MatthewMcGhee Posted March 7 Share Posted March 7 I have Helix Floor on 3.15... expression pedal is lowering volume by itself out of nowhere down to 70-80%s. Anyone experienced this? I just did a complete reset. EDIT: Can anyone provide instructions on downgrading firmware please? Quote Link to comment Share on other sites More sharing options...
theElevators Posted March 7 Share Posted March 7 1 hour ago, MatthewMcGhee said: I have Helix Floor on 3.15... expression pedal is lowering volume by itself out of nowhere down to 70-80%s. Anyone experienced this? I just did a complete reset. EDIT: Can anyone provide instructions on downgrading firmware please? Download Helix updater. Run it. Select 3.11. Quote Link to comment Share on other sites More sharing options...
FearTheAbyss Posted March 7 Share Posted March 7 23 hours ago, FearTheAbyss said: Hello. Hopefully you guys can help me out. Line 6 HX Stomp XL Firmware 3.1+ (tried the 3 most recent ones) HX Edit a- I’ve tried the 2 most recent updates Windows 10 Currently, I’m experiencing no sound when the unit is FULLY booted up. I hear a dry signal when you first turn the unit on, but once the unit is booted it cuts out. The weird thing is, I 100% know that this is a software issue. Everything worked before I did a factory reset so I could sell it. Having 2nd thoughts, I was going to give it another go. I installed all the lastest firmwares and started trying to make a patch. I get no sound, none of the stock presets work. It’s pretty much just bricked. i uninstalled everything and tried again, didn’t work. Reverted back to older firmwares, nothing worked. Updated the older firmwares to the latest ones, no luck. Am I missing something here? Bump Quote Link to comment Share on other sites More sharing options...
rd2rk Posted March 7 Share Posted March 7 1 hour ago, FearTheAbyss said: Bump 1) In regard to the following - make no assumptions. JUST DO IT! 2) DL and install HX Edit 3.15. 3) Do a factory reset. If that doesn't fix it: 4) Re-flash your FW using the Line6 Updater, the latest version of which installs with HX Edit. FOLLOW THE DIRECTIONS! 5) FOLLOW THE DIRECTIONS! 6) See 1) 7) If, after having done all of that while FOLLOWING THE DIRECTIONS, contact support. There's nothing anyone here can do for you. 1 Quote Link to comment Share on other sites More sharing options...
boynigel Posted March 7 Share Posted March 7 My LT has locked up/froze several times now while trying to get to a certain preset. The only fix is to reboot and try again, but subsequent attempts yield the same result until I found a workaround. Here are some details: So far, it only seems to happen when I try accessing a certain preset. If it matters, the preset I’m going to has a new 3.15 addition, the Tesselator. In addition, this preset contains Shuffle Looper and some CPU-intensive effects like the Poly Capo. Safe to say that this preset is on the brink of being “maxed out” in terms of CPU availability…if that could be part of the reason. That said we ALL have some presets that are maxed, or near-maxed. Here’s how it all goes down- I’ll be on a given preset and then I’ll use the bank footswitches to get to the back that holds the preset in question. When I tap the preset’s corresponding foot switch, nothing happens, and then it freezes up. Doesn’t matter what footswitch or button I press, the screen is locked showing all of my presets in that particular bank. Through trial and error, I’ve found that I can access the preset via the Preset wheel/knob, but there’s just something about using the foot switches that it’s not liking. Sometimes it lets me, but most of the time it doesn’t. I know it isn’t the footswitch (that corresponds to the preset) itself, because the switch gives me no issues within other banks. FWIW, this isn’t a case where I had just updated to 3.15, created the new preset, and then all of this started happening. I updated weeks ago, and created the preset within a few days later, so there’s that. Quote Link to comment Share on other sites More sharing options...
C4TH Posted March 7 Share Posted March 7 3.15 update - Using Ext Amp (EXP 2) Instant Commands with My HX Effects, and changing the command from tip, ring or whatever to change amp channels, seems to effect (EXP1) My expression pedal in EXP1 stops working on all presets. Quote Link to comment Share on other sites More sharing options...
