Digital_Igloo Posted January 16, 2020 Share Posted January 16, 2020 POD Go FAQ What’s the deal with POD Go? POD Go is Line 6’s all new next generation POD, built to toss into your backpack or carry-on and take anywhere. Oh, and it’s incredibly easy to use—might be the easiest POD since the original POD in 1999. How much can you run simultaneously? Each preset in POD Go includes the following blocks: Input with Noise Gate Amp or Preamp (all HX models) Hybrid Cab from Helix—OR—1x Impulse Response (up to 128 user IRs can be loaded into POD Go via the Mac/PC editor) Preset EQ (any HX type) Wah (any HX type) Up to 4 additional effects (any HX type), with the following caveats: Three HX effects models have been omitted due to their size (Tone Sovereign, Clawthorn Drive, and Cosmos Echo) All Distortions, Dynamics, and Pitch/Synth blocks are mono only (which precludes the stereo-only 3 OSC Synth) All other effects are stereo only Volume Pedal FX Loop (mono or stereo) Output with Volume and Pan The FX Loop and Preset EQ blocks are automatically assigned to stomp switches, and adding any additional effects automatically assigns them to the remaining stomp switches. Press and hold any two stomp switches to swap them. If it has nearly all models from HX and Helix products, why call this a POD at all? The original POD set the standard for ease-of-use in digital guitar and bass products. We wanted POD Go to be ridiculously easy-to-use, which meant purposefully omitting some power user features one would expect to find in HX or Helix-branded products. And not putting the best modeling possible in a box just because it happens to be less expensive—or have a different name—is weak sauce. What about some of the cooler Helix features like Snapshots, color switch rings, block copy/paste, 3-second footswitch assignment, 3-second controller assignment, multichannel USB audio, and re-amping? POD Go has all of these. So can you use this on professional gigs? Of course. The main outputs on POD Go are balanced/unbalanced and with TRS 1/4” to XLR M cables, can feed the front-of-house mixer—in stereo—without additional DI boxes. Then the 1/4” AMP OUT can be sent to your amp onstage (either echoing the Main Outs or tapped off before the Cab/IR block). The routable stereo send/return jacks can be used for 4-Cable Method. Is there a Mac/PC editor? Yes. POD Go Edit is available now. Does POD Go have an audio interface? Yes. POD Go has a 4-in/4-out audio/MIDI interface with re-amping built in. Why didn’t you put VDI, L6 LINK, AES/EBU, S/PDIF, MIDI, parallel paths, dual DSPs, cap-sense switches, scribble strips, blah blah blah?! Because POD shouldn’t cost what Helix costs. Dimensions/weight? Is it smaller than POD HD500X? 14.1”w x 9.1”d x 3.5”h; 5.2lbs It’s way smaller and lighter than POD HD500X. Fits inside pretty much any backpack or carry-o What’s the price? POD Go sells for $449.99 US street. When is POD Go shipping? April. Input/Output Impedance Chart Quote Link to comment Share on other sites More sharing options...
deidelberg Posted January 16, 2020 Share Posted January 16, 2020 Looks like it could fill a nitch! Now we need some of those low dsp blocks added to stomp. And at least one full usage block (if not two) and let us figure out what will fit. ;-) Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 16, 2020 Share Posted January 16, 2020 Are the four "pick your own" blocks freely configurable in the signal chain? 1 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted January 16, 2020 Share Posted January 16, 2020 Is there a looper block? Personally, I would never consider an all-in-one guitar modeling unit without one anymore... And I don't exactly get this: "The FX Loop and Preset EQ blocks are automatically assigned to stomp switches" - does that mean it's a must to have them assigned or is that just the default state (I would guess it's the latter). Will Helix Native see some POD Go compatibility mode? Can you bypass the amp block? Quote Link to comment Share on other sites More sharing options...
lazerdriver Posted January 17, 2020 Share Posted January 17, 2020 Appealing in many ways...but no digital out = no-GO for me. Digital out on every variant of Pod since X3 until this. Guess you can't please everyone. Wait for v2 or maybe a desktop version (BRING BACK THE BEAN!). Won't hold my breath. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted January 17, 2020 Share Posted January 17, 2020 Given that the two smaller Helix siblings (Stomp, FX) don't have digital outs, either, I wouldn't hold my breath. Quote Link to comment Share on other sites More sharing options...
