robberns Posted April 22, 2020 Share Posted April 22, 2020 It's a good thing there aren't any gigs in the near future. I've got 2 bricked HX units, a Stomp and an Effects. Attempted the 2.9 firmware update on both, both units failed and now won't boot. Opened a support ticket and tried what they told me to (power up holding down the > button) and then try to manually load the firmware. Both units failed again. I should have waited until the rest of the world worked out the bugs. So beware out there. Quote Link to comment Share on other sites More sharing options...
silverhead Posted April 22, 2020 Share Posted April 22, 2020 I hesitate to ask.... but did you use HX Edit v2.90 to perform the firmware update? That’s important information for the others out there who should beware. 1 1 Quote Link to comment Share on other sites More sharing options...
robberns Posted April 22, 2020 Author Share Posted April 22, 2020 Yes, I followed the Line 6 instructions to the letter. And I am not a computer newbie. Once the units bricked, the instruction is to use the Line 6 updater, which also failed. I originally tried on a Mac laptop, now trying on a Dell laptop. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 22, 2020 Share Posted April 22, 2020 What Silverhead said. Do a Factory Reset by re-booting while holding down buttons 9+10. If you did the backup during the install you can restore it after the reset. Quote Link to comment Share on other sites More sharing options...
robberns Posted April 22, 2020 Author Share Posted April 22, 2020 There are no buttons 9 + 10 on the HX Effects... I did attempt to do a factory reset on both units, which did not work. What did work is to run the Updater from the Windows PC. Mac OS did not work, there is obviously a problem there. I was able to get both the Stomp and Effects updated to 2.9, and then reloaded my backup from the Mac. Not sure what I would have done if I did not have a Windows machine. Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted April 22, 2020 Share Posted April 22, 2020 Well, I'm glad you got it fixed, but before you go ragging on Line 6, consider that if every Mac user 'bricked' their devices during update, we'd be seeing a LOT more about it. So far, you're the only one. Since the common link in all this was your Mac, I'd be a little suspicious about something specific to your computer (flaky USB port? cable used? old/out of date OS?... ) 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 22, 2020 Share Posted April 22, 2020 6 minutes ago, robberns said: There are no buttons 9 + 10 on the HX Effects... Oops....FS6+TAP on that. Glad you got it working. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted April 22, 2020 Share Posted April 22, 2020 Frank Ritchotte of Line 6 posted these Official Steps to TGP regarding Safe Booting, if needed: Helix SafeBoot Steps: https://www.thegearpage.net/board/index.php?posts/30401537/ Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 22, 2020 Share Posted April 22, 2020 20 minutes ago, MusicLaw said: Frank Ritchotte of Line 6 posted these Official Steps to TGP regarding Safe Booting, if needed: Helix SafeBoot Steps: https://www.thegearpage.net/board/index.php?posts/30401537/ GREAT! I'm saving that link for all the future "My update failed!" posts. 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted April 22, 2020 Share Posted April 22, 2020 4 minutes ago, rd2rk said: GREAT! I'm saving that link for all the future "My update failed!" posts. That's what I did too!! So, I'll have it if I might ever need it... Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 23, 2020 Share Posted April 23, 2020 I'm glad things seem to have gotten sorted, but it seems to me that if the same computer bricked multiple pieces of hardware, than it's most likely there's some sort of issue with that particular computer, not all the different pieces of hardware... 2 Quote Link to comment Share on other sites More sharing options...
robberns Posted April 23, 2020 Author Share Posted April 23, 2020 Hey, who knows, but the 2.9 editor works fine on this MacBook. Used the same cable with the PC so I know it isn't that. The issue was with the firmware updater. Maybe it is the MacBook, can't say. I'll be curious to see if anyone else using OS X has this issue over the coming weeks. Quote Link to comment Share on other sites More sharing options...
MartinDorr Posted April 23, 2020 Share Posted April 23, 2020 Knowing your OS X version and laptop model / year would help to correlate to other user’s problem if there is a systemic underlying issue ... Quote Link to comment Share on other sites More sharing options...
robberns Posted April 23, 2020 Author Share Posted April 23, 2020 MacBook Pro (Retina, Mid 2012) A1398 (EMC 2512) Mac OS Catalina Version 10.15.4 Quote Link to comment Share on other sites More sharing options...
soundog Posted April 23, 2020 Share Posted April 23, 2020 Catalina is a scary thing for a lot of apps. 1 Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted April 23, 2020 Share Posted April 23, 2020 Adding this link to another post about update failure on Mac and how to fix it. In this case, failure was because the Mac went into sleep mode at some point during the update: Quote Link to comment Share on other sites More sharing options...
monsieurkozo Posted April 23, 2020 Share Posted April 23, 2020 Hi, just for info : I did the update yesterday on OSX without any issue. It took less than 10 minutes. Late 2011 Macbook Pro with OSX 10.13.6 (High Sierra) Quote Link to comment Share on other sites More sharing options...
giaturr Posted April 23, 2020 Share Posted April 23, 2020 I did the update yesterday, too. MacOS 10.15.4 (Catalina). Upgraded Helix Floor and HX Stomp, one after the other, in no time. Quote Link to comment Share on other sites More sharing options...
