Ibanez_cv Posted August 9, 2014 Share Posted August 9, 2014 I'm only using dropped D, so I can use the built-in detunings to get where I need to be. At the same time, I like the analog (real pickups) option, and have used them in many of my HD500 patches. Has anybody just detuned the JTV a half-step, and what was the result? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 9, 2014 Share Posted August 9, 2014 If you are going to play that way all the time, I would detune rather than use alt tuning. Alt tuning is always a compromise. Quote Link to comment Share on other sites More sharing options...
radatats Posted August 9, 2014 Share Posted August 9, 2014 I think for a 59 detune is fine but a 69 with trem its not so easy. I would use digital for a 69 just to not have to do a setup... Quote Link to comment Share on other sites More sharing options...
scotterp Posted August 9, 2014 Share Posted August 9, 2014 I have a 69 and we detune a half step. You may need to adjust the tension of the springs for the trem, but that's for your personal preference. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 9, 2014 Share Posted August 9, 2014 Half step detune isn't any different than changing string gauge. A trem adjustment should cover it. Again, I would do this if I was going to always play in Eb. Quote Link to comment Share on other sites More sharing options...
pugdealer Posted August 11, 2014 Share Posted August 11, 2014 I'd detune...digital always has an effect of tone not to mention possible warbles Quote Link to comment Share on other sites More sharing options...
Leftzilla Posted August 11, 2014 Share Posted August 11, 2014 I am in a prog band that my keyboard player does most of the writing. Every once in awhile he decides to change the original key of a song after I and the rest of the band have learned it. In one instance, a song that relied on open chords was change down a full step. To keep the open chords I used the down full step preset on the tuning knob and it sounded and worked very well. Quote Link to comment Share on other sites More sharing options...
rogue203 Posted August 14, 2014 Share Posted August 14, 2014 I'd detune so that you can use the alt tunings when you need Drop D, etc. Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 14, 2014 Share Posted August 14, 2014 Tune to your most used tuning, then base your alternate tunings on that. Dustin Kensrue tuned his Variax to D standard and had no problem. Thrice would play songs as low as B standard or Drop A, but it all sounded good still. Quote Link to comment Share on other sites More sharing options...
donnachatoo Posted August 15, 2014 Share Posted August 15, 2014 My band plays in Eb and I actually detuned my 59 down the half tone, however in my experience it does throw out the alt-tunings via the modelling as it is altering the tuning based on it expecting the guitar to be in E. So you may need to alter the tunings in the workbench.....not done it myself yet as other than dropped D (or dropped Db) I don't use any other tunings but will get round to doing it ! Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 15, 2014 Share Posted August 15, 2014 The Alt tunings are all relative to the actual tuning so if you change the actual tuning, the alt tunings will be shifted. If your actual tuning is out of tune, the alts will be out of tune. 3 Quote Link to comment Share on other sites More sharing options...
mdmayfield Posted August 20, 2014 Share Posted August 20, 2014 My band plays in Eb and I actually detuned my 59 down the half tone, however in my experience it does throw out the alt-tunings via the modelling as it is altering the tuning based on it expecting the guitar to be in E. So you may need to alter the tunings in the workbench.....not done it myself yet as other than dropped D (or dropped Db) I don't use any other tunings but will get round to doing it ! The Alt tunings are all relative to the actual tuning so if you change the actual tuning, the alt tunings will be shifted. If your actual tuning is out of tune, the alts will be out of tune. Charlie_Watt, my experience agrees with yours - for example, physical standard tuning, going to Drop D digital tuning drop the low string to D, but physically tuned to Eb, digital Drop D actually drops to Db. I don't think the Variax modeling "knows" what you're physically tuned to - it should be all relative. donnachatoo, are you referring maybe to *setting up* a custom alt tuning on the instrument (as opposed to setting it in Variax Workbench) and saving it in one of the tuning slots, by holding down the knob then playing the notes relative to the 12th fret? Because that would make sense. I think that's the only time the Variax modling ever actually "listens" to the notes you're playing, so it probably assumes you're in standard tuning. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted August 21, 2014 Share Posted August 21, 2014 " I think that's the only time the Variax modelling ever actually "listens" to the notes you're playing, so it probably assumes you're in standard tuning." It does - you just have to adjust for the altered tuning, so if physically tuned to Eb you need to set Virtual Capo using the 13th fret as the base rather than the 12th Quote Link to comment Share on other sites More sharing options...
FrozenOzone Posted August 21, 2014 Share Posted August 21, 2014 I have been down tuning my variax to Eb since I got it. I have never had to move the capo or do much other than have to set my guitar up again. I think Charlie_Watt is correct in his logic. Quote Link to comment Share on other sites More sharing options...
johnnyayyy Posted August 21, 2014 Share Posted August 21, 2014 Dustin Kensrue tuned his Variax to D standard and had no problem. I have always tuned my Variax transplants to D standard and never had any problems. My JTV on the other hand does not like to be tuned to D standard and makes funny out of tune notes on some of the models, the 12 string acoustics and the 12 string Rickenbacker are the ones I had problems with but there might be more. A support ticket was created by another user here with the same problem and the results were: "they've updated their faq's webpage to include that tuning must be in E Standard to work. They told me that that is how the guitar is calibrated and it's not tested beyond that. " My JTV works properly when tuned down to Eb, and most models are okay when tuned down to D - but when tuned to D the 12 strings are mostly unusable, unless you are playing in a Japanese noise band or something. 1 Quote Link to comment Share on other sites More sharing options...
