rickrussos Posted January 14, 2017 Share Posted January 14, 2017 Will do Quote Link to comment Share on other sites More sharing options...
rickrussos Posted January 14, 2017 Share Posted January 14, 2017 YES.... It worked. I did it a bit different than the video, I just reversed the amp learning process. I had the amp learn the switches after I programmed the Instant (lightning bolt). If you play with your amp and Helix enough you should be able to get it working. I guess the tech guys at line 6 should take lessons from Lan Eisenberg, because they said it couldn't be done. Good Luck guys! THANKS HonestOpinion I really appreciate it! 1 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted January 14, 2017 Share Posted January 14, 2017 YES.... It worked. I did it a bit different than the video, I just reversed the amp learning process. I had the amp learn the switches after I programmed the Instant (lightning bolt). If you play with your amp and Helix enough you should be able to get it working. I guess the tech guys at line 6 should take lessons from Lan Eisenberg, because they said it couldn't be done. Good Luck guys! THANKS HonestOpinion I really appreciate it! Wahoo, awesome!! :) Quote Link to comment Share on other sites More sharing options...
LaurentJoulzy Posted January 15, 2017 Share Posted January 15, 2017 Another one for those who want to use the Helix as a midi controller for external systems, like pedals or amps. During gigs, everything should be automated on preset or snapshot change. But when jamming, or looking for a sound, or if anything goes wrong, I'd like to be able to jump quickly to a page where I can easily control my MIDI pedals. http://line6.ideascale.com/a/dtd/Custom-footswitch-layouts/865069-23508 Quote Link to comment Share on other sites More sharing options...
d0stenning Posted January 16, 2017 Share Posted January 16, 2017 Auto-Calibrate and Generate HELIX Global Eq curve using a measurement or other type of mic http://line6.ideascale.com/a/dtd/Auto-Generate-Global-Eq-curve-using-measurement-or-other-mic/865124-23508 Adding a way to quickly calibrate generate a global EQ curve by making the HELIX or the HELIX editor generate a swept sine-wave from 20-20Khz and then adjust the EQ curve on-the-fly based on what is being picked up by a connected measurement microphone, or known microphone such as a Shure SM58/ Neuman etc etc or even an iPhone or iPad mic - or the mic in a Mac - would be really useful. IK Multimedia sell such a room-measurement system along with a plugin is designed to be placed in the Master channel of a DAW - to calibrate a home or pro recording studio. But this is expensive. But a google search reveals that measurement mikes are available for as little as £39 ( from StudioSpares UK ) and these days its possible to just compensate for different mic characteristics so a range of mics could be supported 1 Quote Link to comment Share on other sites More sharing options...
derboesebernd Posted January 20, 2017 Share Posted January 20, 2017 please vote for my idea! add "helix control" support for the new helix native plugin! http://line6.ideascale.com/a/dtd/Helix-Native/865585-23508 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted January 22, 2017 Share Posted January 22, 2017 If you would find a Blend Route To parameter for the Dual Cab Block useful, vote this up: http://line6.ideascale.com/a/dtd/A-Route-To-Blend-Parameter-in-a-Dual-Cab-Block/865971-23508?submitted=1 1 Quote Link to comment Share on other sites More sharing options...
purplebeefunk Posted January 24, 2017 Share Posted January 24, 2017 Hi All, I haven't seen any Harmony Delay. Could we have Harmony Delay without keys just like TC Nova or Eventide? Thanks 1 Quote Link to comment Share on other sites More sharing options...
carlito17 Posted January 30, 2017 Share Posted January 30, 2017 I'd love to see the Bogner 101B Blue and Red as well as Blue w/ boost and Red w/boost available as amp models. 1 Quote Link to comment Share on other sites More sharing options...
JC-Tonequest Posted January 30, 2017 Share Posted January 30, 2017 Think I might be a little "special" but I can't seem to post my ideascale links here. I try to copy and paste it in the body, I try to use the link button. Doesn't work. Appreciate the help! Quote Link to comment Share on other sites More sharing options...