FearTheAbyss Posted March 7 Share Posted March 7 2 hours ago, rd2rk said: 1) In regard to the following - make no assumptions. JUST DO IT! 2) DL and install HX Edit 3.15. 3) Do a factory reset. If that doesn't fix it: 4) Re-flash your FW using the Line6 Updater, the latest version of which installs with HX Edit. FOLLOW THE DIRECTIONS! 5) FOLLOW THE DIRECTIONS! 6) See 1) 7) If, after having done all of that while FOLLOWING THE DIRECTIONS, contact support. There's nothing anyone here can do for you. I’ve already submitted a support ticket. Here’s what I’ve done so far. Reset to factory settings and wiped PC with all Line 6 software with intent to sell. Had a friend that was interested, so I tried to install the latest firmware via line 6 updater and the newest HX Edit. No signal, bricked. Wiped PC and reset to factory settings. Installed HX Edit first, then installed the firmware via HX Edit. Nada, no go. Quote Link to comment Share on other sites More sharing options...
jdomine Posted March 7 Share Posted March 7 2 hours ago, C4TH said: 3.15 update - Using Ext Amp (EXP 2) Instant Commands with My HX Effects, and changing the command from tip, ring or whatever to change amp channels, seems to effect (EXP1) My expression pedal in EXP1 stops working on all presets. I am able to reproduce this and have logged a bug for it. It seems to go all the way back to 3.00.0 if not further. It does not seem to happen if you use EXP1 for the ext amp control and EXP2 for expression. For now I would recommend using this configuration as a workaround. Quote Link to comment Share on other sites More sharing options...
C4TH Posted March 7 Share Posted March 7 3 minutes ago, jdomine said: I am able to reproduce this and have logged a bug for it. It seems to go all the way back to 3.00.0 if not further. It does not seem to happen if you use EXP1 for the ext amp control and EXP2 for expression. For now I would recommend using this configuration as a workaround. Thanks for confirming. Thanks a lot Quote Link to comment Share on other sites More sharing options...
canadianjamest Posted March 11 Share Posted March 11 On 2/26/2022 at 5:28 PM, shmaque said: Hit my first show-stopper level 3.15 issue today (Helix Floor): I like to run Stomp/Snap mode, with four snapshots on the bottom row and four stomps on the top (for my live style, it just works best for me). However, on some presets, I end up using more than 4 snapshots. Rather than manually having to remember which presets to hit bank up+down to switch to 8-snap display, I’ve taken to assigning snapshots to some of the top row stomp switches via command center. This worked great through 3.11, but at least one of those presets went berserk today on 3.15. snapshot1 looks & behaves totally normal (first image), but when I hit snaps 2-4, the upper row flips to SNAPSHOT^ on all buttons. To fix this, I had to enable “recall” for snapshot edits, and walk through every snap in the patch, manually fixing the command center setting, then re-save. Basically, I’m saying something broke my preset in the 3.15 preset rebuild & only retained the snapshot setting metadata for the first snap in these kind of patches. The rest knew there was a cmd center event, and knew it was a snapshot event, but overwrote it with “1” (Next). Yes, I did a full factory reset & restore from backup when upgrading, including letting it rebuild all of my presets after the restore. EDIT: even stranger, it only appears to have affected this one preset. All of my others (which only have one cmdCenter snap saved as a stomp vs the 4 here) are fine EDIT #2: You know what, I apologize. I just went back and decoded/parsed all of my setlist backups for the past year. This issue has been in my patch since at least last August, which tells me something different, but equally interesting: this must've been a bug in previous firmware, where snapshots didn't honor different parameters on CommandCenter settings from one snap to the next that they fixed in 3.15. I don't see anything specifically tied to it in the release notes, but perhaps it was related to some of the other CommandCenter bug fixes. So, yeah. The firmware is actually doing what it's supposed to now. *shrug* I have experienced this identical issue and am trying to work through it with a number of presets. I have never experienced anything like this in any previous firmware versions. After doing some trouble shooting on my end, the only thing that worked for me was to open HX Edit to the problem patch, then also open the "Command Center". I then would click on the button I was programing in Command Center, in my case it was button number 3, and I was programming it to select Snapshot #5 to that button in the "HX Snapshot" control menu of the command center. I would then select each snapshot using the dropdown menu/list at the top of HX Edit and I would see the snapshot assignment for that button change/revert back to "next snapshot" instead of Snapshot #5 that I initially programmed onto that button. I would then manually change it from "next snapshot" back to "Snapshot 5" that I wanted on that button, then I would save the patch. I would then select the next snapshot from the dropdown list at the top of HX Edit and continue to do that same process for each snapshot. Once I did this the changes were saved on all the snapshots and the patch would work correctly. This is definitely a bug, or if not a bug, a severe unintended consequence to the new ability to stack snapshots on one button. I have some work ahead of me to change a number of patches to get them to work correctly. Quote Link to comment Share on other sites More sharing options...
