supposed to be doing and kind of ignored it. Quote Link to comment Share on other sites More sharing options...
DoeWoe Posted April 25, 2016 Share Posted April 25, 2016 Mine does it too. Another user told me it happened to him until he reloaded his firmware and it went away. I reloaded mine, but it still happens. I'm just gonna hope it clears after the next install, if not, it's only a minor irritation. Quote Link to comment Share on other sites More sharing options...
Guitarzman Posted April 25, 2016 Share Posted April 25, 2016 Same I get the same message didn't think it was a big deal...I also did a re-instal still and got the same message! Quote Link to comment Share on other sites More sharing options...
spikey Posted April 25, 2016 Share Posted April 25, 2016 Be sure (its a duh thing) to back up (save) those presets outside of Helix, just incase they wind up in the bit bucket... Quote Link to comment Share on other sites More sharing options...
EdwinV Posted April 26, 2016 Author Share Posted April 26, 2016 Do those presets work? In my experience, if there's actually a corrupt preset, the Helix locks up when trying to go to them. If they work, perhaps just re-saving them might be all you need to do. Both presets work OK. I've re-saved them, but this does not solve the message during booting. I totally acknowledge that this is not a real problem, but was just wondering if this is normal behavior. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 26, 2016 Share Posted April 26, 2016 I think it's normal. It always happens after a firmware update, but even without updating I often see one or more presets being rebuilt when Helix powers up. Don't know why, or what circumstances trigger it, but it's never been a problem for me. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 26, 2016 Share Posted April 26, 2016 Both presets work OK. I've re-saved them, but this does not solve the message during booting. I totally acknowledge that this is not a real problem, but was just wondering if this is normal behavior. I think it's normal. It always happens after a firmware update, but even without updating I often see one or more presets being rebuilt when Helix powers up. Don't know why, or what circumstances trigger it, but it's never been a problem for me. Not sure if this is can really be classified as normal. It may have something to do with some parameter in a preset that requires updating by the current firmware but then does not stick after a power down. I suspect this will either be addressed in a future firmware update or at least someone will hopefully figure out what causes it. I wonder if this can be caused by restoring a preset that was not saved with the corresponding Helix app for a particular firmware release. I would think eventually the part of the preset causing the issue will be identified and updated and saved within the preset the first time so that it does not pop up again. Quote Link to comment Share on other sites More sharing options...
nippyjun Posted April 30, 2016 Share Posted April 30, 2016 I too started experiencing this for 265 and 267 after loading about 15 presets from the customtone page. Some of the patches had blank IR's and I thought that that was the issue. So I put in cabs in the place where the blank IR was. After that only 267 would rebuild each time. I re-ordered the newly added presets but that didn't fix the issue. I then re-saved all the presets I had added and that seems to have fixed the issue. I think just re-saving is what fixes this. Is anyone with this issue still having the issue after re-saving? Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 30, 2016 Share Posted April 30, 2016 Why this is an 'issue'? Everything operates fine - just takes a few more seconds to power up. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted April 30, 2016 Share Posted April 30, 2016 I get the rebuild a few times after an update but then it stops doing it and boots normal. Maybe a bum preset? The resaving then rebackup seems like good advice Quote Link to comment Share on other sites More sharing options...
spikey Posted April 30, 2016 Share Posted April 30, 2016 Why this is an 'issue'? Everything operates fine - just takes a few more seconds to power up. The only like example I can give is that Windows registry will still allow the OS to boot up too, until it gets "too" corrupted. In which case you must reformat the drive. If Helix gets too many presets to be rebuilt, is it possible it won't boot up as well? Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 1, 2016 Share Posted May 1, 2016 .... If Helix gets too many presets to be rebuilt, is it possible it won't boot up as well? Don't know for sure but I think it's unlikely. Helix rebuilds ALL presets after a firmware update, and also has a startup sequence that rebuilds all presets, so I can't see there ever being too many to rebuild. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 1, 2016 Share Posted May 1, 2016 Don't know for sure but I think it's unlikely. Helix rebuilds ALL presets after a firmware update, and also has a startup sequence that rebuilds all presets, so I can't see there ever being too many to rebuild. I see this as a very minor bug that probably/hopefully goes away at some point. Certainly an apparently incredibly inconsequential issue but one that they may figure out and eliminate at some point. Boot time is still excellent on the Helix IMHO. Quote Link to comment Share on other sites More sharing options...
Guitarmaniac64 Posted May 1, 2016 Share Posted May 1, 2016 I have rebuild nr 280-303 everytime not a problem for me Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted May 1, 2016 Share Posted May 1, 2016 I too started experiencing this for 265 and 267 after loading about 15 presets from the customtone page. Some of the patches had blank IR's and I thought that that was the issue. So I put in cabs in the place where the blank IR was. After that only 267 would rebuild each time. I re-ordered the newly added presets but that didn't fix the issue. I then re-saved all the presets I had added and that seems to have fixed the issue. I think just re-saving is what fixes this. Is anyone with this issue still having the issue after re-saving? If resaving the preset permanently eliminates the rebuild on reboot then perhaps the solution is, that in the next firmware version, have the rebuild process include a save of the affected preset. Quote Link to comment Share on other sites More sharing options...
deadlocked Posted May 2, 2016 Share Posted May 2, 2016 I was getting the same message on 996, 997, 998 and 999. I mapped the affected patches and all I did was to load each one and re-saved it without making any changes and now Helix loads up without rebuilding anything. Dunno what happened, but it started doing it after I upgraded the FW to 1.10 Quote Link to comment Share on other sites More sharing options...
pwik Posted May 3, 2016 Share Posted May 3, 2016 People actually look at the display during startup? I power on the Helix, go power up my amp, then my PA, grab a guitar and plug in. By that time the Helix and everything else is ready to go. ;) Quote Link to comment Share on other sites More sharing options...
klangmaler Posted May 11, 2016 Share Posted May 11, 2016 Even with FW 1.12 rebuilding messages... Why? What is being 'rebuild' during booting?! Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 12, 2016 Share Posted May 12, 2016 Even with FW 1.12 rebuilding messages... Why? What is being 'rebuild' during booting?! I think that any preset (except any empty or 'New Preset') that hasn't previously been saved with the current firmware is rebuilt on each startup. For instance, immediately after a firmware update the factory setlists are automatically rebuilt. I believe the next startup will rebuild any existing user setlists. After that, anytime you load a new user setlist all its presets that were not saved before powering off are candidates for rebuild on the next startup, and so on. Importing a Customtone download will cause it to be rebuilt next startup if not saved. Explicitly saving a preset removes it from the rebuild candidate list. But that's just my theory based on observation...... it could be wrong. I suppose that theory could be tested if anyone is so inclined. Rebuilding does no harm as far as I can tell. Quote Link to comment Share on other sites More sharing options...
klangmaler Posted May 12, 2016 Share Posted May 12, 2016 [...] But that's just my theory based on observation...... it could be wrong. [...] Thank you for your theory ;) ... I would really like to read a more official statement coming from DI or L6 - these rebuilding remarks are slightly beginning to make me sceptical... :angry: Quote Link to comment Share on other sites More sharing options...