VIIyears Posted January 31, 2017 Share Posted January 31, 2017 I would love to see the new Precision drive by Horizon Devices modeled! https://www.youtube.com/watch?v=XJkJ3y2Rr7U Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted January 31, 2017 Share Posted January 31, 2017 Think I might be a little "special" but I can't seem to post my ideascale links here. I try to copy and paste it in the body, I try to use the link button. Doesn't work. Appreciate the help! You should just be able to cut and paste the link. If that doesn't work try an alternate browser from the one you are currently using: e.g. Chrome, Firefox, IE. Quote Link to comment Share on other sites More sharing options...
metalplated Posted January 31, 2017 Share Posted January 31, 2017 What do the bass players here think about getting this modeled along with the edge activator? Laser Cannon https://www.youtube.com/watch?v=sxAWX_afgA0 I have the edge activator and its pretty awesome, and it works well on acoustic guitars too. Quote Link to comment Share on other sites More sharing options...
richardantonelli Posted January 31, 2017 Share Posted January 31, 2017 Don't know if this was posted or not... One thing I hope that Line 6 will do in the future is not have to make the ext amp switching assignable to one of the switches. Storing the state in a snapshot or preset would free up the switches for other things. I use a friedman amp and while I can do the channel switching, I have to use up 2 footswitches to do it. I'd like to be able to save the ext amp's state per preset or snapshot and not assign it to one of the switches. Quote Link to comment Share on other sites More sharing options...
cdiddy5000 Posted January 31, 2017 Share Posted January 31, 2017 Adding the ability to select impedance and pad the input on any on the FX returns and the AUX in would be killer. 1 Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted January 31, 2017 Share Posted January 31, 2017 Adding the ability to select impedance and pad the input on any on the FX returns and the AUX in would be killer. I would especially like this for the Rack, so I can use one of the rear inputs for electric guitar. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted January 31, 2017 Share Posted January 31, 2017 Different colored signal paths depending on if the path is stereo or mono. Also handy in seeing where your mono blocks are since the signal path after would be a different color. https://line6.ideascale.com/a/dtd/Helix-signal-path-stereo-mono-indicator/867136-23508?submitted=1 1 1 Quote Link to comment Share on other sites More sharing options...
cdiddy5000 Posted February 2, 2017 Share Posted February 2, 2017 I would love to see the unused switches in looper mode be assignable to a FX block. This would allow me to stay on the looper mode and have access to a lead boost without having to tap dance. An alternative that would also be useful would be to be able to assign necessary looper controls to stomp switches. In my solo gigs, I never have had need for the 1/2 speed or reverse controls. Would be nice to free up that space for other things like a boost or whatever... 1 Quote Link to comment Share on other sites More sharing options...
daddydoodles Posted February 4, 2017 Share Posted February 4, 2017 A great addition for the wish list would be for the Helix to be able to have something similar to DigiTech FreqOut Natural Feedback Creator. VERY cool 1 1 Quote Link to comment Share on other sites More sharing options...
daddydoodles Posted February 6, 2017 Share Posted February 6, 2017 Has anyone heard any rumors of what will be in the next firmware update? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted February 6, 2017 Share Posted February 6, 2017 Has anyone heard any rumors of what will be in the next firmware update? We know all about it. It's been posted. Mostly some bass stuff, some swell fox and midi sync. Quote Link to comment Share on other sites More sharing options...
metalplated Posted February 9, 2017 Share Posted February 9, 2017 Maybe they will surprise us and give us more then what they posted. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 18, 2017 Share Posted February 18, 2017 Just to get a gauge of how people feel about being able to run plugins on the Helix or its successor: https://line6.ideascale.com/a/dtd/Enable-plugins-to-run-on-the-current-Helix-or-a-future-version/869179-23508 Quote Link to comment Share on other sites More sharing options...
