toobhed Posted November 2, 2018 Share Posted November 2, 2018 I sometimes plug in the 1/4 output to my tuner without disconnecting the VDI, so while I am tuning, both outputs are active. I read in another thread this could potentially overload the circuit and could damage the board. Any truth to this? (JTV-59) Quote Link to comment Share on other sites More sharing options...
silverhead Posted November 2, 2018 Share Posted November 2, 2018 Yes there must be some truth to it since it has been stated repeatedly by Line 6. Having said that I am not personally aware of any user actually having had problems traced to this. Nonetheless I don't think you want to be the first. :-) Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 2, 2018 Share Posted November 2, 2018 One more, yes it is true. Do NOT have both things plugged in at the same time. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 5, 2018 Share Posted November 5, 2018 Correct,... don't do that. Had a few main board and jack plate circuits come back damaged. Traced it to current/load problem, which resulted from running both at the same time time. Quote Link to comment Share on other sites More sharing options...
jerseyboy Posted November 7, 2018 Share Posted November 7, 2018 Can verify mag pup audio is somewhat out of phase between 1/4" phono and VDI-Helix. Didn't compare model output waveforms as 'was "snooping" something else. Little point in doing this with potential DC circuit damage. I get the use of a tuner but just get a good clamp on.... Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 7, 2018 Share Posted November 7, 2018 Reminder,... be sure that it's a TRS (tip/ring/sleeve)1/4" cable and not TS (tip/sleeve) cable, when using the 1/4" Phone output. It's an active, not passive circuitry, so must bear in mind the TRS, where tip= signal, ring= DC volts, and sleeve= return. Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted November 7, 2018 Share Posted November 7, 2018 8 minutes ago, psarkissian said: Reminder,... be sure that it's a TRS (tip/ring/sleeve)1/4" cable and not TS (tip/sleeve) cable, when using the 1/4" Phone output. It's an active, not passive circuitry, so must bear in mind the TRS, where tip= signal, ring= DC volts, and sleeve= return. Wait, excuse me if I'm dumb ('cause I often am) but what are you referring to in the above? Are you referring to the simple act of plugging a standard guitar cable into the analog output of the Variax? Are we supposed to make sure it's a TRS cable? Because the handbook simply says "standard" guitar cable here. Is there a risk to the unit? Hopefully I'm off on I90 and didn't realize what you're referring to. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 7, 2018 Share Posted November 7, 2018 Risk to the unit? More like efficiency and performance of the guitar. Over time it can put stress on the circuit with current flow, by draining battery quicker. Been like that since the old Variax, and standard way of doing guitars with active circuits since at least the mid 1970's. Something to aware of with active guitar circuits. 2 Quote Link to comment Share on other sites More sharing options...
Kilrahi Posted November 7, 2018 Share Posted November 7, 2018 4 minutes ago, psarkissian said: Risk to the unit? More like efficiency and performance of the guitar. Over time it can put stress on the circuit with current flow, by draining battery quicker. Been like that since the old Variax, and standard way of doing guitars with active circuits since at least the mid 1970's. Something to aware of with active guitar circuits. Cool. Thanks for the reply and explanation. I've never had an active circuit guitar until the Variax, and had no idea there was an advantage to a TRS cable. It looks like I'll be heading off to my local music store . . . Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 7, 2018 Share Posted November 7, 2018 There are some good cables out there for that. Know about the active circuit stuff because I and the bass player for the band Iron Butterfly used to be among the circuit geeks of the day, who used to build and do those mods back in the mid to late 1970's. That TRS configuration eventually became the norm. 1 Quote Link to comment Share on other sites More sharing options...
