phil_m Posted April 27, 2020 Share Posted April 27, 2020 8 hours ago, andrewastin said: I have a Helix LT which I have just updated to the latest version (2.91) and HX Edit at 2.81. The Revv Gen Purple model is not showing in the amp lists on my HX edit. You need to update HX Edit. 1 Quote Link to comment Share on other sites More sharing options...
The_Elf Posted April 27, 2020 Share Posted April 27, 2020 No, no, no guys!!!!!! I have to correct you. The tap light was always in sync. It wasn't 100% accurate, but it was always very close. It was me that hassled them to fix it so that it was 100% accurate, and one of the 2.8 releases finally fixed it fully. From 2.8x (I don't recall which) it was 100% accurate and would stay synced to the delay time over several minutes. I know - I tested it, and have been using it for improv performance on stage ever since! I won't bore anyone with the details, but being able to see a light to guide my loop/delay improv is critical to me, hence me wanting it sorted out properly. Thankfully they did. It was perfectly possible to rely on it as a visual metronome - even before it was 100% Clearly most people didn't know it had been fixed, but I certainly did. Sadly it's now more broken than it ever was. What is the use of a tap tempo light that doesn't reflect the tempo!?! Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted April 27, 2020 Share Posted April 27, 2020 6 minutes ago, The_Elf said: No, no, no guys!!!!!! I have to correct you. The tap light was always in sync. It wasn't 100% accurate, but it was always very close. It was me that hassled them to fix it so that it was 100% accurate, and one of the 2.8 releases finally fixed it fully. From 2.8x it was 100% accurate and would stay synced to the delay time over several minutes. I know - I tested it, and have been using it for improv work stage for months! I won't bore anyone with the details, but being able to see a light to guide my loop/delay work is critical to me, hence me wanting it sorted out properly. Clearly most people didn't know it had been fixed, but I certainly did. What is the use of a tap tempo light that doesn't reflect the tempo!?! I find the tap tempo light to work fine, always have. 1 Quote Link to comment Share on other sites More sharing options...
The_Elf Posted April 27, 2020 Share Posted April 27, 2020 1 hour ago, PeterHamm said: I find the tap tempo light to work fine, always have. Not if you were using delays with long, LONG repeat trails over a couple of minutes (I know, don't ask - it's just a specialist requirement of what I do! ). But it was fixed. Now it's not fixed and much worse. Hopefully they can figure out what broke it and get it back in time. Quote Link to comment Share on other sites More sharing options...
Mudskipper75 Posted April 27, 2020 Share Posted April 27, 2020 Hello, HX Edit ist not able to List the new 2.9 Effects. On my Effects ist 2.91 installed, i can choose per example the Rochester Comp and i want to edit it per HX Edit on my PC. But the HX Edit cannot find all new 2.9 Effects on my HX Effects. All other Effects are there, ready to edit via HX Edit and visible. Quote Link to comment Share on other sites More sharing options...
jdomine Posted April 27, 2020 Share Posted April 27, 2020 On 4/25/2020 at 6:56 PM, droe5577 said: Same here on LT. Was working in HX Edit for about an hour, and somewhere along the line everything locked. Edit could not save the patch to the unit tand the unit was completely unresponsive despite producing tone and responding to edits from HX Effects the entire time. If you unplug the USB cable after it has become unresponsive does that snap it back into functioning? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted April 27, 2020 Share Posted April 27, 2020 3 hours ago, PeterHamm said: I find the tap tempo light to work fine, always have. I could post a video proving that statement wrong. The LED is always flashing a tad slower compared to the delay repeats (at 1/4, of course). Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 27, 2020 Share Posted April 27, 2020 1 hour ago, Mudskipper75 said: Hello, HX Edit ist not able to List the new 2.9 Effects. On my Effects ist 2.91 installed, i can choose per example the Rochester Comp and i want to edit it per HX Edit on my PC. But the HX Edit cannot find all new 2.9 Effects on my HX Effects. All other Effects are there, ready to edit via HX Edit and visible. You need to update HX Edit... Seriously, folks... I’ve posted this reply about a dozen times in this thread. If you don’t see new effects or amps in HX Edit, it means you’re running an outdated version of HX Edit. It’s literally Step 1 of the instructions for updating. 2 2 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted April 27, 2020 Share Posted April 27, 2020 6 minutes ago, phil_m said: It’s literally Step 1 of the instructions for updating. Yeah well - to quote Digital Igloo from the update instructions: Quote IMPORTANT! Carefully read and follow the update instructions below. If you don't—and then run to the forums asking why it's not working—the interwebs will make fun of you. Maybe the interwebs were too polite so far... 1 Quote Link to comment Share on other sites More sharing options...