d0stenning Posted February 24, 2017 Share Posted February 24, 2017 Model Presets - presets per effect model type https://line6.ideascale.com/a/dtd/Model-Presets-presets-per-effect-model-type/870115-23508?submitted=1 For any effect-model in a patch - allow the user to select from a list of factory presets for that effect model - or be able to save the current settings for the currently selected effect-block as a new effect preset and have that added to the list of presets. Often - for a complex effect that one may never have used before one simply isn't aware of all the possibilities in which that effect can be used. And being able to simply switch between a collection of pre-built settings - each that have a name - would be a useful and creative way of exploring the full potential of any effect - be it a chorus, compressor, delay etc.. 2 Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted February 24, 2017 Share Posted February 24, 2017 Model Presets - presets per effect model type https://line6.ideascale.com/a/dtd/Model-Presets-presets-per-effect-model-type/870115-23508?submitted=1 For any effect-model in a patch - allow the user to select from a list of factory presets for that effect model - or be able to save the current settings for the currently selected effect-block as a new effect preset and have that added to the list of presets. Often - for a complex effect that one may never have used before one simply isn't aware of all the possibilities in which that effect can be used. And being able to simply switch between a collection of pre-built settings - each that have a name - would be a useful and creative way of exploring the full potential of any effect - be it a chorus, compressor, delay etc.. Voted! Btw, there is an Idea that has been out there for a while effectively advocating the same thing you are. The idea has been enthusiastically endorsed with 645 votes last time I checked. I hope this one gets implemented at some point. The other idea is: https://line6.ideascale.com/a/dtd/Ability-to-save-default-blocks/741187-23508 4 Quote Link to comment Share on other sites More sharing options...
hideout Posted February 26, 2017 Share Posted February 26, 2017 Source Audio Soundbox Pro Multi-Band distortion https://line6.ideascale.com/a/dtd/Source-Audio-Soundblox-Pro-Multi-Wave-Distortion/870326-23508?submitted=1 Quote Link to comment Share on other sites More sharing options...
drdip69 Posted March 4, 2017 Share Posted March 4, 2017 suggestions for future additions... 1) Detailed Manual with all the effects and their parameter controls description 2) Keeley Bassist Limiter/Compressor 3) David Eden WT800 Bass Head + 4 x 10 Cab Quote Link to comment Share on other sites More sharing options...
Jezmonster Posted March 7, 2017 Share Posted March 7, 2017 MORE DELAY TIME IN ELEPHANT MAN PLEASE!! I love the effect, but I'd love longer delays- Any chance??? THANKS! Quote Link to comment Share on other sites More sharing options...
jamiepenner Posted March 7, 2017 Share Posted March 7, 2017 https://line6.ideascale.com/a/dtd/USB-multichannel-output-through-sends/871298-23508 USB multichannel output through sends The ability to assign the "audio interface" part of the unit to default USB 1,2,3,4 to Sends 1,2,3,4. The idea is to allow users to have their DAW output something like click, cues, and backing tracks through the Helix (USB 1,2,3.4) and out to the 4 Sends without the need for additional hardware and without taking up unnecessary real estate in a patch. This is sort of done now with USB 1/2 being able to be sent out directly to the 1/4", XLR, and Digital outputs. This would be an expansion of that concept allowing additional USB audio channels to be directed through the Sends as well. 1 Quote Link to comment Share on other sites More sharing options...
markblack77 Posted March 10, 2017 Share Posted March 10, 2017 A Freeze function (sound retainer) - like the EHX Freeze would be great. 1 Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted March 11, 2017 Share Posted March 11, 2017 Here's a recap of my IdeaScale suggestions; Oldest listed first. Vote 'em up! Helix Remote Android App Touch Capacitance footswitch for Edit Mode and more Model Select Amp FX w Footswitches in Pedal Edit Mode Color Looper Status Indicators A Route To Blend Parameter in a Dual Cab Block User Favorites Display Mode for Blocks and Presets L6 Link Support for Yamaha DXR Link Cab Mic Parameter Knob Press to Resume Default 1 Quote Link to comment Share on other sites More sharing options...