Matt_Brown Posted January 17, 2020 Share Posted January 17, 2020 The pic I saw didn't have a Variax port or line 6 link so no integration... Going for a new market (again). Quote Link to comment Share on other sites More sharing options...
joel_brown Posted January 17, 2020 Share Posted January 17, 2020 It's $449 bucks. You want the other stuff then buy the Helix . They had to cut features to make it cheap. I think they did a great job. 4 2 Quote Link to comment Share on other sites More sharing options...
usta28 Posted January 17, 2020 Share Posted January 17, 2020 I would LOVED to have an Helix of this size, with a price between the hx stomp and the helix lt. I sold my helix lt because it was too big, I hope I can keep myself from buying this, especially if there will be an helix of this size at some point. Also I wonder if there will be a new pod vst that's basically this unit in vst form? edit: I do agree that this is a great move to get into the market where mooer, nux, joyo and hotone are roaming and this sounds ALOT better and is cheaper. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 17, 2020 Share Posted January 17, 2020 2 hours ago, usta28 said: I hope I can keep myself from buying this, especially if there will be an helix of this size at some point. This IS a Helix of this size. Or did you not read the description? 4 Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 17, 2020 Share Posted January 17, 2020 Gee whiz. If only I didn't already have fully functional gear that does everything I need it to do. ---- plus my boycott of all things Yamaha. 1 Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 17, 2020 Share Posted January 17, 2020 Aww, I just read no momentary switches....LAME Quote Link to comment Share on other sites More sharing options...
usta28 Posted January 17, 2020 Share Posted January 17, 2020 1 hour ago, pianoguyy said: This IS a Helix of this size. Or did you not read the description? "The original POD set the standard for ease-of-use in digital guitar and bass products. We wanted POD Go to be ridiculously easy-to-use, which meant purposefully omitting some power user features one would expect to find in HX or Helix-branded products" I hope this clears up this ISN'T a helix because it misses alot of features that would make it an Helix (why would they otherwise call it a POD right?) .. Yes, it DOES use the helix amps and effects, but that DOESN'T make it a Helix. BUT, this WOULD be a great product for anyone that uses an Helix (as a backup) in case the helix would fart out live on stage (which I highly doubt!) anyway have a good day :p . Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted January 17, 2020 Share Posted January 17, 2020 32 minutes ago, usta28 said: I hope this clears up this ISN'T a helix because it misses alot of features that would make it an Helix No kidding, it is missing a lot of features. For that matter, so is the Helix LT. If you want all of the features, you have to buy the big one. 35 minutes ago, usta28 said: why would they otherwise call it a POD right Perhaps you are confusing the word Pod with HD. Quote Link to comment Share on other sites More sharing options...
usta28 Posted January 17, 2020 Share Posted January 17, 2020 51 minutes ago, pianoguyy said: No kidding, it is missing a lot of features. For that matter, so is the Helix LT. If you want all of the features, you have to buy the big one. yea, the LT misses some connections, knobs and led name strips, but the software it runs on is EXACTLY the same as the regular Helix. Even the HX stomp runs on exactly the same software, if you don't count the 6 block limit. This one just runs the same amp and effect models. But I don't want to get off topic too much, I'm sure I'll probably buy this one.. The size is just perfect. But I have to try it in a store first, so I can be sure I won't need more than what it can do. (I'm pretty sure at this point that it can do all I need). I also hope that buyers of this can get the discount on helix native.. Or at least another VST that has these helix amps and effects. Quote Link to comment Share on other sites More sharing options...
Jugghaid Posted January 18, 2020 Share Posted January 18, 2020 This may be a perfect smaller solution for my much-less-complicated bass rig as opposed to my full helix setup for my guitar rig. Quote Link to comment Share on other sites More sharing options...
cgiles001 Posted January 18, 2020 Share Posted January 18, 2020 I am so excited for this! I own the LT and I've owned the stomp and HX effects. All amazing products but this looks like the right fit! I feel like Goldylocks up in here! April can't come soon enough! Quote Link to comment Share on other sites More sharing options...