Mudskipper75 Posted April 27, 2020 Share Posted April 27, 2020 Learned my lesson: don`t work 14h Hours straight an then do updates with tired mind and eyes. I was so sure that I downloaded Edit 2.9 but is was still 2.8 - sorry folks! 2 1 Quote Link to comment Share on other sites More sharing options...
ivanmongiardo Posted April 30, 2020 Share Posted April 30, 2020 After upgrading my HxEffects firmware to 2.91 version, the output volume is lower by -6dB circa. Please note that I've already checked this on my DAW, with the same output settings (instruments) on my HxEffects, same guitar, same patch, same routing, same project, and I've compared a new take with the older one I've recorded 2 days before the new firmware. So, it's definetly a bug or a new behavior from the last firmware and from my testing is related to the IR block. Quote Link to comment Share on other sites More sharing options...
ivanmongiardo Posted April 30, 2020 Share Posted April 30, 2020 After upgrading my HxEffects to 2.91 firmware,I can here a dry signal coming out from Hx Effects while the tuner is ON even if the setting for the tuner is to mute the guitar signal. With the previous firmware everything was OK. Quote Link to comment Share on other sites More sharing options...
ivanmongiardo Posted April 30, 2020 Share Posted April 30, 2020 After upgranding my HxEffects to 2.91, I've noticed a strange behavior if I put a stereo double tracking block just before a/b split. It seems that the final R channel has 6dB less volume than the L channel. Quote Link to comment Share on other sites More sharing options...
ivanmongiardo Posted April 30, 2020 Share Posted April 30, 2020 On 4/26/2020 at 5:35 PM, adennis said: I have the same issue on my HX FX. Also, with a snapshot assigned to FS5 it sometimes takes two taps to actually change snapshots. I assume it’s a bug. It seems to work correctly if I use FS1-FS3 for my snapshots instead of FS4-FS6. I have the same issue on my Hx Effects Quote Link to comment Share on other sites More sharing options...
molul Posted April 30, 2020 Share Posted April 30, 2020 I saw another tap tempo bug: if you set your tremolo rate with the tap tempo, it won't match either what you pressed or the led light. I'm submitting a support ticket. Quote Link to comment Share on other sites More sharing options...
AlexDT665 Posted May 1, 2020 Share Posted May 1, 2020 Hi guys Hope you’re staying safe and ok with your families, while these tough times indeed. i have purchased my Helix Floor(second hand, but in perfect shape) a year ago and mostly used it onstage. Right now, we have much more time to spend at home and I tried to make some recordings using DAW(Reaper) and faced annoying trouble... once I’m plugged I’m hearing some hum and clicks (ticks) whatever I may call it... I hoped it’s monitoring defect, but hellno, it’s been recorded as well... it makes studio work impossible... could please share your experience? Thanks fellows!!! Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted May 1, 2020 Share Posted May 1, 2020 8 hours ago, AlexDT665 said: Hi guys Hope you’re staying safe and ok with your families, while these tough times indeed. i have purchased my Helix Floor(second hand, but in perfect shape) a year ago and mostly used it onstage. Right now, we have much more time to spend at home and I tried to make some recordings using DAW(Reaper) and faced annoying trouble... once I’m plugged I’m hearing some hum and clicks (ticks) whatever I may call it... I hoped it’s monitoring defect, but hellno, it’s been recorded as well... it makes studio work impossible... could please share your experience? Thanks fellows!!! Check your sample rate settings in your DAW as well as in your Helix Floor Global settings. Make sure they match. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted May 1, 2020 Share Posted May 1, 2020 1 hour ago, PeterHamm said: Check your sample rate settings in your DAW as well as in your Helix Floor Global settings. Make sure they match. The settings on the Helix are only relevant in case you record via SPDIF, otherwise you can leave them at any setting. I would rather try to raise the buffer size in Reaper (and obviously not record at sample rates higher than 44.1kHz or 48kHz, to keep the CPU load in check). Quote Link to comment Share on other sites More sharing options...