Riprock Posted April 23, 2020 Share Posted April 23, 2020 All good here too! I used my shiny new MacBook Pro - Catalina 10.15.4, installed the new HX Edit first and then updated my Helix from version 2.82 to the new 2.90. It was fast and easy. So far all is working fine for me. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 23, 2020 Share Posted April 23, 2020 9 hours ago, soundog said: Catalina is a scary thing for a lot of apps. Catalina is just fine for all Helix products at this point. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 23, 2020 Share Posted April 23, 2020 2018 MBP 13" here, Catalina, everything ran smoothly on every beta. In fact, I have had no installation issues of any kind since early 2016 I think. Quote Link to comment Share on other sites More sharing options...
robberns Posted April 23, 2020 Author Share Posted April 23, 2020 Guess it's just my particular MB Pro. Fine for HX Edit, will do any future firmware updates via Windows laptop. Quote Link to comment Share on other sites More sharing options...
surfsup1955 Posted April 24, 2020 Share Posted April 24, 2020 Catalina here, no issues at all with update. Helix Floor. Quote Link to comment Share on other sites More sharing options...
BlueD Posted April 24, 2020 Share Posted April 24, 2020 On 4/22/2020 at 5:30 PM, phil_m said: I'm glad things seem to have gotten sorted, but it seems to me that if the same computer bricked multiple pieces of hardware, than it's most likely there's some sort of issue with that particular computer, not all the different pieces of hardware... seems like a pretty wild and unwarranted logical leap to me. It's much more likely there's an issue with the Mac version of the software and that has caused problems. Line6 notoriously pays little attention to Mac, you can see it by how most of their software is still not notarized for Catalina (except HX Edit with the last release) after almost a year from release. The latest version of Helix Native still has issues installing under Catalina, I was shocked to see that. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 24, 2020 Share Posted April 24, 2020 1 hour ago, BlueD said: seems like a pretty wild and unwarranted logical leap to me. It's much more likely there's an issue with the Mac version of the software and that has caused problems. Line6 notoriously pays little attention to Mac, you can see it by how most of their software is still not notarized for Catalina (except HX Edit with the last release) after almost a year from release. The latest version of Helix Native still has issues installing under Catalina, I was shocked to see that. You think Line 6 doesn’t pay attention to Mac? Everyone I know at Line 6 uses a Mac... I think it’s harder for companies to keep up with Apple because they have more frequent OS updates, and a lot of updates seem to affect core functionality when it comes to audio, for whatever reason. The whole thing with the certification is kind of a non-issue, in that it can be overridden. It’s just kind of Apple throwing its weight around, trying to make the world play by its rules. 1 Quote Link to comment Share on other sites More sharing options...
BlueD Posted April 24, 2020 Share Posted April 24, 2020 3 minutes ago, phil_m said: You think Line 6 doesn’t pay attention to Mac? Everyone I know at Line 6 uses a Mac... I think it’s harder for companies to keep up with Apple because they have more frequent OS updates, and a lot of updates seem to affect core functionality when it comes to audio, for whatever reason. The whole thing with the certification is kind of a non-issue, in that it can be overridden. It’s just kind of Apple throwing its weight around, trying to make the world play by its rules. You're essentially saying "don't believe your lying eyes" here. It's not that I THINK, I KNOW they don't because otherwise they would have caught up. Using Macs doesn't mean much, they have made prioritization decisions and obviously first rate support on Mac is not on the list of priorities, or the situation would be different. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 24, 2020 Share Posted April 24, 2020 9 minutes ago, BlueD said: You're essentially saying "don't believe your lying eyes" here. It's not that I THINK, I KNOW they don't because otherwise they would have caught up. Using Macs doesn't mean much, they have made prioritization decisions and obviously first rate support on Mac is not on the list of priorities, or the situation would be different. No, I’m saying Apple forces companies in the OSX ecosystem to jump through a lot of hoops. I’ve not seen anything that says Line 6 isn’t trying. It’s just that sometimes their hands are tied. The fact that Catalina dropped 32-bit support entirely, for instance, screwed a lot of people over. As far as the Line 6 guys using Macs goes, it’s certainly relevant. If most of the testing and development is being done with Macs, how can they actually just ignore it? Regardless, I’ve not seen widespread evidence that there’s some sort of universal problems with the Helix and Macs. I see just as many posts of people having issues with Windows machines. There’s enough variation in these systems, that there’s always going to be anecdotes of people having problems. 1 Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted April 24, 2020 Share Posted April 24, 2020 1 hour ago, BlueD said: seems like a pretty wild and unwarranted logical leap to me. It's much more likely there's an issue with the Mac version of the software and that has caused problems. ONE user having this issue on ONE computer makes it 'much more likely' that it's an issue with Mac versions in general? You described your own logic with your first sentence. 1 Quote Link to comment Share on other sites More sharing options...
