Joepeggio 76 Posted April 12, 2016 I agree steve. The only problem is getting the expression pedal the same, if you hav any parameters associated with it. Quote Share this post Link to post Share on other sites
steveheroan 4 Posted April 12, 2016 I agree steve. The only problem is getting the expression pedal the same, if you hav any parameters associated with it. I figured if you have the exp pedal in full toe down (or full heel down, or at halfway or whatever) that the Helix could still recognize that that's where it was last saved? Maybe I'm missing something, I'm probably not tech-savvy enough to be commenting on this forum, lol. Quote Share this post Link to post Share on other sites
fabbr 13 Posted April 12, 2016 Electro-Harmonic Key9 pedal It would be great to have a Synth/Piano/Keyboard/Organ pedal on the Helix like the Electro-Harmonix Key9 http://line6.ideascale.com/a/dtd/Electro-Harmonic-Key9-pedal/816531-23508 Quote Share this post Link to post Share on other sites
bojackey 0 Posted April 13, 2016 Editor enhancements: http://line6.ideascale.com/a/dtd/Editor-Improvements/816848-23508?submitted=1 Quote Share this post Link to post Share on other sites
roscoe5 253 Posted April 14, 2016 Line 6 Idea Scale Posted http://line6.ideascale.com/a/dtd/Helix-Variax-Model-Pack-and-13-pin-MIDI-compatibility/817048-23508 Helix Variax Model Pack and 13 pin MIDI compatibility Develop Helix Variax Model Pack(s) for non-Variax guitar/bass owners. Develop some sort of 13-pin MIDI compatibility (13 pin to VDI adapter?) for use with Graph Tech Ghost Piezo systems, and maybe Roland GK systems. Quote Share this post Link to post Share on other sites
duncann 758 Posted April 20, 2016 New idea: Add a global option to change the mix functionality for reverbs Quote Share this post Link to post Share on other sites
Phil_B 1 Posted April 20, 2016 Morley Power Wah effect block Quote Share this post Link to post Share on other sites
Lachdanan0121 181 Posted April 21, 2016 I searched IdeaScale first, and didn't see one. So I created an IdeaScale of HX reverb models. This is the link. http://line6.ideascale.com/a/dtd/NEW-HX-Reverb-models-added-to-Helix-line/818580-23508?submitted=1 As a studio musician this would be a really big plus for me. Quote Share this post Link to post Share on other sites
Phil_B 1 Posted April 21, 2016 Thanks mate. Tremonti Power Wah would be my preference but either would be great ;) I searched IdeaScale first, and didn't see one. So I created an IdeaScale of HX reverb models. This is the link. http://line6.ideascale.com/a/dtd/NEW-HX-Reverb-models-added-to-Helix-line/818580-23508?submitted=1 As a studio musician this would be a really big plus for me. Quote Share this post Link to post Share on other sites
nippyjun 23 Posted April 22, 2016 I submitted the idea for an iOS version of the editor. http://line6.ideascale.com/a/dtd/iPad-editor/818691-23508 Quote Share this post Link to post Share on other sites
ricksteruk 85 Posted April 22, 2016 SEND Block to more places - e.g. 1/4in for easy IR bypass http://line6.ideascale.com/a/dtd/SEND-Block-to-more-places-e-g-1-4in-for-easy-IR-bypass/818624-23508 (I posted this idea yesterday and it's in review already! DI voted for it :)) Allow the SEND and RETURN blocks to connect to more of the Helix inputs and outputs. SEND should also go to 1/4in, XLR, USB, Digital. RETURN should also return from AUXin, Variax, Digital, USB This would make Helix's routing even more powerful. Scenario 1: A simple way to set up 1/4 in jacks to amp on stage and XLRs with Cab/IR to FOH. You could leave the Helix path output set to "XLR" and then just add a send block before your IR or Cab block that was set to send to 1/4in jack outputs. Simples! One reason for doing this is that you don't have to use a whole Path line just simply to do Scenario1. Meaning the other Paths can be used for parallel fx routing or maybe processing a mic as well. Of course to save a path you could connect your amp via a Send socket that you can already select with a Send block - but then you lose the ability to control the stage amp level with the Helix volume knob. Scenario2: Set up a USB device in a Send / Return loop easily. Think of the possibilities....... Quote Share this post Link to post Share on other sites