DimSam Posted May 1, 2020 Share Posted May 1, 2020 On 4/26/2020 at 4:35 PM, adennis said: I have the same issue on my HX FX. Also, with a snapshot assigned to FS5 it sometimes takes two taps to actually change snapshots. I assume it’s a bug. It seems to work correctly if I use FS1-FS3 for my snapshots instead of FS4-FS6. Exactly the same problem.Renders the 6 footswitch mode useless for snapshot inclusion. Quote Link to comment Share on other sites More sharing options...
PaulJam Posted May 1, 2020 Share Posted May 1, 2020 Device: HELIX Floor Firmware: 2.91 Global Settings: Footswitches/Stomp Select [Press] Bug: Stomp switches react with a noticeable delay Hi, I have a HELIX with firmware v2.91. Ever since I upgraded to firmware v2.8x I had the problem, that there was a noticeable audible delay (maybe 100 to 200 ms) between pressing a switch in stomp mode and the bypass state of the assigned pedals actually changing. This is especially annoying when changing between a clean and an overdrive sound. Today i played around a bit with the global settings and found out what setting causes the delay. If the setting "Stomp Select" under "Footswitches" is set to "Press" or "Touch+Press" the delay is there. When selecting "Off" or "Touch" the foot switches react immediately without any noticeable delay. Can anyone confirm this behavior or add other useful information before I submit a support ticket? Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted May 2, 2020 Share Posted May 2, 2020 2 hours ago, PaulJam said: Can anyone confirm this behavior or add other useful information before I submit a support ticket? Can't confirm. it's working fine over here with any setting. Quote Link to comment Share on other sites More sharing options...
bwQuestion Posted May 2, 2020 Share Posted May 2, 2020 Because of the tap tempo issue, I had to roll back to 2.82 from the 2.9. I can confirm that on 2.82, the tempo light and the timing of the unit are sync'd. What I can also say is that if I play a lick on the up beat the delay will happen when the light is off, thus giving the impression that they are not together, but they are. The light is flashing the time from when it was put in. The sound of the effect is timed from when the note is struck. It is very possible that all of you disagreeing about the light are all correct. On 2.82, if you play in time with the light, the sound will be in time with the light. If you do not play in time with the light, the sound will not be in time with the light, but it will be in the correct time. Hope that helps. Quote Link to comment Share on other sites More sharing options...
molul Posted May 3, 2020 Share Posted May 3, 2020 On 5/2/2020 at 4:42 AM, bwQuestion said: Because of the tap tempo issue, I had to roll back to 2.82 from the 2.9. I can confirm that on 2.82, the tempo light and the timing of the unit are sync'd. What I can also say is that if I play a lick on the up beat the delay will happen when the light is off, thus giving the impression that they are not together, but they are. The light is flashing the time from when it was put in. The sound of the effect is timed from when the note is struck. It is very possible that all of you disagreeing about the light are all correct. On 2.82, if you play in time with the light, the sound will be in time with the light. If you do not play in time with the light, the sound will not be in time with the light, but it will be in the correct time. Hope that helps. I'm rolling back to 2.82 as well. I was only using the new phaser, but I can use another one instead while they fix this. EDIT: just rolled back, and tap tempo light matches the rhythm in delays and modulation effects. Can wait for next update :) Quote Link to comment Share on other sites More sharing options...
daniel_john Posted May 3, 2020 Share Posted May 3, 2020 On 4/26/2020 at 5:35 PM, adennis said: I have the same issue on my HX FX. Also, with a snapshot assigned to FS5 it sometimes takes two taps to actually change snapshots. I assume it’s a bug. It seems to work correctly if I use FS1-FS3 for my snapshots instead of FS4-FS6. I found the same problem in my Hx Effects updated. Hope they solve it soon! Quote Link to comment Share on other sites More sharing options...