BlueD Posted April 24, 2020 Share Posted April 24, 2020 19 minutes ago, phil_m said: No, I’m saying Apple forces companies in the OSX ecosystem to jump through a lot of hoops. I’ve not seen anything that says Line 6 isn’t trying. It’s just that sometimes their hands are tied. The fact that Catalina dropped 32-bit support entirely, for instance, screwed a lot of people over. As far as the Line 6 guys using Macs goes, it’s certainly relevant. If most of the testing and development is being done with Macs, how can they actually just ignore it? Regardless, I’ve not seen widespread evidence that there’s some sort of universal problems with the Helix and Macs. I see just as many posts of people having issues with Windows machines. There’s enough variation in these systems, that there’s always going to be anecdotes of people having problems. How many actively supported pieces of software do you use that are not notarized (a process that takes literally minutes) to work under Catalina? I understand you like the company, but this is MAGA level of denial. 1 Quote Link to comment Share on other sites More sharing options...
BlueD Posted April 24, 2020 Share Posted April 24, 2020 Just now, qwerty42 said: ONE user having this issue on ONE computer makes it 'much more likely' that it's an issue with Mac versions in general? You described your own logic with your first sentence. One in this thread. Also if you know anything about how computers work, it's very unlikely that a hardware problem severe enough to introduce an issue during a firmware refresh would have no other effect whatsoever. Paired with what I'm reading in the groups on Facebook and other forums, it's pretty clear this is not an isolated event. Frankly this answer says more about you than it says about me: attacking me personally because I'm saying something that goes against the idealized image you formed of a corporation in your mind, that's pretty sad. I know it happens, but still, I constantly shake my head at the depth of self delusion fanboys will fall into. 2 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 24, 2020 Share Posted April 24, 2020 21 minutes ago, BlueD said: It's not that I THINK, I KNOW Part of this statement is false...... Anecdotal evidence in refutation of the L6 "anti-MAC" bias: Helix Native is mostly MIDI enabled, except for Program Change Messages. They only work on DAWs that run on MAC, NOT in the myriad DAWs that only run on PCs. I've questioned L6 on this (admittedly minor problem) in at least three places. No answer. Must be a conspiracy....... Quote Link to comment Share on other sites More sharing options...
BlueD Posted April 24, 2020 Share Posted April 24, 2020 Just now, rd2rk said: Part of this statement is false...... Anecdotal evidence in refutation of the L6 "anti-MAC" bias: Helix Native is mostly MIDI enabled, except for Program Change Messages. They only work on DAWs that run on MAC, NOT in the myriad DAWs that only run on PCs. I've questioned L6 on this (admittedly minor problem) in at least three places. No answer. Must be a conspiracy....... Ok then, they are sloppy on every platform. I feel relieved... 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 24, 2020 Share Posted April 24, 2020 3 minutes ago, BlueD said: Ok then, they are sloppy on every platform. I feel relieved... Happy to help. But seriously, this is not the first time you've come on here to criticize L6, then got personally offended when others defend them, attacking all and sundry with the "Fanboy" epithet. I gotta wonder, what is your agenda? And, oh yeah, you also introduced politics, in violation of forum policies. Just sayin'. 1 1 Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted April 24, 2020 Share Posted April 24, 2020 17 minutes ago, BlueD said: One in this thread. Also if you know anything about how computers work, it's very unlikely that a hardware problem severe enough to introduce an issue during a firmware refresh would have no other effect whatsoever. Paired with what I'm reading in the groups on Facebook and other forums, it's pretty clear this is not an isolated event. Frankly this answer says more about you than it says about me: attacking me personally because I'm saying something that goes against the idealized image you formed of a corporation in your mind, that's pretty sad. I know it happens, but still, I constantly shake my head at the depth of self delusion fanboys will fall into. No, I'm refuting your statement because it's as much of a logical fallacy as you claimed the other was. If you go up in this thread, I posted a link to another post on this forum where a mac user had a similar problem from his computer entering sleep mode during the update. This person's problem could have just as easily been the same thing. That's the point--yes, there are things that can happen that are isolated incidents. Your leap of assuming more about me at the end of your reply, after accusing me of 'attacking you personally', is another logical fallacy, and a hypocritical one at that. 1 Quote Link to comment Share on other sites More sharing options...