brue58ski Posted November 12, 2018 Share Posted November 12, 2018 On 11/7/2018 at 10:06 AM, psarkissian said: There are some good cables out there for that. Know about the active circuit stuff because I and the bass player for the band Iron Butterfly used to be among the circuit geeks of the day, who used to build and do those mods back in the mid to late 1970's. That TRS configuration eventually became the norm. Just a side note. I have a Vetta amp head that I was looking for a Line 6 FBV footcontroller pedal for. I had the small one and a friend of mine was looking for one of those but I was looking for the big one. I told him if he ever came across a full size one to buy it and I would trade him. So he finds a full size one and goes to the guys house to get it. He said the room he was led into had black light posters, a lava lamp, beads in the doorways, etc. and it turned out the guy had just gotten done touring with Iron Butterfly with his Vetta. I still have that footcontroller. I'm pretty sure his name was Charlie Marinkovich. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 14, 2018 Share Posted November 14, 2018 Cool. Met Charlie a couple of times. The present IB line-up, I've come to know Dave Meros (Spock's Beard), drummer Ray Weston and known guitar player Erik Barnett for sometime now. I still hang with drummer Ron Bushy and his wife, we all go back a long ways. Quote Link to comment Share on other sites More sharing options...
yelldog Posted November 23, 2018 Share Posted November 23, 2018 I did it for 4 years, never had a problem. That said, I was probably just lucky. I don't do anymore since it was brought to my attention. Quote Link to comment Share on other sites More sharing options...
soundog Posted November 29, 2018 Share Posted November 29, 2018 When I customize my Standard using Workbench HD, I run an RJ-45 ethernet cable to the USB dongle (to computer), and a TRS 1/4" from Variax to my Variax power A/B unit (for Variax power), then a 1/4" guitar cable from the A/B box to to an amp (for monitoring while customizing). Isn't that bona fide and kosher? Or will things eventually explode? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted November 29, 2018 Share Posted November 29, 2018 Using both connectors while using Monkey (for updates, the battery engage to give two green LED's) or Workbench is in a programming state, shouldn't be a problem. It's in the audio operations of playing that can add stress to the circuit. 1 Quote Link to comment Share on other sites More sharing options...
tfysh Posted December 16, 2018 Share Posted December 16, 2018 TRS? Aren't most (if not all) devices that the other end of a guitar cable plugs into TS? Wouldn't the sleeve/ring get shorted there? Should I not be using my G50 wireless with my JTV59? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 17, 2018 Share Posted December 17, 2018 Haven't had a problem with JTV and G50's. The internals of the G50 transmitter deal with that. It's an internal circuit thing. Just don't go using the G50 simultaneously with the VDI connection. Quote Link to comment Share on other sites More sharing options...
tfysh Posted December 19, 2018 Share Posted December 19, 2018 Great, thx. Quote Link to comment Share on other sites More sharing options...
odersfelt Posted December 26, 2018 Share Posted December 26, 2018 I just got a new JTV-89F and see recommendation to use TRS cable. Is that TRS at both ends or TRS into guitar and TS at other end into pedal board? Mind you am using a G70 for gigs, so this is really just for practice at home. Thanks. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted December 26, 2018 Share Posted December 26, 2018 Yes, TRS at both ends is good. When running JTV off of its battery, tip= signal, ring= battery, sleeve= ground return. It's been the de facto standard since the mid 1970's for active circuit guitars. Custom stuff I used to do for myself and Iron Butterfly, when I crewed for them back in the 70's. 1 Quote Link to comment Share on other sites More sharing options...
es345tds Posted March 8, 2019 Share Posted March 8, 2019 I think I might have missed something here - I can understand the possibility of "overloading the circuit" (I haven't ever used both jacks at the same time but have always wondered about that) by using the two jacks at the same time but I shouldn't be using a TR (standard) cable from Variax to amp (or in my case Helix)? I have always used a TR "standard" cable as the user manual instructs. I see the note about connecting the XPS-DI box with a TRS cable to power the Variax in place of the battery but the manual explicitly says use a standard 1/4" cable for the "analog" output jack. Is this TRS instruction an amendment to the user guide? Quote Link to comment Share on other sites More sharing options...