Melissiah Posted May 3, 2020 Share Posted May 3, 2020 Rolling back to 2.9 Updating to 2.91 helix floor freeze at recovering preset #581. Reboot and start from 582. did the update a 2nd Time and ils the same. But my real bug now: when I assign a snapshot, the camera logo is not there. It looks like a stomp. Bigger bug. I cannot know on which snapshot I’m on cause the light doesnt get brighter. Like a stomp always off. Tried with a computer and with the floor alone... Quote Link to comment Share on other sites More sharing options...
molul Posted May 4, 2020 Share Posted May 4, 2020 5 hours ago, Melissiah said: Rolling back to 2.9 Updating to 2.91 helix floor freeze at recovering preset #581. Reboot and start from 582. did the update a 2nd Time and ils the same. But my real bug now: when I assign a snapshot, the camera logo is not there. It looks like a stomp. Bigger bug. I cannot know on which snapshot I’m on cause the light doesnt get brighter. Like a stomp always off. Tried with a computer and with the floor alone... Could you post a pic of that? Not sure what this problem means :( Quote Link to comment Share on other sites More sharing options...
Melissiah Posted May 4, 2020 Share Posted May 4, 2020 17 hours ago, molul said: Could you post a pic of that? Not sure what this problem means :( Snapshot 6 havent been edited. So it keeps the camera logo and the led is working as it should be. it’s only happening in 10 FS mode when I assign snapshot there. It was ok in 2.90. 2.91 screwed mine 1 clean 2 heavy 3 lead 4 piezzo 5 dirt as you can see one the screen i’m on snapshot #2 but the light is always like this whatever snapshot IM on Quote Link to comment Share on other sites More sharing options...
Melissiah Posted May 4, 2020 Share Posted May 4, 2020 Look here. This patch was made before 2.91 and it’s still working. 10 fs mode with mix of snaphot and stomps. Quote Link to comment Share on other sites More sharing options...
molul Posted May 5, 2020 Share Posted May 5, 2020 Oops! I think I lack the knowledge to understand the problem, sorry ^_^U I don't mean to bother you, but I'd need a deeper explanation of the problem, although other users will most likely be able to help you with the info you already posted. Another option is to send line6 a bug report. Sorry for not being very helpful :( Quote Link to comment Share on other sites More sharing options...
JoseK Posted May 6, 2020 Share Posted May 6, 2020 Using Helix LT v2.91. Have anyone else noticed that using the 3-band compressor the gain reduction metering is not very responsive? Well it is for a few seconds and then it starts to lag. After about a minute of enabling the compressor there is 2-5 seconds of delay on the meters. I think it is still doing what I want but the feature is not that helpful at this point. Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 6, 2020 Share Posted May 6, 2020 On 5/4/2020 at 11:45 PM, Melissiah said: Snapshot 6 havent been edited. So it keeps the camera logo and the led is working as it should be. it’s only happening in 10 FS mode when I assign snapshot there. It was ok in 2.90. 2.91 screwed mine 1 clean 2 heavy 3 lead 4 piezzo 5 dirt as you can see one the screen i’m on snapshot #2 but the light is always like this whatever snapshot IM on This picture is a little confusing. The Command Centre image is showing what is assigned to FS9 (Heavy) not what is assigned to FS4 (Snapshot6). Does this still happen if you reprogram FS4 to something else? Quote Link to comment Share on other sites More sharing options...
Melissiah Posted May 6, 2020 Share Posted May 6, 2020 2 hours ago, datacommando said: This picture is a little confusing. The Command Centre image is showing what is assigned to FS9 (Heavy) not what is assigned to FS4 (Snapshot6). Does this still happen if you reprogram FS4 to something else? That’s the problem. Heavy is the snapshot. But the camera logo is not showing on the screen and the led does’nt gent brighter when I use the snapshot created in 2.91 1 Quote Link to comment Share on other sites More sharing options...
datacommando Posted May 6, 2020 Share Posted May 6, 2020 5 hours ago, Melissiah said: That’s the problem. Heavy is the snapshot. But the camera logo is not showing on the screen and the led does’nt gent brighter when I use the snapshot created in 2.91 Ahh! Now I understand the issue. It is not something that I have experimented with to any extent just yet. Maybe best to raise a ticket with support, unless someone else knows what may be causing the problem. Sorry, I’m not able to assist this time. Quote Link to comment Share on other sites More sharing options...