hideout 191 Posted April 23, 2016 New submission. Please Upvote. http://line6.ideascale.com/a/dtd/A-Virtual-Effects-Loop-in-the-Amp-and-Amp-+-Cab-blocks/818552-23508 Quote Share this post Link to post Share on other sites
PeterHamm 656 Posted April 23, 2016 New submission. Please Upvote. http://line6.ideascale.com/a/dtd/A-Virtual-Effects-Loop-in-the-Amp-and-Amp-+-Cab-blocks/818552-23508 I wonder how much different will this sound than simply using an amp block and a cab block separately the way it is now? I'm not saying it's a bad idea, I just wonder how much different it will really sound. Quote Share this post Link to post Share on other sites
datacommando 644 Posted April 23, 2016 SEND Block to more places - e.g. 1/4in for easy IR bypass http://line6.ideascale.com/a/dtd/SEND-Block-to-more-places-e-g-1-4in-for-easy-IR-bypass/818624-23508 (I posted this idea yesterday and it's in review already! DI voted for it :)) Scenario2: Set up a USB device in a Send / Return loop easily. Think of the possibilities....... Hi ricksteruk, Interesting concept, but I would really be impressed if Line 6 could get the USB audio MIDI to function correctly on OSX. Think about those the possibilities... Wonder if DI will vote for that? He shifted my Ideascale request for the dedicated Mac USB driver from "in review" to "in progress" in a few short hours. Wow, joy and happiness. Trouble is - as far as I'm concerned, it was a major fail. Didn't work! And we have had no more notice of progress or intentions to rectify the issues via this forum. So, cool idea - just don't hold your breath! Line 6 need to get the base functions up to speed before drifting off on other pipe dreams. Just my opinion, but a fix for the USB problem - "This would make Helix's routing even more powerful"! Quote Share this post Link to post Share on other sites
ricksteruk 85 Posted April 24, 2016 That's a bummer about the MIDI. I've not bothered to connect my Helix to my mac much yet - just did the firmware update when I first got it and then a couple of quick test USB recordings on Logic (which worked fine with my Core Audio). I am still running 10.9.5 so maybe that's why I've not had problems yet. I will want to use MIDI at some point - I'm thinking of running a complex Mobius looper set up using my Helix as the main computer interface with a couple of other MIDI controllers for other band members - so I hope it does get sorted! Quote Share this post Link to post Share on other sites
hideout 191 Posted April 24, 2016 I wonder how much different will this sound than simply using an amp block and a cab block separately the way it is now? I'm not saying it's a bad idea, I just wonder how much different it will really sound. I also submitted an idea where, within the amp block, you could swap preamp and powe amp types. I wonder if this will save on DSP use. Was it really necessary to downvote it? I mean, couldn't you just not vote for it? Quote Share this post Link to post Share on other sites
jpdennis 74 Posted April 24, 2016 Just added my first idea. I wasn't sure if it was already combined within another idea. I did a search but no luck, so ... BOSS SG-1 http://line6.ideascale.com/a/dtd/Boss-Slow-Gear-SG-1/818934-23508 Quote Share this post Link to post Share on other sites
jpdennis 74 Posted April 25, 2016 Just added my first idea. I wasn't sure if it was already combined within another idea. I did a search but no luck, so ... BOSS SG-1 http://line6.ideascale.com/a/dtd/Boss-Slow-Gear-SG-1/818934-23508 This is the video that started my quest for the SG-1 by the way ... Quote Share this post Link to post Share on other sites
d0stenning 62 Posted April 27, 2016 Can I just give a big BIGUP to this suggestion by another user - namely adding the ability to call up, create and save presets - for each effect ! Presets per effect Each effect (such as eq, overdrives, delays, compression, ect) within the menu at the bottom having the ability to pull up a preset for that specific effect, for example: You have a 10 band eq you use on every patch, but every time you make a new patch you have to go back and forth adjusting and comparing to get it to match..... Really slows things down from the usual quick paced helix editing :) Same could apply to anything, say a go to delay setting, or just about anything else... Helix was made to edit on the fly, and this would help that vision come to fruition! http://line6.ideascale.com/a/dtd/Presets-per-effect/799692-23508 Quote Share this post Link to post Share on other sites