ech0FX Posted April 1 Share Posted April 1 Does anyone else has noises when using any Pitch changer preset? Doesnt matter if simple or poly-Pitch. If you down-Pitch even by 1 Semitone, i get a wobbly noise. Use it for bass. You can hear it at lot in super low tunings but even from a simple D->C is noticable. I was using the Simple-Pitch for Years now, but since 3.15 it makes those noises. The lower the more noticable. Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 1 Share Posted April 1 On 4/1/2022 at 12:02 PM, ech0FX said: Does anyone else has noises when using any Pitch changer preset? Doesnt matter if simple or poly-Pitch. If you down-Pitch even by 1 Semitone, i get a wobbly noise. Use it for bass. You can hear it at lot in super low tunings but even from a simple D->C is noticable. I was using the Simple-Pitch for Years now, but since 3.15 it makes those noises. The lower the more noticable. Are you putting the pitch change FIRST in the chain? Quote Link to comment Share on other sites More sharing options...
Egery4 Posted April 4 Share Posted April 4 Help me please. There was a problem. Version 3.11 was installed. After that, the settings were reset and version 3.15 was installed. The problem has not been resolved. Did a reset again and installed version 2.82. did not help. Now it costs 3.10. Quote Link to comment Share on other sites More sharing options...
Egery4 Posted April 4 Share Posted April 4 Similar problem. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 4 Share Posted April 4 (edited) On 4/4/2022 at 10:02 AM, Egery4 said: Help me please. There was a problem. Version 3.11 was installed. After that, the settings were reset and version 3.15 was installed. The problem has not been resolved. Did a reset again and installed version 2.82. did not help. Now it costs 3.10. 143 B · 2 downloads On 4/4/2022 at 10:05 AM, Egery4 said: Similar problem. Hi, You say that you installed the v3.15 firmware update, but you did not say if you followed the installation notes that state you should make a backup of your Helix prior to the update, then after it completes, you should perform a factory reset, and then restore from the backup. In any situation where things do not work as expected, or you experience any other weird things happening with your hardware - perform a factory reset. If you still experience abnormal behaviour with the unit, re-flash the firmware and follow the instructions precisely. Essentially you are dealing with a computer and software- it’s very rare that a software update will brick your hardware. It all lights up - quite possibly a it’s just a glitch! Hope this helps/makes sense. EDIT: I have just seen your post in the thread where that video was originally posted. If you have tried all the usual methods to fix this issue, without success, then you need to raise a ticket with Support, as suggested in the other thread. Edited April 4 by datacommando Added comment 1 Quote Link to comment Share on other sites More sharing options...
Egery4 Posted April 5 Share Posted April 5 I have reinstalled various firmware versions and reset several times. Line 6 support responded that they couldn't help me at the moment. What other options might there be? Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 5 Share Posted April 5 On 4/5/2022 at 4:28 AM, Egery4 said: What other options might there be? Hi, Other options? Well, none here, this is a user group that deals with general minor issues. In the other thread where you got the video, there is a response from “psarkissian”, who is a Line 6 service engineer, and he stated:- “Log a Support ticket in your account. That will have to be serviced.” I cannot understand why Customer Support said they couldn’t help you at the moment. Their job is to support the customer. There must be more to it than that. That answer makes absolutely no sense at all. Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
Egery4 Posted April 6 Share Posted April 6 Thanks! I hope they help me. 1 Quote Link to comment Share on other sites More sharing options...
Pinkmania Posted April 6 Share Posted April 6 also my Helix Rack (3.15 and on previous firm) sounds different random, though no level was changed. For 1 - 2 or three days is good, day after is bad. All comments previous are usefull! but i can't understand why that happens. Anyone knows how to run an auto-test for its harware? Thank you very much indeed. Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 6 Share Posted April 6 On 4/6/2022 at 2:03 PM, Pinkmania said: also my Helix Rack (3.15 and on previous firm) sounds different random, though no level was changed. For 1 - 2 or three days is good, day after is bad. All comments previous are usefull! but i can't understand why that happens. Anyone knows how to run an auto-test for its harware? Thank you very much indeed. Hi, In any situation where things do not work as expected, or you experience any other weird things happening with your hardware - perform a factory reset. If you still experience abnormal behaviour with the unit, re-flash the firmware and follow the instructions precisely. All reset options for your Helix Rack can be found here: https://helixhelp.com/tips-and-guides/universal/reset-options Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted April 8 Share Posted April 8 Still getting these constantly. And once it happens, not only HX Edit craps out but the Helix itself is freezing in, requiring a reboot. Never had this happen with any earlier FW version. I'm seriously considering going back to 3.1. Fwiw, I'm on macOS Mojave. 1 Quote Link to comment Share on other sites More sharing options...