hkremer Posted January 18, 2020 Share Posted January 18, 2020 Curious if the sound will suffer due to there being only one vs. two DSP chips. Or does that just cut down on simultaneous blocks etc. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 18, 2020 Share Posted January 18, 2020 3 hours ago, hkremer said: Curious if the sound will suffer due to there being only one vs. two DSP chips. Even with only one DSP the models per se will behave identically to those of the big brothers (a single modern DSP is enough for one HX amp model plus a few blocks), but overall if in the chain there are some FXs in addition to the amp model the device final tone will be somewhat different due to the device input having a fixed 1 megahom impedance. A variable/automatically adaptable impedance is one of the factors which made the difference between the Eleven Rack, POD HD, Axe FX and the previous old modeling technology devices, ie to get a response of the models more faithful to that of to the real things modeled. The above observation doesn't mean that you can't get good results from the models even having only a fixed 1 megahom impedance input circuit, but unless the LT or HX patches are set on purpose to use a fixed 1 megahom impedance instead of automatically changing the impedance depending on the first FX in the chain, the POD GO and its big brothers will sound somewhat different from each other. If this were not true, it would mean that in all these years the modelers makers have made fun of us with the importance of having variable/automatically adaptable impedance to obtain even more realistic results. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
qwpeoriu Posted January 19, 2020 Share Posted January 19, 2020 Can POD Go patches be imported into the Helix editor? POD Go looks awesome and I can see myself using it to get ideas down quickly, but then refining my tone later on in Helix Native. And yeah, I would not expect to be able to go the other way around (import Helix patches into POD Go), not concerned about that use case. Quote Link to comment Share on other sites More sharing options...
joel_brown Posted January 19, 2020 Share Posted January 19, 2020 It's $449 dollars and it's sound is on par with the Helix or AXE FX. Thank you Line6 for finding a way to make great tone very affordable. 1 Quote Link to comment Share on other sites More sharing options...
hkremer Posted January 19, 2020 Share Posted January 19, 2020 16 hours ago, hurghanico said: A variable/automatically adaptable impedance is one of the factors which made the difference between the Eleven Rack, POD HD, Axe FX and the previous old modeling technology devices, ie to get a response of the models more faithful to that of to the real things modeled This is interesting. I don’t quite understand the electronics, but your description makes sense. 11 minutes ago, joel_brown said: It's $449 dollars and it's sound is on par with the Helix or AXE FX On par, yes, but with half the DSP. For me the price is irrelevant. What I’m looking for is compact, which is why I looked at this in the first place. The Helix are too big (for me). So I’m waiting for compact/modern/high DSP. See the Neural Quad Cortex coming out next year. Quad SHARC in a small package. Of course it’s even more expensive than the Helix. If Line6 could do something like that I would be all over it. Currently I’m going HX EFX into a Bias head, and I’m happy with that. 1 Quote Link to comment Share on other sites More sharing options...
bluesounds Posted January 20, 2020 Share Posted January 20, 2020 Will the Go accept program (preset) change info from a DAW via MIDI and the USB port? Seems to me that Line6 put quite a bit of thought into this and created a leap forward in quality, features, and as usual, bang for the buck. Rock on! Quote Link to comment Share on other sites More sharing options...
rpschultz13 Posted January 20, 2020 Share Posted January 20, 2020 Can the stereo return be used as inputs and mixed together for a mono out... like Helix does? 1 Quote Link to comment Share on other sites More sharing options...
