edstar1960 Posted March 22, 2015 Author Share Posted March 22, 2015 Medical grade just means $$. They have to be tested for leakage to ground and other things. You do not need Medical Grade for a Pod. The link that spaceatl shared above shows a medical grade PSU for just $14.80. The Line 6 DC-3G is $40. So in this case at least it seems to be the other way around. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted March 23, 2015 Author Share Posted March 23, 2015 @edstar1960 - I am wondering if you being in the UK on 240 might be running your PSU near the top of its input range could be contributing to the heat....Only thing I could think of that might be different for you and me...I have been running mine on regulated 120v... I also use a JTV connected via VDI to my HD500. It occurred to me that's the reason why the HD500 needs to have a 3A power supply - it has to be capable of powering a variax as well. I wonder if that also contributes to the extra heat - more power being drawn from the supply by both the HD500 and the JTV. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 23, 2015 Share Posted March 23, 2015 The Line 6 DC-3g power supply says it's 9V and 3A and the connector has a negative centre. The specs can be found here: http://line6.com/support/page/kb/_/general-faq/power-supply-amp-power-and-battery-faq-r445 Specifically: DC-3g: (POD HD 300/400/500 and HD Bean): 9V DC, 3A (3000mA) Plug length: 15mm, Diameter: 5mm, Center Pin: 2mm. Well I just purchased and received this 6 ft 2.1mm x 5.5mm DC Plug Extension Cable for Power Adapter, 20AWG http://www.amazon.com/gp/product/B00FTH6WNS/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1 It DOESN"T fit. It seems like 2.1mm is too small. Anyone have any experience with this? The power supply fits on the female end of this adapter but the male end's center pin hole is too small for the unit. Which doesn't make sense given Line 6's dimension of 2mm. If anything it should be a little loose. Is there a 2.5mm available? Has anyone tried it and does it fit? Quote Link to comment Share on other sites More sharing options...
sgierling Posted March 26, 2015 Share Posted March 26, 2015 I lug my HD500 out every weekend for 4 years and I'm on my 3rd power supply. I found a third party one on amazon that worked for awhile then crapped out. I'd recommend OEM if you can find it cheap. Having said that here's an alternative for $30 http://www.amazon.com/UpBright%C2%AE-Power-Supply-Adapter-Charger/dp/B00KBFW4XA/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1427344866&sr=1-1-catcorr&keywords=line6+DC-3g+power+supply Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted March 26, 2015 Author Share Posted March 26, 2015 I lug my HD500 out every weekend for 4 years and I'm on my 3rd power supply. I found a third party one on amazon that worked for awhile then crapped out. I'd recommend OEM if you can find it cheap. Having said that here's an alternative for $30 http://www.amazon.com/UpBright%C2%AE-Power-Supply-Adapter-Charger/dp/B00KBFW4XA/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1427344866&sr=1-1-catcorr&keywords=line6+DC-3g+power+supply Thanks for the info. Just out of interest - did your power supplies just fail for some reason or did they fall apart on their own or did they get broken because someone trod on them or some equipment fell on them - or some other reason? Just would like to know if they failed due to being fragile or due to cheap internal electrical components that don't last. Thanks. Quote Link to comment Share on other sites More sharing options...