JSP552003 Posted May 7, 2020 Share Posted May 7, 2020 Anyone else having issues with the tuner becoming unresponsive? Helix LT. Updated from 2.8x straight to 2.91. Tuner works fine for a while after booting up but eventually lags or doesn’t track guitar at all. If I reboot, tuner works fine again for a while. I tried changing input to guitar only. I guess we’ll see what happens but something definitely isn’t right. 2 1 Quote Link to comment Share on other sites More sharing options...
AlMurdoch Posted May 7, 2020 Share Posted May 7, 2020 Tuner doesnt work all the time after the 2.91 update. When i engage the tuner the signal does not mute and although the tuner appears on the screen, there is no signal going into tuner. This usually happens on first power up of the day. The only way to fix it is to turn the unit off and on. 1 Quote Link to comment Share on other sites More sharing options...
The_Elf Posted May 8, 2020 Share Posted May 8, 2020 Happy to see folks noticing that the delays and tempo light *were* totally in sync in 2.82. I know because it was a big deal for me! You could absolutely rely on the tempo light as a visual metronome in that release. Line 6 are a responsive team, and I'm hopeful that they will get it back to that state in a future update. Quote Link to comment Share on other sites More sharing options...
aholland Posted May 8, 2020 Share Posted May 8, 2020 Unable to turn off Touch In 2.7 > in Global Settings > Footswitches - the first selection was Touch Select. The user had the option to turn it on or off. It seems that in 2.9.1, that became Stomp Select with - Off, Touch, Press and Touch & Press. I turned it to OFF but I am still getting messages asking if I want to swap snapshots. Adjusting the setting appears to turn off only disables the touch to select, aka short touch. But the touch feature is still enabled with a long touch. Quote Link to comment Share on other sites More sharing options...
ptaubert Posted May 9, 2020 Share Posted May 9, 2020 Hello there, There seems to be a phasing issue with the Whammy effect. As soon as you go up for some semi tones and go back to normal the complete signal is out of phase. Never had this issue before. I controlled the whammy effect block via the on board expression pedal. If needed I can make a recording. My Helix is on firmware version 2.91.0. The used effect chain is quite simple: Facial Fuzz -> Kinky Boost -> Whammy -> Amp Would be great if this could be fixed soon, thank you! Best, Philipp Quote Link to comment Share on other sites More sharing options...
molul Posted May 9, 2020 Share Posted May 9, 2020 37 minutes ago, ptaubert said: Hello there, There seems to be a phasing issue with the Whammy effect. As soon as you go up for some semi tones and go back to normal the complete signal is out of phase. Never had this issue before. I controlled the whammy effect block via the on board expression pedal. If needed I can make a recording. My Helix is on firmware version 2.91.0. The used effect chain is quite simple: Facial Fuzz -> Kinky Boost -> Whammy -> Amp Would be great if this could be fixed soon, thank you! Best, Philipp If you want it fixed, you should report it through customer support. The community forum is meant for users to help each other :) 1 Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted May 11, 2020 Share Posted May 11, 2020 On 5/7/2020 at 10:56 AM, JSP552003 said: Anyone else having issues with the tuner becoming unresponsive? Helix LT. Updated from 2.8x straight to 2.91. Tuner works fine for a while after booting up but eventually lags or doesn’t track guitar at all. If I reboot, tuner works fine again for a while. I tried changing input to guitar only. I guess we’ll see what happens but something definitely isn’t right. Yes, confirmed here on my Floor unit. Seems to probably be related to the lagging output and compression meters, because the tuner gets laggy on my unit the same way the meters do. Have you reported it via a ticket to Line 6? If not, one of us needs to to make sure it's on their bug list so it gets fixed. Quote Link to comment Share on other sites More sharing options...