usta28 Posted January 20, 2020 Share Posted January 20, 2020 that would be a great feature! I guess they can perhaps implement it with a software update if it doesn't do it already. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 20, 2020 Share Posted January 20, 2020 6 hours ago, rpschultz13 said: Can the stereo return be used as inputs and mixed together for a mono out... like Helix does? As you can check by yourself by reading the already dowloadable POD GO CHEAT SHEET the stereo RETURN can be used as AUX stereo input. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
rpschultz13 Posted January 20, 2020 Share Posted January 20, 2020 1 hour ago, hurghanico said: As you can check by yourself by reading the already dowloadable POD GO CHEAT SHEET the stereo RETURN can be used as AUX stereo input. Ok good to know. But that assumes they are route to the stereo output. It doesn’t answer whether those inputs can be mixed or blended together with separate gain and effects and routed to a mono output like Helix can do on a single dsp. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted January 20, 2020 Share Posted January 20, 2020 53 minutes ago, rpschultz13 said: It doesn’t answer whether those inputs can be mixed or blended together with separate gain and effects and routed to a mono output like Helix can do on a single dsp. I don't know the official answer, most likely the 2 inputs Guitar in and Aux/Return (if both used) signals will be mixed together but the chain with its settings, effects and amp will be just one and shared. To get 2 independent separately processed (mono) lines you need the big HX brothers, or even the old HD500/X. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted January 23, 2020 Author Share Posted January 23, 2020 On 1/19/2020 at 6:08 AM, qwpeoriu said: Can POD Go patches be imported into the Helix editor? POD Go looks awesome and I can see myself using it to get ideas down quickly, but then refining my tone later on in Helix Native. And yeah, I would not expect to be able to go the other way around (import Helix patches into POD Go), not concerned about that use case. Nope; POD and Helix/HX are different lines. In the future, we *may* (read: TBD) allow copy/paste of individual blocks from POD Go Edit to HX Edit, but we have no current plans to support full preset conversion. On 1/20/2020 at 4:59 AM, rpschultz13 said: Ok good to know. But that assumes they are route to the stereo output. It doesn’t answer whether those inputs can be mixed or blended together with separate gain and effects and routed to a mono output like Helix can do on a single dsp. When Global Settings > Ins/Outs > Return Type is set to "Aux In", the Return acts as a stereo input that is mixed in with the processed output. There is never any processing on the Aux Input signal. It's designed for jamming along with iPods, mixers, etc. Oh, and we now have an official POD Go subforum: https://line6.com/support/forum/97-pod-go/ Quote Link to comment Share on other sites More sharing options...
kkdarling Posted January 23, 2020 Share Posted January 23, 2020 (edited) On 1/17/2020 at 12:30 PM, gunpointmetal said: Aww, I just read no momentary switches....LAME On the back of the POD GO, there is a Switch Input where you can connect 2 EXTRA SWITCHES, VIA A "Y CABLE." Maybe someone at Line 6 will read this and verify. If using a Y Cable to add 2 extra switches, I see no reason 1 of these couldn't be Momentary!! Edited January 23, 2020 by kkdarling Misspelled a word!...PID, instead of POD!! 1 Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted January 23, 2020 Share Posted January 23, 2020 2 hours ago, kkdarling said: On the back of the POD GO, there is a Switch Input where you can connect 2 EXTRA SWITCHES, VIA A "Y CABLE." Maybe someone at Line 6 will read this and verify. If using a Y Cable to add 2 extra switches, I see no reason 1 of these couldn't be Momentary!! I think the way it's set up that control option is not available for any of the switches, internal or external. On another forum DI replied that momentary SNAPSHOT functionality would be there, so that works for me, I think. The appeal of the POD Go is that it can be can be a backup for my Helix floor with the same amp models and IRs and I don't need any external switches or pedals. I had been eyeing up the HX Stomp for this purpose, but the block limit, as well as needing a volume pedal or external EXP pedal and a MIDI controller to use it was not something I wanted to get in to. I want as few pieces of gear on stage as possible. Sold all my stomp boxes 10+ years ago and haven't bought another one since. Quote Link to comment Share on other sites More sharing options...
kkdarling Posted January 23, 2020 Share Posted January 23, 2020 Getting rid of my almost 40 pound Pedalboard is what's making the POD GO so appealing to me as well as feeling your pain!! That and NOT having to also tote around my Marshall DSL as well and just taking a LIGHTWEIGHT FRFR Speaker makes setting up and tearing down a breeze. I had Roadies back in the 80's. Their all gone now so it's just my Spine and me! Lol... I'm not getting any younger and after 45+ years of performing, the GO seems like the best choice for me. I was going between the Helix LT and the Headrush primarily, while also keeping the Boss GT-1000 in the back of my mind. I have 3 basic Amp Tones....Clean, Gain and a slightly Heavier Gain for Leads. The vast majority of my Effects are Modulation and a couple of Delays while also needing a Harmonizer. Line 6 NAILED the Eventide Harmonizer, sounding like the Smart Harmony built in to everything from the M-Series to the Helix. The Twin Harmony from the HD500X would have been fine however, I really fell in love with the Smart Harmony while using the HX for a short while. It's going to be wonderful just running a couple of Cables to the FOH.....Sound System... then a line to a single FRFR as my personal Monitor. I'm sure that's really going to make, not only our Soundman, also the rest of the band happy as well! After FINALLY getting a Representative from Line 6 on the Phone, he answered EVERY question I had. Now, I just have to decide between the LT and the POD GO!!!....UGGHHHH!! I just basically want my 3 tones from my Amp with the Modulations I can just turn on and off....those rarely change, have the Tap Tempo for my ON BOARD Delay as well as a separate Tap for the Echoplex. That's an Outboard Pedal which runs directly into the front of whichever Amp I choose. That's all I need!! I can FINALLY retire my old Vintage Thomas Organ Wah!! That was the first Effect Pedal I received.....I was 10 at the time......and it was used. I'm old but not that old...lol! I have a small Pedalboard Case these will fit in to and I can have it as a "Carry on" whenever I fly. I won't have to worry about Backlines anymore, as well as not having to worry about my BACK finally saying, it's enough!!...LOL... Take care and good luck! Quote Link to comment Share on other sites More sharing options...