j_hotch Posted April 24, 2020 Share Posted April 24, 2020 Just a PSA: you can block posts from users who give you 'd blues. It can go a long way towards improving your day. Good luck! 2 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 24, 2020 Share Posted April 24, 2020 58 minutes ago, BlueD said: How many actively supported pieces of software do you use that are not notarized (a process that takes literally minutes) to work under Catalina? I understand you like the company, but this is MAGA level of denial. I am more than a regular on all the forums. I see WAY more issues with Windows computers and HX products than Mac. I don't know that there is actually that many issues with Catalina, tbh. I certainly had no issues with it with either Native 1.8 or 1.9, through all the betas as well. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 24, 2020 Share Posted April 24, 2020 9 minutes ago, PeterHamm said: I am more than a regular on all the forums. I see WAY more issues with Windows computers and HX products than Mac. I don't know that there is actually that many issues with Catalina, tbh. I certainly had no issues with it with either Native 1.8 or 1.9, through all the betas as well. To be fair - there are a WHOLE LOT more Windows computers than MACs in the world. It's been my observation that many (NOT ALL!) MAC users don't know a lot about computers and don't WANT to. That's WHY they buy a MAC. Turn it on and get to work! Many (NOT ALL!) people who buy Windows PCs do so because they're cheaper, and/or the SW they want to run doesn't run on MAC. They have problems because they don't know much about computers, and don't WANT to know, and you NEED to know at least a little about computers to use Windows, IOW - you pay for a more stable and easier to use platform with money. You pay for initial affordability with the need to learn pesky technical stuff to fix things when they go awry (or to make them work in the first place!). Such is the nature of life in the digital wonderland! 1 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 24, 2020 Share Posted April 24, 2020 56 minutes ago, rd2rk said: To be fair - there are a WHOLE LOT more Windows computers than MACs in the world. It's been my observation that many (NOT ALL!) MAC users don't know a lot about computers and don't WANT to. That's WHY they buy a MAC. Turn it on and get to work! Many (NOT ALL!) people who buy Windows PCs do so because they're cheaper, and/or the SW they want to run doesn't run on MAC. They have problems because they don't know much about computers, and don't WANT to know, and you NEED to know at least a little about computers to use Windows, IOW - you pay for a more stable and easier to use platform with money. You pay for initial affordability with the need to learn pesky technical stuff to fix things when they go awry (or to make them work in the first place!). Such is the nature of life in the digital wonderland! well, the gulf between usability on the two platforms is far from what it was just a decade or so ago, but yeah. I still find Windows 10 so annoying to configure and use that my "test" laptop I have here never gets turned on. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 24, 2020 Share Posted April 24, 2020 8 minutes ago, PeterHamm said: well, the gulf between usability on the two platforms is far from what it was just a decade or so ago, but yeah. I still find Windows 10 so annoying to configure and use that my "test" laptop I have here never gets turned on. Long ago, in a galaxy far far away (California), I earned a pretty good living doing every kind of PC and network support you can imagine. I was given a computer to fix - "It's really slow and won't connect to the Internet." Turns out it was an ancient 8088 (or was it a 286?) with 256k and a tiny HD. It was running Windows 1.0. I gave the guy an old 386 I had in the closet running Windows 95. He was THRILLED! Windows 10 is SO much better these days. My systems are VERY stable, but they wouldn't be without the patience afforded me by that experience. A friend loaned me a 2013 MBP, just so I could see what all the fuss was about. I hated it. All the fun stuff is hidden! :-) 2 Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 24, 2020 Share Posted April 24, 2020 I like Windows 10 for the most part. I’ve not had any big problems with it. In my line of work, architecture and engineering, Windows is pretty much the only game in town. There are a few people who use Macs to run Revit or whatnot, but even those have partitioned drives with Windows installed on them for that purpose. There are a lot of things with OS X that I find confusing and kind of backwards, personally. 1 Quote Link to comment Share on other sites More sharing options...