Lachdanan0121 181 Posted April 28, 2016 Thanks mate. Tremonti Power Wah would be my preference but either would be great ;) You're Welcome. I figured the HX reverbs on Ideascale would benefit a lot of Helix users. Quote Share this post Link to post Share on other sites
Ka5par 22 Posted April 28, 2016 I would like to have more different filters on Helix.Especially some classic analog synth ones - MiniMoog, MS-20 etc (need to investigate more to be specific).Is there such ideascale submission already? Quote Share this post Link to post Share on other sites
tjontheroad 9 Posted April 29, 2016 Helix ideascale #200 (literaly) Helix Editor Window Skins with better contrast http://line6.ideascale.com/a/dtd/Helix-Editor-Window-Skins-with-better-contrast/819618-23508?submitted=1 I love the editor. But it can be hard to see. A couple color options would be awesome. Quote Share this post Link to post Share on other sites
d0stenning 62 Posted May 4, 2016 Latest IDEASCALE suggestion: A cheaper, basic "HELIX Control" type floor controller to extend the HELIX. This would - in contrast to the HELIX Controller for the Rack - NOT include the following: * LCD panel at the top ( not needed since we have what we need in the HELIX itself )* the 4 expression pedal and toe switch sockets* the HOST socket BUT would also include the following: * an extra USB type A socket - to connect to the main HELIX, as well as the existing type B ( to allow iPads or other devices to be connected and routed to to the HELIX * DIN MIDI out and in sockets to control other MIDI based devices So up-vote this.... if you're pedal-greedy. Finally - you may say ( about this ) i'm a dreamer ................. but i'm not the only one ... (ok ok ok i'll get my coat ) http://line6.ideascale.com/a/dtd/A-cheaper-basic-HELIX-Control-type-floor-controller-extender/820103-23508 Quote Share this post Link to post Share on other sites
PeterHamm 656 Posted May 4, 2016 Latest IDEASCALE suggestion: A cheaper, basic "HELIX Control" type floor controller to extend the HELIX. This would - in contrast to the HELIX Controller for the Rack - NOT include the following: * LCD panel at the top ( not needed since we have what we need in the HELIX itself ) * the 4 expression pedal and toe switch sockets * the HOST socket BUT would also include the following: * an extra USB type A socket - to connect to the main HELIX, as well as the existing type B ( to allow iPads or other devices to be connected and routed to to the HELIX * DIN MIDI out and in sockets to control other MIDI based devices So up-vote this.... if you're pedal-greedy. Finally - you may say ( about this ) i'm a dreamer ....... .......... but i'm not the only one ... (ok ok ok i'll get my coat ) http://line6.ideascale.com/a/dtd/A-cheaper-basic-HELIX-Control-type-floor-controller-extender/820103-23508 Wow, I REALLY don't think so. All due respect... You're asking them to put WAY more in there than you're asking them to take out. Adding MIDI and USB functionality like that? You think that would somehow cost less? And... I doubt that very many are going to want the EXPs removed... and the display not being there? makes little sense to most rack users live who don't have the rack right in front of them but do have Control. It wouldn't cost any less because of the small quantities of people who would buy it. Quote Share this post Link to post Share on other sites