urbansoban Posted January 25, 2020 Share Posted January 25, 2020 Can the blocks be moved/doubled in the signal chain? More particularly the IR block? This is a deal breaker for me. The reason why I’m asking this is because I play quite a lot of acoustic guitar and electric violin. These instruments use piezos that sound harsh and unnatural, but if you run their dry signal through an impulse response of a quality acoustic instruments, the results are really good and convincing at least for live use. But such IR blocks must come before FX such as EQ, delay, reverb and modulation that are typically used with acoustic sounds, not after as is the case with the electric guitar scenario (preamp - above FX - cab IR). Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 25, 2020 Share Posted January 25, 2020 29 minutes ago, urbansoban said: Can the blocks be moved/doubled in the signal chain? More particularly the IR block? This is a deal breaker for me. The reason why I’m asking this is because I play quite a lot of acoustic guitar and electric violin. These instruments use piezos that sound harsh and unnatural, but if you run their dry signal through an impulse response of a quality acoustic instruments, the results are really good and convincing at least for live use. But such IR blocks must come before FX such as EQ, delay, reverb and modulation that are typically used with acoustic sounds, not after as is the case with the electric guitar scenario (preamp - above FX - cab IR). Any of the blocks can be moved anywhere in the chain, so, yeah, you can do what you want with the IR. As far as doubling blocks, you can have multiple instances of the same effect in any of the four wild card slots (as long as you're within the DSP limits). You can't have multiple instances of any of the fixed blocks, though. Quote Link to comment Share on other sites More sharing options...
yggorus Posted January 26, 2020 Share Posted January 26, 2020 Hi Line6 guys. Straight one - are you plan also to have a "bean" version of this unit? GO looks great, but even greater would have all the same sounds and DSP in even smaller package. Quote Link to comment Share on other sites More sharing options...
TRENDKILLCFH333 Posted January 27, 2020 Share Posted January 27, 2020 Are the 4 preset blocks changeable? Meaning, can I alter a preset to have only effects (no amps, cabs, eq, wah) so I can essentially use this unit as an HX Effects with expression pedal to use it with tube amps via 4cm? Quote Link to comment Share on other sites More sharing options...
MalcolmPaterson Posted January 28, 2020 Share Posted January 28, 2020 Digital Igloo, can the POD Go toggle between two values of one or more parameters as well as toggle one or more blocks on and off? Quote Link to comment Share on other sites More sharing options...
chasingMango Posted January 29, 2020 Share Posted January 29, 2020 19 hours ago, MalcolmPaterson said: Digital Igloo, can the POD Go toggle between two values of one or more parameters as well as toggle one or more blocks on and off? It utilizes snapshots, so yes. Quote Link to comment Share on other sites More sharing options...
marhil Posted January 29, 2020 Share Posted January 29, 2020 Can the main outputs and amp out be used simultaneously ? For example having the main outs connected to mixer/PA speakers and then connect the amp out to my amp for a monitor for my guitar. Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 29, 2020 Share Posted January 29, 2020 1 minute ago, marhil said: Can the main outputs and amp out be used simultaneously ? For example having the main outs connected to mixer/PA speakers and then connect the amp out to my amp for a monitor for my guitar. Yes. Quote Link to comment Share on other sites More sharing options...