dbagchee Posted August 23, 2014 Share Posted August 23, 2014 I tune mine down to Drop Db and adjusted the intonation for it. Then I went through all of the knob presets and adjusted them so that the selected label will be in the tuning matching the label. Works pretty well and I'm able to use the mags for most songs for my band. I think Line 6 doesn't support tuning down because it changes the pressure on the piezo pickups a bit. That said, if you change string gauge accordingly then it might account for that and work the same. Quote Link to comment Share on other sites More sharing options...
paulsteinway Posted August 23, 2014 Share Posted August 23, 2014 Keep in mind that when you retune digitally it can affect sustain. Normally the sound from the amp will cause the string to resonate at the same note symapthetically. When you retune digitally, the pitch coming from the amp is different frm the pitch of the strings so you won't get the same sustain (or any feedback). Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 24, 2014 Share Posted August 24, 2014 Keep in mind that when you retune digitally it can affect sustain. Normally the sound from the amp will cause the string to resonate at the same note symapthetically. When you retune digitally, the pitch coming from the amp is different frm the pitch of the strings so you won't get the same sustain (or any feedback). You'll still get feedback from resonance sympathy. It will still vibrate your strings regardless of what pitch they are. Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 24, 2014 Share Posted August 24, 2014 Feedback is GREATLY reduced during alternate tunings because as paulsteinway says the pitch from the amp does not match the pitch of the strings. Resonances are enhanced when they are excited at their resonant frequency. String's fundamental resonant frequency is not the same as what the DSP is generating during alternate tunings. This is a real disadvantage of alternate tunings done by DSP. Quote Link to comment Share on other sites More sharing options...
bobwilken Posted August 29, 2014 Share Posted August 29, 2014 so if I am interpreting this thread correctly ...turning down a full step to D Will generally function properly.. but might be whacked out on some alternate tunings and various settings.. especially susceptible are those involving 12 strings. I am also getting the impression that whatever mischief might be caused by turning down to D can be corrected with the editing software. have I got it right ? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 29, 2014 Share Posted August 29, 2014 Alternate tunings will be relative to the actual string tunings period. Quote Link to comment Share on other sites More sharing options...
jcerrero Posted August 31, 2014 Share Posted August 31, 2014 I don't have enough experience with variax models. I recently bought a JTV-59 but I'm still trying to discover models and tunings. Something getting me crazy is the fact that everytime I use the alternative tuning 1/2 step down (Eb), the sound of the guitar gets octaved, as it was in the 12 strings model but it's not!! Does somebody have something to share about it? Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted August 31, 2014 Share Posted August 31, 2014 I don't have enough experience with variax models. I recently bought a JTV-59 but I'm still trying to discover models and tunings. Something getting me crazy is the fact that everytime I use the alternative tuning 1/2 step down (Eb), the sound of the guitar gets octaved, as it was in the 12 strings model but it's not!! Does somebody have something to share about it? Thats a new one...numerous complaints about the alt tunings...'ghost notes', 'warbling', lack of sustain, etc...but never seen anyone say that an alt tuning produced octave harmonies. Quote Link to comment Share on other sites More sharing options...
clay-man Posted August 31, 2014 Share Posted August 31, 2014 Thats a new one...numerous complaints about the alt tunings...'ghost notes', 'warbling', lack of sustain, etc...but never seen anyone say that an alt tuning produced octave harmonies. Looks like someone forgot they're on a 12 string model haha Quote Link to comment Share on other sites More sharing options...
jakeman19 Posted September 1, 2014 Share Posted September 1, 2014 I've been tuned down to Eb also since I got my JTV-69s and other than having to adjust the tremolo springs I have not had a problem. I've been so use to having my guitar a step down over the years I just had to tune this one down even though I could do it with the JTV's virtual capo. My 2 cents. Quote Link to comment Share on other sites More sharing options...
donnachatoo Posted September 2, 2014 Share Posted September 2, 2014 donnachatoo, are you referring maybe to *setting up* a custom alt tuning on the instrument (as opposed to setting it in Variax Workbench) and saving it in one of the tuning slots, by holding down the knob then playing the notes relative to the 12th fret? Because that would make sense. I think that's the only time the Variax modling ever actually "listens" to the notes you're playing, so it probably assumes you're in standard tuning. Apologies for the late reply, what I meant was actually going into the Workbench and adjusting all the tunings there, but the Virtual Capo version would work I guess....not done either myself, but keep meaning to !!! I'm still happy using the mags to be honest with the occasional dropped D which seems to sound fine ! Quote Link to comment Share on other sites More sharing options...
jcerrero Posted September 2, 2014 Share Posted September 2, 2014 Thats a new one...numerous complaints about the alt tunings...'ghost notes', 'warbling', lack of sustain, etc...but never seen anyone say that an alt tuning produced octave harmonies. I found what the problem was. This effect only appears when I´m using the Guitar Rig interface for recording. I've tested pluging the guitar direct to the ampli and it's Ok. I don't know why indeed but it's probably related to digital issues. Quote Link to comment Share on other sites More sharing options...