amorris1972 Posted April 11, 2019 Share Posted April 11, 2019 I'm a little confused. As es345tds stated the manual clearly says "put a standard 1/4 inch guitar cable here" in the description of the Analog output. I primarily use the VDI to my Helix, but I have occasionally used the battery/analog output to play through a traditional amp. Also, I find it interesting that the subject is about using both output at the same time and the consensus is that is bad, however you must use both when connecting to the workbench via a PC. Granted in that scenario the 1/4 cable doesn't need to plug into anything, but both are used. Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 11, 2019 Share Posted April 11, 2019 3 minutes ago, amorris1972 said: Also, I find it interesting that the subject is about using both output at the same time and the consensus is that is bad, however you must use both when connecting to the workbench via a PC. Granted in that scenario the 1/4 cable doesn't need to plug into anything, but both are used. amorris - I'm pretty sure I saw a comment about the fact that the 1/4" plug merely powers up the battery for use with the VDI connection so the two connections aren't really being used in the circuit together. Hope I understood what I just passed along to correctly. Maybe some else will jump in on this one since I don't remember where I saw that statement. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 11, 2019 Share Posted April 11, 2019 Correct es345tds,... programming is one thing, playing through it is something else. Just had one on my bench a week or two ago, took out the main board and the battery box circuits because of that. Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 12, 2019 Share Posted April 12, 2019 22 hours ago, psarkissian said: Correct es345tds,... programming is one thing, playing through it is something else. Just had one on my bench a week or two ago, took out the main board and the battery box circuits because of that. Were you modding that guitar or was that a remove/replace thing you did? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 12, 2019 Share Posted April 12, 2019 It came in for repair. The board was dead, component going to the VDI and the TRS were damaged or shorted from too much current pull, and the power management program in the battery box board was wiped. And he did it with inside the box, which made it worse. In programming or update mode using Monkey or Workbench HD, different circuitry is engaged, current draw is different, and so it's not a problem. TRS and VDI simultaneously,... don't do that. Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 12, 2019 Share Posted April 12, 2019 Sorry to drag this out but I might as well get more confusion out of the way. I am going to keep a "phono" plug (with no cable attached) handy for powering up the variax for use with the VDI updates. Would it matter in that case whether it was TR or TRS? Also - Is there a simple explanation for the difference in the circuitry used for powering the guitar for audio signal transmission vs simple power associated with VDI updates? I really haven't grasped why the TRS plug works differently from the TR plug for use with the variax application and why Line 6 doesn't speak of it (at least as far as I have seen anyway). Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 15, 2019 Share Posted April 15, 2019 Use a TRS adapter. Update mode engages different function than when in audio playing mode. And audio playing mode pulls current/voltage for different functions. In active guitar circuits since at least the mid 1970's, the configuration has been TRS: Tip= Signal, Ring= +V and Sleeve= ground/return. It's been something of a de-facto standard since then, and still the case today. Should be something in the manuals about that, and I constantly post on this here and on the Variax Facebook group. Sometimes gets lost in all the other posts. Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 15, 2019 Share Posted April 15, 2019 psarkissian "In active guitar circuits since at least the mid 1970's, the configuration has been TRS: Tip= Signal, Ring= +V and Sleeve= ground/return." Thanks, I understand how the TRS jacks work in normal conditions but with the VARIAX circuit the RING makes the connection that powers up the Variax at it's jack? The unit at the other end (amp, pedal, processor, etc...) with the TS style input doesn't engage the RING on the TRS plug, therefore it never sees the voltage and has no significance - right? I would think that there could be a problem using a TRS plug in a circuit that isn't designed for voltage - something like a stereo pedal that is looking for two guitar signals, not battery voltage - I don't know, just seems like something could go wrong plugging a powered TRS cable into just anything without knowing the compatibility. Please don't say "check with the manufacturer". I have a Yamaha acoustic/electric guitar that can be powered up via a TRS connection with the corresponding Yamaha AG Stomp preamp. This case is another unusual use for the TRS plug - you have to remember to swap out the battery for a "dummy" battery before making this connection. There does seem to be a lot of room for confusion when using the TRS cables and jacks due to their flexibility I suppose. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 16, 2019 Share Posted April 16, 2019 You could check with the manufacturer. But the way jacks are wired and "normaled", it matters at the guitar end to power the electronics. TRS acts as a switch as well. Much like the input jack on our DL4 Delay Modeler product. I plug TRS from JTV to other devices (some of them dating back to the 1970's) without a problem, it's the way the jacks are normal. Certain standards that have been around since since the days of Alexander Graham Bell that are still used today, with a few today tweaks. Also check the manuals in the Support link here for info on connecting with the onboard battery or the XPS power wedge. Some good diagrams on how that works. Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 16, 2019 Share Posted April 16, 2019 Thank you for the time and thoughts. TW Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 17, 2019 Share Posted April 17, 2019 psarkissian - this is off topic so I thought you could direct me to the right area - you seem to have a handle on the variax guitar - is there a forum topic that engages the variax HD work bench issues with the Helix edit program? I need to know if Line 6 is going to make the two programs compatible. I've been told not to use them at the same time. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted April 17, 2019 Share Posted April 17, 2019 I don't know what's in the pipeline, they don't tell any that sort of thing. They just give me stuff if it breaks, and I fix it. Quote Link to comment Share on other sites More sharing options...