d0stenning 62 Posted May 5, 2016 Wow, I REALLY don't think so. All due respect... You're asking them to put WAY more in there than you're asking them to take out. Adding MIDI and USB functionality like that? You think that would somehow cost less? And... I doubt that very many are going to want the EXPs removed... and the display not being there? makes little sense to most rack users live who don't have the rack right in front of them but do have Control. It wouldn't cost any less because of the small quantities of people who would buy it. Good point about the MIDI DIN - and have removed that new feature from the FR for an "extender" - but the EXP's those can go in my view since we would still have 2 EXP's on the main HELIX unit. Now this does in fact beg the question of whether there is an argument for another - more expensive than HELIX Control type product - one useable by non-HELIX users as well as HELIX users that includes MIDI DIN and 4 EXPs etc... and there is a case for that too - since when I surveyed the other MIDI floor controllers out there which have scribble strips - ( FAMC, RJM for example ) those currently go for around $1000 at least and more ! so if L6 were to enter that market too and sell for say $500 then L6 would be making a product far cheaper than the competition and would gain a new market much bigger than just HELIX owners. And having some kind of more intelligent link to Ableton etc for example would be amazing ( triggering loops, scenes etc ) where the scribble strips automatically change according to track names, clip names in Ableton etc - would be uber cool. Quote Share this post Link to post Share on other sites
PeterHamm 656 Posted May 5, 2016 so if L6 were to enter that market too and sell for say $500 then L6 would be making a product far cheaper than the competition and would gain a new market much bigger than just HELIX owners. I suspect it would be way more than 500. They'd have to include features broad enough to widen the appeal as much as possible... MIDI controllers like this are a niche market, keeping final cost to the customer up... I think it's a GREAT idea. But maybe not in L6's wheelhouse. If they ended up making it for 700 or 800 bucks, I wonder how many would sell... Quote Share this post Link to post Share on other sites
shawngs 0 Posted May 5, 2016 Please update the Helix so that we can turn on/off effects blocks via MIDI. If that's not possible, please add a "Mix" element to every effect so we can set the mix via a MIDI footswitch. Another option might be to allow for more than 10 Line 6 Footswitch options. Quote Share this post Link to post Share on other sites
Guitarmaniac64 10 Posted May 6, 2016 Come on guys help me out with this one http://line6.ideascale.com/a/dtd/Driver-App-for-Mac-s-that-cant-install-OSX-10-8-or-later/820248-23508?submitted=1 Quote Share this post Link to post Share on other sites
d0stenning 62 Posted May 9, 2016 http://line6.ideascale.com/a/dtd/HELIX-Editor-View-TWO-presets-at-same-time/820657-23508?submitted=1 Christian Arnolds excellent "Loopy HD Control" CustomTone and videos is a great idea. But it now begs for a new feature in the HELIX Editor: today I wanted to use this for another preset I made. So a new ideaScale is called for: Currently I would have to make a copy of the preset "Loopy HD Control" and go in manually and just set it up from scratch block-by-block to match the parts in my own original patch I want. It would be better if in the HELIX Editor I could see AT ONCE BOTH my preferred preset - with the tones how i want it- AND the new "TARGET" preset - and then simply highlight the blocks I want then COPY AND PASTE this to the new preset containing the MIDI control pedal assignments. For this I need to be able to view the details for TWO presets AT ONCE - one being the "SOURCE" preset (read-only) and the other being the TARGET - with only the TARGET being editable, paste-able etc so one can copy anything from the SOURCE into the TARGET patch. This would save a lot of time. It would also be very useful in any situation where one wants to combine parts from two different patches into a new one. Quote Share this post Link to post Share on other sites