Pinkmania Posted April 8 Share Posted April 8 Thank you very much datacommando, in the past I had already made factory reset also with previous firmware, but not reflash. Today I have reflash and perform a factory reset before and after reflashing. Now It seems all good, I hope next days still remains stable. Unfortunately for Helix Rack, see page you linked, doesn't show "test mode" for Helix Rack, Floor only. Even if is not explain what test perform. Several keys if pressend before booting, show some misterious menu. I can't remember which ones, but I think avoid that can be dangerous. I'll post a feedback if Helix remain stable. Have a good day. Thanks a lot. On 4/7/2022 at 12:13 AM, datacommando said: Hi, In any situation where things do not work as expected, or you experience any other weird things happening with your hardware - perform a factory reset. If you still experience abnormal behaviour with the unit, re-flash the firmware and follow the instructions precisely. All reset options for your Helix Rack can be found here: https://helixhelp.com/tips-and-guides/universal/reset-options Hope this helps/makes sense. 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted April 8 Share Posted April 8 On 4/8/2022 at 3:12 PM, Pinkmania said: Unfortunately for Helix Rack, see page you linked, doesn't show "test mode" for Helix Rack, Floor only. Even if is not explain what test perform. Oops! I forgot that the Helix Rack doesn’t have the “test” feature- only the Floor an LT models. Even if the Rack had the test, I’m not sure if it would have helped your random audio changes. Here is a link to a video which shows what tests can be done on the Helix Floor. Glad you managed to get your Rack unit working properly. Have fun. 1 1 Quote Link to comment Share on other sites More sharing options...
Pinkmania Posted April 9 Share Posted April 9 On 4/8/2022 at 8:07 PM, datacommando said: Oops! I forgot that the Helix Rack doesn’t have the “test” feature- only the Floor an LT models. Even if the Rack had the test, I’m not sure if it would have helped your random audio changes. Here is a link to a video which shows what tests can be done on the Helix Floor. Glad you managed to get your Rack unit working properly. Have fun. Wow! You're very kindly. I had forgot, but looking at that video, I remembered with previous Helix unit, who dealer changed me because encoder N° 5 didn't works just back at home, before coming back to shop I tried to push some keys at boot (not only encoder) . One of them, I can't remember which ones, sent LCD in the same screen shown in video, as You said It didn't help me. That feature is a test maybe for controls. No diagnostic! So previous Helix was replaced at once by dealer. With new unit since last 3 year I avoid "dangerous experiments"! Multi reset and reflashing, for now, seems works ;) Thank You. 1 Quote Link to comment Share on other sites More sharing options...
jaburke4 Posted May 7 Share Posted May 7 FYI-Having same lock up issue with specific presets no matter which way I approach accessing them. I now have done all prescribed resets 'following directions' with the same fault. Though it seems that it might take a day or so before it occurs. Back graded to previous firmware 3.1 and have not had the issue occur on same preset. Going to support. Note: When first occurred I had the issue with a preset I downloaded from the CustomeTone page. The last reset the issue has locked onto is a purchased preset from the MarketPlace which has never been a problem before. Quote Link to comment Share on other sites More sharing options...
melodiusthunk Posted May 21 Share Posted May 21 On 3/11/2022 at 6:57 PM, canadianjamest said: I have experienced this identical issue and am trying to work through it with a number of presets. I have never experienced anything like this in any previous firmware versions. After doing some trouble shooting on my end, the only thing that worked for me was to open HX Edit to the problem patch, then also open the "Command Center". I then would click on the button I was programing in Command Center, in my case it was button number 3, and I was programming it to select Snapshot #5 to that button in the "HX Snapshot" control menu of the command center. I would then select each snapshot using the dropdown menu/list at the top of HX Edit and I would see the snapshot assignment for that button change/revert back to "next snapshot" instead of Snapshot #5 that I initially programmed onto that button. I would then manually change it from "next snapshot" back to "Snapshot 5" that I wanted on that button, then I would save the patch. I would then select the next snapshot from the dropdown list at the top of HX Edit and continue to do that same process for each snapshot. Once I did this the changes were saved on all the snapshots and the patch would work correctly. This is definitely a bug, or if not a bug, a severe unintended consequence to the new ability to stack snapshots on one button. I have some work ahead of me to change a number of patches to get them to work correctly. I too have experienced this very same problem. Thanks for posting a workaround, and I hope the Helix team sorts this problem in the next release. Scott Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 22 Share Posted May 22 On 5/21/2022 at 3:57 PM, melodiusthunk said: I too have experienced this very same problem. Thanks for posting a workaround, and I hope the Helix team sorts this problem in the next release. Scott It's not a bug, it's the way it works now. They might have done a better job of documenting it though. Quote Link to comment Share on other sites More sharing options...