es345tds Posted April 17, 2019 Share Posted April 17, 2019 1 hour ago, psarkissian said: I don't know what's in the pipeline, they don't tell any that sort of thing. They just give me stuff if it breaks, and I fix it. I feel your pain - I've also been a mushroom from time to time. TW :) Quote Link to comment Share on other sites More sharing options...
soundog Posted August 2, 2021 Share Posted August 2, 2021 Sorry to bring this up again, but I'm ready to a bunch of editing using Workbench HD on my Variax Standard. I just want to triple check and clarify: @psarkassian .... you said "In programming or update mode using Monkey or Workbench HD, different circuitry is engaged, current draw is different, and so it's not a problem" [to use TRS and VDI simultaneously]. That puts it to rest, I think... But then you add "TRS and VDI simultaneously,... don't do that." And scary story about fixing a fried board haunts me. I hate the smell of burnt circuitry. So... To triple check ....when using Workbench HD for programming/editing only, is it OK to route Variax VDI to the USB dongle (for Workbench) and TRS from Variax to a Variax power A/B unit (to avoid using a battery), and finally XLR or 1/4" TS from the A/B box to to an amp (for monitoring while customizing)? I'd simply charge a battery, but it takes soooo long, and I always power my Variax via the nifty A/B box. Thanks. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 2, 2021 Share Posted August 2, 2021 For checking what you're doing in Workbench, wouldn't be a problem. Do the battery and jack thing like you would for a Flash update thru Monkey, doing this with Workbench is fine. Using the XPS would not be a good idea. Using Workbench HD, hook it up like you would for a Flash update. Quote Link to comment Share on other sites More sharing options...
soundog Posted August 2, 2021 Share Posted August 2, 2021 Thank you, but this is still confusing. Maybe I skipped breakfast. Let's try this: Assume I have no working battery, instead I only use an XPS A/B to power my Variax. Can I use Workbench HD? Can I perform Flash updates? When should I NOT use the XPS? ------------ update, just found this from 2012 JTV “Variax Reflash and Software Update Instructions” from Line6Tony: "When using the Workbench Interface to update or edit the Variax guitar, ensure that a charged battery is in the guitar and a 1/4" TS mono cable is inserted into the guitar's output jack, or that the stereo TRS cable is plugged into the Variax providing power from the XPS power supply to power on the guitar. So, that's also reassuring. Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 3, 2021 Share Posted August 3, 2021 No, XPS is for using when playing only, not for updating or Workbench HD use. Tony's posting should be TRS, cable (with no connect on the other end) or headphone adapter, the idea is to engage the battery during update or Workbench HD, it's just a battery switch. I'll check that posting i the morning when I get in,... I'm the one who prepared that info him, for that. Quote Link to comment Share on other sites More sharing options...
rockmancentral Posted September 18, 2021 Share Posted September 18, 2021 Do the JTV's normally send both the modelled guitar signal and the mag signal simultaneously through the VDI AES/BUI? Quote Link to comment Share on other sites More sharing options...
amsdenj Posted September 19, 2021 Share Posted September 19, 2021 21 hours ago, rockmancentral said: Do the JTV's normally send both the modelled guitar signal and the mag signal simultaneously through the VDI AES/BUI? The models and/or magnetics are both sent digitally through the VDI cable. The A2D converter for the magnetics is in the Variax. With the model switch off, the magnetics are sent by themselves over VDI. With the model switch on you can use Workbench HD to adjust the balance/blend between the magnetics and model picks for any given patch. The default is to have the magnetics turned all the way down, and you would have to do this for any open tuning patches. Quote Link to comment Share on other sites More sharing options...
