Triryche Posted August 16, 2017 Share Posted August 16, 2017 Any clues as to what is going - see attached pix Click on the Helix log in the plug-in (at the bottom) to authorize your license. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 oh boy.. I guess I should post this in native forums, anyway Reaper64 crashed both vst2 and vst3, jBridger won't work, savihost64 crashed right after authorization... (windows 8.1 x64) What version of Reaper? Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 16, 2017 Share Posted August 16, 2017 (edited) On 8/16/2017 at 1:50 PM, Triryche said: Click on the Helix log in the plug-in (at the bottom) to authorize your license. Ermm - well that was the very first thing I did after installing the plug-in. It authorizes Native for me (datacommando) but only as a Trial Version. Oh, yeah! I have done a Deauthorize etc. no change! see pic. Edited March 14, 2019 by datacommando Pic removed to free up space! Quote Link to comment Share on other sites More sharing options...
yannfoubert Posted August 16, 2017 Share Posted August 16, 2017 I am lost. It's the first time I use a plugin. Just bought Native plugin. Now Could someone explain me how to use it in GarageBand? Thanks. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 @datacommando Maybe the servers are stressing. Have you tried signing out, closing your DAW and sign back in? Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 I am lost. It's the first time I use a plugin. Just bought Native plugin. Now Could someone explain me how to use it in GarageBand? Thanks. http://line6.com/support/manuals/helix-native Quote Link to comment Share on other sites More sharing options...
bradlake Posted August 16, 2017 Share Posted August 16, 2017 So far so good on my MacBook Pro, no glitches on install and authorization, imported a Fremen bank and some IRs, guess now I gotta work on gain staging, since my Helix is in my other residence out of state, I am inputting thru a HI-Z Unison input on my UAD Apollo. latency is there, but hardly noticeable at a 48000, 64 setting in Logic. Anybody else’s using a similar setup? Quote Link to comment Share on other sites More sharing options...
requietus666 Posted August 16, 2017 Share Posted August 16, 2017 What version of Reaper? it's 5.4 also, the TriplePlay 64 doesn't recognize HelixNative64.dll being a plugin Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2017 Share Posted August 16, 2017 Hmm... I've been using Native in Reaper ever since the beta began, and have never had it crash. I'm using Windows 10, though. When does it crash? When you try inserting it as an effect? Quote Link to comment Share on other sites More sharing options...
bradlake Posted August 16, 2017 Share Posted August 16, 2017 also a little surprised that there are no stock presets loaded on install...Did I miss a step? (Not that I really need em...) Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2017 Share Posted August 16, 2017 also a little surprised that there are no stock presets loaded on install...Did I miss a step? (Not that I really need em...) There are factory presets that should load in the Factory 1 and Factory 2 setlists. If for some reason they didn't load, click on the Helix Native logo at the bottom of the GUI to get to the global settings menu. There's a button there that says "Reload Factory Setlists". That should get them to show up. 1 Quote Link to comment Share on other sites More sharing options...
requietus666 Posted August 16, 2017 Share Posted August 16, 2017 reaper64 and tripleplay64 crash immediately after inserting an dll on fx savihost64 crashes right after showing an info box about trial period, see scrn Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2017 Share Posted August 16, 2017 reaper64 and tripleplay64 crash immediately after inserting an dll on fx savihost64 crashes right after showing an info box about trial period, see scrn I'm wondering if the fact that you installed both the VST2 and VST3 versions might not be causing a problem. Technically, it shouldn't matter, but it might be worth uninstalling one of them. I have only ever used the VST3 version in Reaper. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 it's 5.4 also, the TriplePlay 64 doesn't recognize HelixNative64.dll being a plugin Assuming you already tried after a fresh reboot, I would definitely open a support ticket, Are you launching Triple Play in 64bit mode? Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 I'm wondering if the fact that you installed both the VST2 and VST3 versions might not be causing a problem. Technically, it shouldn't matter, but it might be worth uninstalling one of them. I have only ever used the VST3 version in Reaper. Nice catch, from the manual: *NOTE: If your host DAW application supports VST3, it is recommended that you do not also install the older VST2 format. Quote Link to comment Share on other sites More sharing options...