roscoe5 253 Posted May 12, 2016 It would be pretty straight forward to model rack tube power amps and preamps. A lot of this stuff is now out of production and is certainly vintage and cool. This would open up some new options for us 90's kids that used to use and love rack gear, and expose the new generation guitarists to it. No one wants to haul around a 20U road ready rack full of gear anymore, but you could do some cool things and very intuitive mixing, matching and routing with that stuff and there were some unique quality tones in some of it. Tube Power Amps http://line6.ideascale.com/a/dtd/Helix-models-Rack-Power-amps/821070-23508?submitted=1 Marshall EL34 100/100 Marshall EL84 20/20 Mesa Strategy 500 Mesa Simul 2:90 Mesa Recto 2:100 Mesa fifty/fifty Mesa 20/20 Mesa Baron VHT two-ninety-two VHT two-fifty-two VHT 2150 Peavey Classic 50/50 Randall RT2/50 (EL34 & 6L6 tubes) Engl Tube Poweramp E810/20 Engl Tube Poweramp E840/50 Engl Tube Poweramp E850/100 Kittyhawk Tube Power-Amp 2x60 Kittyhawk Tube Power-Amp Stereo 120 Tube Preamps http://line6.ideascale.com/a/dtd/Helix-models-Rack-Tube-Preamps/821072-23508?submitted=1 Marshall JMP-1 Mesa Triaxis Mesa V-Twin Mesa Formula Pre Mesa Studio Quad Bogner Fish Engl Tube Preamp E530 Engl Preamp E570 Randall RM4 (all modules) CAE 3+ Tube Preamp Soldano SP777 VHT Valvulator Mako Mak 4 ADA MP-1 Peavey Valverb Peavey Rockmaster Peavey TG Raxx Peavey TubeFex Jackson JX-3 Kittyhawk Quattro Kittyhawk Testarosa Quote Share this post Link to post Share on other sites
Guitarmaniac64 10 Posted May 12, 2016 It would be pretty straight forward to model rack tube power amps and preamps. A lot of this stuff is now out of production and is certainly vintage and cool. This would open up some new options for us 90's kids that used to use and love rack gear, and expose the new generation guitarists to it. No one wants to haul around a 20U road ready rack full of gear anymore, but you could do some cool things and very intuitive mixing, matching and routing with that stuff and there were some unique quality tones in some of it. Tube Power Amps http://line6.ideascale.com/a/dtd/Helix-models-Rack-Power-amps/821070-23508?submitted=1 Marshall EL34 100/100 Marshall EL84 20/20 Mesa Strategy 500 Mesa Simul 2:90 Mesa Recto 2:100 Mesa fifty/fifty Mesa 20/20 Mesa Baron VHT two-ninety-two VHT two-fifty-two VHT 2150 Peavey Classic 50/50 Randall RT2/50 (EL34 & 6L6 tubes) Engl Tube Poweramp E810/20 Engl Tube Poweramp E840/50 Engl Tube Poweramp E850/100 Tube Preamps http://line6.ideascale.com/a/dtd/Helix-models-Rack-Tube-Preamps/821072-23508?submitted=1 Marshall JMP-1 Mesa Triaxis Mesa V-Twin Mesa Formula Pre Mesa Studio Quad Bogner Fish Engl Tube Preamp E530 Engl Preamp E570 Randall RM4 (all modules) CAE 3+ Tube Preamp Soldano SP777 VHT Valvulator Mako Mak 4 ADA MP-1 Peavey Valverb Peavey Rockmaster Peavey TG Raxx Peavey TubeFex Jackson JX-3 Add Kitty Hawk preamps and poweramps to that list aswell http://www.kittyhawkamps.com/index.html Quote Share this post Link to post Share on other sites
roscoe5 253 Posted May 12, 2016 Add Kitty Hawk preamps and poweramps to that list aswell http://www.kittyhawkamps.com/index.html Nice catch! Added Tube preamps Kittyhawk Quattro Kittyhawk Testarosa Tube Power amps Kittyhawk Tube Power-Amp 2x60 Kittyhawk Tube Power-Amp Stereo 120 Quote Share this post Link to post Share on other sites
HonestOpinion 940 Posted May 12, 2016 It would be pretty straight forward to model rack tube power amps and preamps. A lot of this stuff is now out of production and is certainly vintage and cool. This would open up some new options for us 90's kids that used to use and love rack gear, and expose the new generation guitarists to it. No one wants to haul around a 20U road ready rack full of gear anymore, but you could do some cool things and very intuitive mixing, matching and routing with that stuff and there were some unique quality tones in some of it. Tube Power Amps http://line6.ideascale.com/a/dtd/Helix-models-Rack-Power-amps/821070-23508?submitted=1 Marshall EL34 100/100 Marshall EL84 20/20 Mesa Strategy 500 Mesa Simul 2:90 Mesa Recto 2:100 Mesa fifty/fifty Mesa 20/20 Mesa Baron VHT two-ninety-two VHT two-fifty-two VHT 2150 Peavey Classic 50/50 Randall RT2/50 (EL34 & 6L6 tubes) Engl Tube Poweramp E810/20 Engl Tube Poweramp E840/50 Engl Tube Poweramp E850/100 Kittyhawk Tube Power-Amp 2x60 Kittyhawk Tube Power-Amp Stereo 120 Tube Preamps http://line6.ideascale.com/a/dtd/Helix-models-Rack-Tube-Preamps/821072-23508?submitted=1 Marshall JMP-1 Mesa Triaxis Mesa V-Twin Mesa Formula Pre Mesa Studio Quad Bogner Fish Engl Tube Preamp E530 Engl Preamp E570 Randall RM4 (all modules) CAE 3+ Tube Preamp Soldano SP777 VHT Valvulator Mako Mak 4 ADA MP-1 Peavey Valverb Peavey Rockmaster Peavey TG Raxx Peavey TubeFex Jackson JX-3 Kittyhawk Quattro Kittyhawk Testarosa Voted for both ideas! Quote Share this post Link to post Share on other sites