joanesinu Posted June 13 Share Posted June 13 With HX effects: I think it is a bug within the 3.15.0 firmware. Firtst, I did a factory reset on the HX device. After that, the first thing I did was to change global settings for the "Exp Pedal 2" to Ext Amp. So that jack plug will go to the amp channel input jack. The problem is that whatever I choose in the settings for "Exp pedal 1" or "Exp pedal 2", only the "Exp pedal 1" works when changing amp channel. If I plug the cable on the "Exp pedal 2" plug in the HX nothing happens whatever the settings are. Can you confirm this? Thank you Quote Link to comment Share on other sites More sharing options...
joanesinu Posted June 14 Share Posted June 14 On 6/13/2022 at 2:02 PM, joanesinu said: With HX effects: I think it is a bug within the 3.15.0 firmware. Firtst, I did a factory reset on the HX device. After that, the first thing I did was to change global settings for the "Exp Pedal 2" to Ext Amp. So that jack plug will go to the amp channel input jack. The problem is that whatever I choose in the settings for "Exp pedal 1" or "Exp pedal 2", only the "Exp pedal 1" works when changing amp channel. If I plug the cable on the "Exp pedal 2" plug in the HX nothing happens whatever the settings are. Can you confirm this? Thank you I solved the problem. I had a wrong configuration. To use the EXP pedal 2 output the Ext Amp has to be on the options of "2 None" "2 (Tip)" "2 (Ring)" or "2 (T+R)". I was using the "1 (Tip)". So, the number on the config screen indicates the output, the EXP pedal output number. 1 Quote Link to comment Share on other sites More sharing options...
GiancarloM74 Posted June 15 Share Posted June 15 Floor: Nobody noticed if using the headphone output and setting the headphone knob to zero the signal is reproduced the same but only the left side? Quote Link to comment Share on other sites More sharing options...
datacommando Posted June 15 Share Posted June 15 On 6/15/2022 at 8:34 AM, GiancarloM74 said: Floor: Nobody noticed if using the headphone output and setting the headphone knob to zero the signal is reproduced the same but only the left side? I just tested 2 pairs of headphones (Audio Technica ATH-M50x, and some cheapo Superlux HD668B) with my Helix floor. They work exactly as expected. Stereo all the way from loud down to zero. No change in balance between left and right. Check your Helix with another set of good phones that you know work correctly. If it still happens clean the headphone socket with Electric Contact Cleaner. If you still have a problem with the left channel there may be an issue with the connection to the board and you may need a service engineer to check it out. Hope this helps/makes sense Quote Link to comment Share on other sites More sharing options...
natewan Posted yesterday at 09:04 PM Share Posted yesterday at 09:04 PM HX Stomp on v3.15 Snapshots are changing parameters that I have assigned to Midi CC commands and not as Snapshot parameters. How I found the issue: It happens with any parameter assigned to a midi CC# but I found it while trying to toggle a note sync on a delay between 1/4 and 1/8 Dotted. When I change to a different snapshot the note sync goes back to what that snapshot was saved as. This parameter was not assigned as a snapshot edit. This happens with snapshot edit set to discard as well as recall. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted 19 hours ago Share Posted 19 hours ago On 6/23/2022 at 3:04 PM, natewan said: HX Stomp on v3.15 Snapshots are changing parameters that I have assigned to Midi CC commands and not as Snapshot parameters. How I found the issue: It happens with any parameter assigned to a midi CC# but I found it while trying to toggle a note sync on a delay between 1/4 and 1/8 Dotted. When I change to a different snapshot the note sync goes back to what that snapshot was saved as. This parameter was not assigned as a snapshot edit. This happens with snapshot edit set to discard as well as recall. Very strange, and not necessarily MIDI related (I duplicated it with no MIDI involvement). Have fun explaining this to support... :-) 1 Quote Link to comment Share on other sites More sharing options...