sgierling Posted March 26, 2015 Share Posted March 26, 2015 Original OEM housing came apart. The third party one just fizzled out electronically. No abuse for either. Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted March 26, 2015 Share Posted March 26, 2015 If you click on the amazon link and look at "what others searched for" you'll find these as well: http://www.amazon.com/HD500-effects-replacement-supply-adaptor/dp/B00GQWSRXS/ They're running around $18 but are only 2.5A, although users have apparently been using it with the HD500 w/o any issues. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted March 27, 2015 Share Posted March 27, 2015 I don't have evidence of this, but I would expect that 2.5A is plenty if the HD500 is not also providing power to a JTV Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 27, 2015 Share Posted March 27, 2015 So I recently purchased a power cable extender and right angle adapter using the parameters supplied by Line 6. THEY ARE WRONG!!!!!! The pin is stated to be 2mm. IT IS NOT!!!. I purchased an adapter that was 2.1mm and it should have fit with room to spare but it doesn't. I just got an adapter with a pin of 2.5mm. That works. So BE CAREFUL!!! What I am specifically refering to is the pin in the HD500 itself. The power supply does fit into the extender and right angle adapter but neither of those will fit into the HD500 (or 500X) I reiterate. THE LINE 6 POWER SUPPLY PARAMETERS ARE WRONG. THE PIN IS 2.5 MM NOT 2.0 MM. LINE 6....YOU OWE ME $20!!!! ;) Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 27, 2015 Share Posted March 27, 2015 I generally have gone with Medical Grade 9VDC Supplies for pedal boards and such....They generally have a nice wide input range and are well regulated (Better than any OEM supply)... HD being 9VDC makes this pretty simple...I have two supplies at the moment, but I will go with a 4A medical when the time comes... http://www.trcelectronics.com/View/Mean-Well/GSM36B09-P1J.shtml THE LINE 6 PARAMETERS ARE WRONG. THIS WON'T FIT. The pin is too small. You need one with a 2.5 mm pin. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted March 27, 2015 Share Posted March 27, 2015 So since the plug parameters are wrong (DOOOHHHH!!!) I can only find a power supply that's 12 volts and 6.7 amps. I know I can use a power supply that can provide more amps than the HD500's power supply. Does the same apply in regard to volts? Can I use a 12 volt power supply for something that only needs 9 volts? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted March 27, 2015 Share Posted March 27, 2015 I know I can use a power supply that can provide more amps than the HD500's power supply. Does the same apply in regard to volts? Can I use a 12 volt power supply for something that only needs 9 volts? I'm no electrician, but it seems like a rather risky $500 bet. If it never mattered, then why bother putting the specs on there? Everything would have the same power supply. Quote Link to comment Share on other sites More sharing options...
duncann Posted March 27, 2015 Share Posted March 27, 2015 So since the plug parameters are wrong (DOOOHHHH!!!) I can only find a power supply that's 12 volts and 6.7 amps. I know I can use a power supply that can provide more amps than the HD500's power supply. Does the same apply in regard to volts? Can I use a 12 volt power supply for something that only needs 9 volts? No. The only feasible way would be to take the output of the 12 volt supply and make it 9 volts with externally added circuitry. The pod wouldn't be very happy with 12 volts. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted March 27, 2015 Share Posted March 27, 2015 A resistor and a 9V Zenor Diode would probably do it in a quick and dirty way....A DC regulator would be better...ans a decent all in one package will cost half as much a new 9VDC....Here's a 5 amp one... http://www.amazon.com/Vktech-Converter-Regulator-Power-Module/dp/B00ESYUF9K Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted March 28, 2015 Share Posted March 28, 2015 And just to provide another item that may be of interest, if you need a right angle adapter for the power plug, this one works great: http://www.amazon.com/BiXPower-LC53-Right-Connector-Converter/dp/B004L74PGI/. Quote Link to comment Share on other sites More sharing options...
runestro Posted May 1, 2015 Share Posted May 1, 2015 If you are in the UK: http://www.gear4music.com/Books-DVD-and-Sheet-Music/Line-6-UK-DC-3G-Power-Supply-for-POD-Series/MZB :) Quote Link to comment Share on other sites More sharing options...
robbieb61 Posted May 1, 2015 Share Posted May 1, 2015 Will this one work: http://www.amazon.com/Power-Adapter-2-1mm-Regulated-Supply/dp/B006QZ7RG8 Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted May 1, 2015 Author Share Posted May 1, 2015 Will this one work: http://www.amazon.com/Power-Adapter-2-1mm-Regulated-Supply/dp/B006QZ7RG8 It has to have a negative centre and that one has a positive centre - not sure how easy it is to swap the centre from positive to negative or even if its possible with these pre-made units. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted May 1, 2015 Share Posted May 1, 2015 Swapping the center is usually just a matter of cutting the cable and splicing it back together with the leads swapped. Double - make that Triple check the polarity before you plug it into your Pod. Quote Link to comment Share on other sites More sharing options...
stuvr Posted November 2, 2016 Share Posted November 2, 2016 https://www.amazon.co.uk/HD500X-Multi-effects-replacement-supply-adaptor/dp/B00GC4DX8E Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 2, 2016 Share Posted November 2, 2016 https://www.amazon.co.uk/HD500X-Multi-effects-replacement-supply-adaptor/dp/B00GC4DX8E If anyone sees this where you can order it in America with an "American" plug, refresh this thread and put it here. Please. Quote Link to comment Share on other sites More sharing options...