hideout 191 Posted May 16, 2016 Please upvote. Thanks. Always on effects return for external loopers. http://line6.ideascale.com/a/dtd/Global-Always-On-Effects-Return/809601-23508 Edit/Compare feature so you can check the changes you're making against the original patch. http://line6.ideascale.com/a/dtd/Edit-Compare/820832-23508 Quote Share this post Link to post Share on other sites
tommasoferrarese 8 Posted May 16, 2016 I don't know if this has been suggested yet, but I submitted to idea scale a possible alternative solution to having scenes in the same preset: being able to link presets and tell Helix no structure change will happen, just settings will be different: this would reduce loading times to 0 and probably allow spillover while possibly avoiding radical changes to the concept and firmware.. http://line6.ideascale.com/a/dtd/Alternative-to-scenes/821503-23508 Quote Share this post Link to post Share on other sites
MichaelHardly 2 Posted May 21, 2016 Would like to be able to change internal dual speakers/mic without the other automatically switching to something else.Also the mic switches out to a default everytime you switch the speaker. This obviously is not the correct way for something like this to work.Thanks! Quote Share this post Link to post Share on other sites
Inerzia 120 Posted May 23, 2016 I added this Idea a few days back, I hope you find it interestinghttp://line6.ideascale.com/a/dtd/Variax-pickup-selector-to-control-parameters-on-Helix/822783-23508 The info provided in the link explains enough, maybe, but I'll paste the original text here:"I figure, if the Helix can control the pickup selector... why not the other way round? Seems simple, right? Now... what would really be cool, is to allow the pickup selector to select five discrete states. Very, very handy to use with the sync parameter in time related FX, for example"Thanks for your positive contributions Quote Share this post Link to post Share on other sites
d0stenning 62 Posted May 24, 2016 Auto volume normalisation via global reference patch & scenes Auto volume normalisation via global reference patch using (upcoming feature?) scenes: In principle it ought to be possible for some sort of volume normalisation feature be built into the HELIX firmware so that for example - give us via firmware the means to set up a global REFERENCE patch - with three or four "Scenes". one scene the user specifies as "clean", another for boost, one for "lead" or OD - maybe more. The user then ensures that the volume levels for each of these "reference scenes" within this "reference patch" are the volume levels they desire for their typical needs ( in a mix, gigging etc ) Then whenever we create a new patch - we also set up scenes for the new patch - and the HELX provides a means for us to tell the HELIX that scene 1 is our "clean" , scene 2 is our "boost" scene 3 our "lead", scene 4 our "rhythm etc . And then with a single button click the HELIX normalises the levels and output for this new patch to match my initial "reference". So that for the new patch I am now ensured that for the common usages - clean, OD, boost rhythm etc - my new patch can be interchanged with any other without any need to tweak final output levels etc. http://line6.ideasca...es/823342-23508 Quote Share this post Link to post Share on other sites
surfsup1955 33 Posted May 24, 2016 http://line6.ideascale.com/a/dtd/Resizable-Library-Window-in-Helix-Editor/823361-23508?submitted=1 SImple request - most third party IRs (like Ownhammer) have long titles which give pertinent information as to speaker types, speaker mixes, mic types, mic mixes, mic distances, etc. This information is not fully viewable in the limited width of the Library Window. Please give user the ability to stretch the window OR make it so it automatically resizes based on the file information. Quote Share this post Link to post Share on other sites
Inerzia 120 Posted May 24, 2016 I think it's the Helix's own file system that crops the names Quote Share this post Link to post Share on other sites