bradlake Posted August 16, 2017 Share Posted August 16, 2017 There are factory presets that should load in the Factory 1 and Factory 2 setlists. If for some reason they didn't load, click on the Helix Native logo at the bottom of the GUI to get to the global settings menu. There's a button there that says "Reload Factory Setlists". That should get them to show up. that did the trick, thanks! BTW, the stock presets sound super!...also good news for users of the excellent Midi Guitar 2 app, Native loads up fine inside it, both as AU and VST 3 on my MacBook, a great way to use it without having to load up a DAW, and latency appears to be less noticeable than in Logic in my initial noodling...check it out .. http://www.jamorigin.com Quote Link to comment Share on other sites More sharing options...
gbbaker Posted August 16, 2017 Share Posted August 16, 2017 Loaded Native this AM on Windows 7 64 using Latest Reaper 64 and all is VERY GOOD. ONLY use VST3. For those confused on Authorization there are two boxes - the top to "Buy" and the bottom to 'Try Trial Version". If you have already purchased just click the "Trial Version Box" and the top button will change to "Authorize". Follow the "bouncing ball" and all should load. Make SURE if you are taking advantage of any discounts that your other Line6 items are Registered. Just using the Line6Updater DOES NOT register your products. Now . . . . back to my new toy! 1 Quote Link to comment Share on other sites More sharing options...
pelaomedinaese Posted August 16, 2017 Share Posted August 16, 2017 in reaper 5 it's working really fine Quote Link to comment Share on other sites More sharing options...
bradlake Posted August 16, 2017 Share Posted August 16, 2017 Assuming you already tried after a fresh reboot, I would definitely open a support ticket, Are you launching Triple Play in 64bit mode? Assuming you already tried after a fresh reboot, I would definitely open a support ticket, Are you launching Triple Play in 64bit mode? Sadly, I can confirm that Native will not load into 64-bit Tripleplay on my Mac. but as I said earlier, it works great in the MIDI Guitar app.......... Quote Link to comment Share on other sites More sharing options...
bigtony47 Posted August 16, 2017 Share Posted August 16, 2017 Just running this on Windows 7, I7 laptop, in Reaper v 5 (64) - sounds nice but I have lots of latency, unplayable. where can i fix this? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 16, 2017 Share Posted August 16, 2017 Just running this on Windows 7, I7 laptop, in Reaper v 5 (64) - sounds nice but I have lots of latency, unplayable. where can i fix this? If you go under Preferences>Audio Device in Reaper, there's a button that says ASIO Settings or something like that. That should open up the dialog box for your interface. Basically latency is a function of your interface, and each one behaves differently depending on its driver. You need to mess with the buffer settings. Some interfaces give you a choice of latency options such as "safe", "reliable", etc. What interface are you using? Quote Link to comment Share on other sites More sharing options...
Hedon09 Posted August 16, 2017 Share Posted August 16, 2017 Ermm - well that was the very first thing I did after installing the plug-in. It authorizes Native for me (datacommando) but only as a Trial Version. Oh, yeah! I have done a Deauthorize etc. no change! see pic. same problem here....purchased native, logged into my line6-account via native plugin. native only shows a trial activation. authorization/de-authorization didn't change that Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 same problem here....purchased native, logged into my line6-account via native plugin. native only shows a trial activation. authorization/de-authorization didn't change that It is a temporary situation. Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 16, 2017 Share Posted August 16, 2017 same problem here....purchased native, logged into my line6-account via native plugin. native only shows a trial activation. authorization/de-authorization didn't change that Hi Hedon09, Triryche, Line 6 Expert is looking into it. He thinks it may have been a glitch in the servers, as you may have noticed they went offline for a little while. One thing that I spotted was – my purchase history shows both the Helix Native Trial and the Native for Helix Owners in the items column. it looks like the full version requires activation, but I'm baffled as to how to do that. If I try to do it through the plug-in it just takes me back to the Store front! Oh yeah, plus I did a full uninstall, restart and re-install, but still the same. Quote Link to comment Share on other sites More sharing options...
bradlake Posted August 16, 2017 Share Posted August 16, 2017 It is a temporary situation. good, cause its happened to me as well Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 Just running this on Windows 7, I7 laptop, in Reaper v 5 (64) - sounds nice but I have lots of latency, unplayable. where can i fix this? If you go under Preferences>Audio Device in Reaper, there's a button that says ASIO Settings or something like that. That should open up the dialog box for your interface. Basically latency is a function of your interface, and each one behaves differently depending on its driver. You need to mess with the buffer settings. Some interfaces give you a choice of latency options such as "safe", "reliable", etc. What interface are you using? Also, if you are monitoring the plug-in in real time the latency is also a function of your DAW and computer. And be sure to select your device's ASIO drivers in your DAW. Quote Link to comment Share on other sites More sharing options...