BillBee Posted November 2, 2016 Share Posted November 2, 2016 No one likes to hear that their "power barrel is too narrow". :D Quote Link to comment Share on other sites More sharing options...
Phil6_7 Posted November 2, 2016 Share Posted November 2, 2016 I tried to buy a replacement as I hate the way the official one falls apart so easily. It may be the same one linked above, I can't remember. But be warned mine came with an adaptor to go from 2.1 to 2.5mm and also reversed the polarity of the psu so it was correct for the pod. Not what I had in mind as this adapted can also unattach itself easily. It also wasn't the full spec current wise. It does work though. Quote Link to comment Share on other sites More sharing options...
FlyingSquirrel Posted November 3, 2016 Share Posted November 3, 2016 I had similar questions a few months back. Here's what I found. http://line6.com/support/topic/19997-anybody-using-any-one-spot-products-with-their-hd500x/page-1#entry156510 http://line6.com/support/topic/19997-anybody-using-any-one-spot-products-with-their-hd500x/page-1?do=findComment&comment=150788 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 3, 2016 Share Posted November 3, 2016 I just found this. Plug specs are correct but I don't know if the center is + or -. Haven't tried it yet https://www.savingology.com/ProductDetails.asp?ProductCode=3000mA-Adapter-Charger-EGR&click=2&gclid=CLeDwJ3PjNACFQpahgodXbcJfw Quote Link to comment Share on other sites More sharing options...
mamalov Posted April 22, 2017 Share Posted April 22, 2017 Like "bjnette" said, look at back of your pod supply, you should see voltage, amps and polarity (normal is centered). For example, if your power suply have 12 volts and 2,7 amps. You don´t have any problem buy one with more amps, like 12 volts and 3 amps, only don´t buy with less amps. What If the device says 9v and the adapter I have is 12 v ? The amps match though. thanks Quote Link to comment Share on other sites More sharing options...
jeffjob Posted May 5, 2017 Share Posted May 5, 2017 I purchased a used HD500X, and having received it with the incorrect power supply (a PX-2g for which I got a credit back), I looked around for a cheaper suitable replacement. Didn't find one that I felt good about, and didn't want to have any issues with my POD, so I bit the bullet and picked up the correct Line 6 PS locally. Quote Link to comment Share on other sites More sharing options...
JTSC777 Posted May 8, 2017 Share Posted May 8, 2017 My Boss ME70 goes out to work with me 9-10 times for this reason.I can power the Boss with one of prolly 20 9'volt One Spot adapters I have piles of. If the HD500 gets broken or croaks at a gig I am " Lollipopped".Possibly even "Fudgesicled". The power supply thing with the HD is like Apples proprietary cable "Lolly Gagging" . Its all a big Cluster Lollipoop poopy doopy dooper. So I use what will make me my money without having to have stupid expensive extra Lolli-n-pop Line 6 power supplies with me . Quote Link to comment Share on other sites More sharing options...
VAX700 Posted January 8, 2018 Share Posted January 8, 2018 Here's the thing with power supplies: volts and polarity have to match; amps can be slightly over. Electronic devices only draw the amps they require... so plugging a 5000mA power block into a 3000mA unit won't harm it. However, a 2000mA power supply won't provide enough current for the device to work properly. Running a 12V supply into a 9V unit is potentially harmful... it can overpower the device and blow components/circuits. With AC, polarity isn't an issue... but with DC, polarity has to match or the device won't work, and components/circuits could potentially be damaged. The HD500 power supply converts 120V or 240V AC to 9V DC with centre pin + polarity, while supplying 3000mA. So a 9V, 5000mA centre pin + power supply would work just as well. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 8, 2018 Share Posted January 8, 2018 We aren't talking about the price difference between a $12,000 Gibson and a $800 Gibson. We are talking about a $25 device. I mean, sure, the Pod isn't going to know where the power is coming from. But think about it - if someone is so "beginner" that they need to come here asking if a device will work, or if they need an explanation as to how power supplies work... they shouldn't be buying anything other than the official device. Quote Link to comment Share on other sites More sharing options...