hideout Posted March 12, 2017 Share Posted March 12, 2017 Here's a recap of mine More Guitar Compressors Shortcut to Preset Volume A More In-Depth Version of the Manual Add Splits to the Effects Block List Give us an A/B Switch between Path 1 and Path 2 Graphical Representation of the EQ Curve Path Copy and Paste LFO & ADSR Tape Saturation Effect Maintain Effects Setting When Changing Effects Multiple Mics on Cab Sims Virtual Effects Loop in the Amp Blocks Swap Preamps and Power Amps within the Amp Block Pickup Models in the Helix Edit and Compare Model Speaker makes, models and sizes Zero Snapshot Granular Synth Effect Random Rate and Depth A True Modulated Delay Amp Builder/Creator App Gibson Varitone Emulation Two Phase Snapshot Footswitches Mode Auto Gain Structure Optimization Dynamic Cab Emulations Source Audio Soundblox Pro Multiwave Distortion Variable Mic Axis and Position Options Quote Link to comment Share on other sites More sharing options...
J_V_RO Posted March 14, 2017 Share Posted March 14, 2017 so, the Helix does not have an auto wah (envelope filter)???? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 14, 2017 Share Posted March 14, 2017 so, the Helix does not have an auto wah (envelope filter)???? It has two, the "Mutant Filter" and the "Autofilter" Quote Link to comment Share on other sites More sharing options...
duncann Posted March 14, 2017 Share Posted March 14, 2017 I would consider the Mystery Filter an autowah also. Take a look at the Deluxe Flanger too, I think that's the one or maybe it's the Dynamix, which has an envelope filter, which can create a wah effect with a flangerish flavor. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 14, 2017 Share Posted March 14, 2017 It has two, the "Mutant Filter" and the "Autofilter" I would consider the Mystery Filter an autowah also. Take a look at the Deluxe Flanger too, I think that's the one or maybe it's the Dynamix, which has an envelope filter, which can create a wah effect with a flangerish flavor. Thanks duncann, make that three and three quarters options for autowah (envelope follower, envelope filter, 'wah'tevah).. Quote Link to comment Share on other sites More sharing options...
wilkinsi Posted March 14, 2017 Share Posted March 14, 2017 I would really like to see an extra parameter for the SPDIF IN so it can be made to act like a word clock input on the Helix Floor. Likewise, I believe the AES OUT needs a timing fix, as I occasionally lose clock on the recipient device. I would also like to see Guitar to MIDI/USB added, so that Helix can be used like a MIDI keyboard for a soft synth. An FX block modeled after the Morpheus Droptune would be very welcome too. Quote Link to comment Share on other sites More sharing options...
showmpiano Posted March 18, 2017 Share Posted March 18, 2017 This is what I want for the Helix: TSL100 or JVM 210 OD Orange and Red patches, Bogner Ecstacy EL34 Patch, Engl Special Edition e670 el34, Marshall 1960 Cab with V30, Acoustic simulator or Tube Preamp, Micro Pog or DigiTech Mosaic. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted March 18, 2017 Share Posted March 18, 2017 Friendly bump. Still would like this. Global reverb level. https://line6.ideascale.com/a/dtd/Global-Reverb-Percentage-amount/799771-23508 1 Quote Link to comment Share on other sites More sharing options...
hideout Posted March 19, 2017 Share Posted March 19, 2017 Friendly bump. Still would like this. Global reverb level. https://line6.ideascale.com/a/dtd/Global-Reverb-Percentage-amount/799771-23508 I upvoted it but I also added this comment; I like the general idea but maybe change it to a Global Reverb Compensation. I think that it should be a +/- 100% so that you can globally add more or reduce the reverb. The way it is now in your proposal, you can only add to the reverb (0-200%). 1 Quote Link to comment Share on other sites More sharing options...