Hedon09 Posted August 16, 2017 Share Posted August 16, 2017 Hi Hedon09, Triryche, Line 6 Expert is looking into it. He thinks it may have been a glitch in the servers, as you may have noticed they went offline for a little while. One thing that I spotted was – my purchase history shows both the Helix Native Trial and the Native for Helix Owners in the items column. it looks like the full version requires activation, but I'm baffled as to how to do that. If I try to do it through the plug-in it just takes me back to the Store front! Oh yeah, plus I did a full uninstall, restart and re-install, but still the same. thx for the info data, since triryche said it's a temporary situation i will just keep calm and wait for a solution to show up. 15 days left until i start to worry :-) oh and by the way, i too have both the native and the native trial version in the coloumn of my purchase history. 1 Quote Link to comment Share on other sites More sharing options...
bigtony47 Posted August 16, 2017 Share Posted August 16, 2017 If you go under Preferences>Audio Device in Reaper, there's a button that says ASIO Settings or something like that. That should open up the dialog box for your interface. Basically latency is a function of your interface, and each one behaves differently depending on its driver. You need to mess with the buffer settings. Some interfaces give you a choice of latency options such as "safe", "reliable", etc. What interface are you using? I was trying to see if it would work with the Rocksmith USB cable - but that seems a tad flaky in Reaper. Everytime i try and select anything except the Microsoft Sound Mapper i lose all sound. EDIT: After more fiddling I have got it to work with the RS cable - but I still have some latency. Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 I was trying to see if it would work with the Rocksmith USB cable - but that seems a tad flaky in Reaper. Everytime i try and select anything except the Microsoft Sound Mapper i lose all sound. EDIT: After more fiddling I have got it to work with the RS cable - but I still have some latency. Yeah, RS is not an ASIO device. Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 16, 2017 Share Posted August 16, 2017 Re: Helix Native. Spikey ain't gonna be happy when he finds there is no tuner in the plug-in software! Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted August 16, 2017 Share Posted August 16, 2017 It's not Nintendo but........ Atari, even better! Quote Link to comment Share on other sites More sharing options...
alexqhuffman Posted August 16, 2017 Share Posted August 16, 2017 Just downloaded the Helix Native plugin demo...went to try it and was asked to sign in to my Line6.com account. I've tried 20 times now to sign in and it is not working. I double checked and even reset my password just in case...still no access to the plugin. Logging in to Line6.com with the same info is working without a problem. Anyone else having this issue? 2 Quote Link to comment Share on other sites More sharing options...
klangmaler Posted August 16, 2017 Share Posted August 16, 2017 First impression: No probs (installation, authorizing, integration in DAW) Is it right, that Helix has to be connected contantly to the internet (copy protection)? Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 Not if you own the full license. Quote Link to comment Share on other sites More sharing options...
hasseg1 Posted August 16, 2017 Share Posted August 16, 2017 Where are the presets? Best, Hans 1 Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 Click the Helix logo and restore factory setlists. Quote Link to comment Share on other sites More sharing options...
jabak Posted August 16, 2017 Share Posted August 16, 2017 I've added native to the shopping cart but no discount is added. I have registered my helix to my account a looong time ago. How to get my discount? Quote Link to comment Share on other sites More sharing options...
Triryche Posted August 16, 2017 Share Posted August 16, 2017 I've added native to the shopping cart but no discount is added. I have registered my helix to my account a looong time ago. How to get my discount? There should be five variants in your cart. Quote Link to comment Share on other sites More sharing options...
IDent Posted August 16, 2017 Share Posted August 16, 2017 Just downloaded the Helix Native plugin demo...went to try it and was asked to sign in to my Line6.com account. I've tried 20 times now to sign in and it is not working. I double checked and even reset my password just in case...still no access to the plugin. Logging in to Line6.com with the same info is working without a problem. Anyone else having this issue? same problem on Win10 64 and Cubase9. And my friend with Mac is also having problems - insert effect is not even active ((( Quote Link to comment Share on other sites More sharing options...
fanthomaz Posted August 16, 2017 Share Posted August 16, 2017 Hi guys, Just bought my license, 99 bucks because I own a hardware version, cool pricing! But sadly I dont manage to get it thru the AU validation process on logic 10.2.2 Anyone having similar problems? Quote Link to comment Share on other sites More sharing options...