Poul_Ciok Posted October 21, 2018 Share Posted October 21, 2018 Hi, For all of you wondering or guessing what the actual current draw is of the different new Line 6 product is I have attached a few pictures showing the actual measurement of 4 different setups. POD HD500X: max. 1.1A = 1100mA POD HD500X + FBV3: max. 1.3A = 1300mA Firehawk FX: max. 0.8A = 800mA HX Effects: max. 1.1A = 1100mA I'm waiting to get my hands on the HD Stomp to also be able to publish the actual measured current draw of that unit. All the above can be safely and correctly powered of two outlets of the new CIOKS DC7 power supply where each outlet has a rating of 660mA at 9V DC. Using two outlets in a parallel configuration gives you a 1320mA or 1.3A source at 9V DC which is sufficient. To get the plug polarity and size right you should use the #8800 Parallel adapter Flex followed by the yellow #3050 Flex cable with a 5.5/2.5 centre negative DC plug. When two of DC7's outlets are used to power one of the above the Line 6 units you still have 5 isolated outlets for pedals left each with a 660mA current rating plus a 5V USB outlet at 1A and a 24V auxiliary outlet to expand the DC7 with CIOKS 4 or CIOKS 8 to add more isolated outlets if desired. Quote Link to comment Share on other sites More sharing options...
Poul_Ciok Posted January 19, 2019 Share Posted January 19, 2019 Here you go, now with a video: Quote Link to comment Share on other sites More sharing options...
Poul_Ciok Posted January 20, 2019 Share Posted January 20, 2019 Possibly you might be right. But With the old DL4 and other from the same range Line 6 stated 1200mA at 9V AC and that figure had nothing at all to do with the actual current consumption. It was just the figure that was stated on the original adapter. And the DL4 was not able to power anything else than itself. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 20, 2019 Share Posted January 20, 2019 On 1/8/2018 at 7:10 AM, pianoguyy said: We aren't talking about the price difference between a $12,000 Gibson and a $800 Gibson. We are talking about a $25 device. I mean, sure, the Pod isn't going to know where the power is coming from. But think about it - if someone is so "beginner" that they need to come here asking if a device will work, or if they need an explanation as to how power supplies work... they shouldn't be buying anything other than the official device. Quote Link to comment Share on other sites More sharing options...
SiCantwell Posted April 17, 2019 Share Posted April 17, 2019 Good thread. This is 4 amp, looks like it would work. $16.64 from Amazon, free 2-day shipping with Prime. 9V 3A 4A 5A AC DC Adapter 27W 36W 45W Switching Power Supply (9V4A-USCABLE) https://www.amazon.com/dp/B0771LX649/ref=cm_sw_r_sms_tai_oVZTCbWW8VMFB Quote Link to comment Share on other sites More sharing options...
brokenbones Posted April 17, 2019 Share Posted April 17, 2019 Keep us posted if that power supply does work. I'm getting ready to mount the POD on a pedalboard and that power supply from Amazon would be much easier to conceal underneath. I haven't watch Poul Ciok's videos yet but does he just test them while they're simply turned on or does he do any real load testing? I wonder how much current draw would come from full use of all set lists, dual amp patches, and many effects on each patch? Quote Link to comment Share on other sites More sharing options...
blekenbleu Posted April 19, 2019 Share Posted April 19, 2019 This $17 power supply is advertised at Amazon for HD500 etc https://www.amazon.com/dp/B0154WFJDG Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 21, 2019 Share Posted April 21, 2019 On 1/8/2018 at 7:10 AM, pianoguyy said: We aren't talking about the price difference between a $12,000 Gibson and a $800 Gibson. We are talking about a $25 device. Quote Link to comment Share on other sites More sharing options...
blekenbleu Posted April 21, 2019 Share Posted April 21, 2019 On 1/7/2018 at 8:44 PM, VAX700 said: With AC, polarity isn't an issue... but with DC, polarity has to match or the device won't work, and components/circuits could potentially be damaged. The HD500 power supply converts 120V or 240V AC to 9V DC with centre pin + polarity, while supplying 3000mA. So a 9V, 5000mA centre pin + power supply would work just as well. While VAX700 was correct about DC polarity being critical, he was incorrect about HD500, which (2.5mm) center pin requires negative 9VDC.. Quote Link to comment Share on other sites More sharing options...
