MarkJarvis Posted May 7, 2018 Share Posted May 7, 2018 Hi Phil_m Thanks for replying, i dont think this is right though..regardless of 'why' I am panning there are a left and right on 2A (two amps) and they merge and send to 2A so thast still two channels left and right then i pull the stereo delay to 2b now that 'should' still respect the fact i have a left and right from the first path but it doesnt. In fact if I do the exact same thing with one channel (not two amps just ) and then do the same thing on 2b it works correctly. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 7, 2018 Share Posted May 7, 2018 19 minutes ago, MarkJarvis said: Hi Phil_m Thanks for replying, i dont think this is right though..regardless of 'why' I am panning there are a left and right on 2A (two amps) and they merge and send to 2A so thast still two channels left and right then i pull the stereo delay to 2b now that 'should' still respect the fact i have a left and right from the first path but it doesnt. In fact if I do the exact same thing with one channel (not two amps just ) and then do the same thing on 2b it works correctly. Â Sorry, I'm not really following what you're saying... With the split in Path 2 hard panned like you have it, though, each side of that split is only getting one half of the stereo signal. Path 2A is only getting the left side and Path 2B is only getting the right side. So with only the right side signal going into the Dual Delay block, you'll only hear repeats on the right side. Also, you have the merge mixer hard panned, so even if there is sonic information on the left side of Path 2B, you're losing it through the merge mixer. Quote Link to comment Share on other sites More sharing options...
wilkinsi Posted May 10, 2018 Share Posted May 10, 2018 When using Cosmos Delay (stereo) block, I get random pitched jumps as though I altered the time parameter whilst playing, even though I had not. This seems to be restricted to the hardware's firmware, because it didn't happen in Native. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 10, 2018 Share Posted May 10, 2018 13 hours ago, wilkinsi said: When using Cosmos Delay (stereo) block, I get random pitched jumps as though I altered the time parameter whilst playing, even though I had not. This seems to be restricted to the hardware's firmware, because it didn't happen in Native. Â This behavior is controlled by the Splice parameter. The higher you have it, the more often it will happen. If you don't want it to happen, set it to 0. Quote Link to comment Share on other sites More sharing options...
Superorko Posted May 11, 2018 Share Posted May 11, 2018 Hi there! hope everyone is good! I am an Helix LT user and i use it for several different things: guitar sounds, effects, bass sound, but mostly to midi map and control ableton live. It happen though few times that if i am mapping an ableton live scene launch (play a particular scene ) and stop all scenes and set the Helix button properly most of the times it works fine but it happen (even at a gig!! :(  ) that the Helix button changes the polarity of the switch so instead of letting the sound play when i press the switch, it let it play when i release the switch causing a obvious delay in the sequence to start. Now i generally solve this issue recalling the Helix patch and generally works fine afterwards but is very annoying. Then often the Helix software crush if it is open at the same time of Ableton. Another thing that would be great to have is about the looper: Can it be midi syncable? I would love to have the looper in a patch that is sync'd to my Ableton rig and receiving midi tempo so when i start and stop a loop that i'd played live it will sync' the amount of bars to the time of the midi. That would be an impressive feature for all the poly instrumentalists like me that often need to loop parts on the fly on sequence or a midi bpm....  Hope this stuff will be sorted out in the next firmware!!!  Thanks and keep the great work up! Quote Link to comment Share on other sites More sharing options...
JordiFlames Posted May 14, 2018 Share Posted May 14, 2018 Hi! First of all, sorry for my english. I updated to 2.54 firmware and now Helix don't detect any signal from inputs... nothing with guitar in, aux in, sends, returns... nothing. And obviously, the tuner doesn't work too. I upgraded to 2.53 and others versions, but it doesn't work... I HAVE A CONCERT IN A FEW DAYS AND I'M DESESPERATE! Help pls! Thx! Quote Link to comment Share on other sites More sharing options...
the_bees_knees22 Posted May 14, 2018 Share Posted May 14, 2018 9 hours ago, JordiFlames said: Hi! First of all, sorry for my english. I updated to 2.54 firmware and now Helix don't detect any signal from inputs... nothing with guitar in, aux in, sends, returns... nothing. And obviously, the tuner doesn't work too. I upgraded to 2.53 and others versions, but it doesn't work... I HAVE A CONCERT IN A FEW DAYS AND I'M DESESPERATE! Help pls! Thx! Have you tried redownloading the update? I had to try it a few times before I got a solid update working with 2.54.  Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted May 14, 2018 Share Posted May 14, 2018 I would re-install the update. It might fix everything. Â Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 14, 2018 Share Posted May 14, 2018 10 hours ago, JordiFlames said: Hi! First of all, sorry for my english. I updated to 2.54 firmware and now Helix don't detect any signal from inputs... nothing with guitar in, aux in, sends, returns... nothing. And obviously, the tuner doesn't work too. I upgraded to 2.53 and others versions, but it doesn't work... I HAVE A CONCERT IN A FEW DAYS AND I'M DESESPERATE! Help pls! Thx!  Another vote for re-installing the update. Did you create a backup prior to updating? If not, I would do that, and back up your setlists individually just in case. If you're still having an issue after running the update, I'd try resetting the unit by holding footswitches 9&10 while powering up. Just to be clear, THIS WILL ERASE ALL YOUR PRESETS AND IRs, so don't do it unless you have a backup ready to send to the unit. Quote Link to comment Share on other sites More sharing options...
Superorko Posted May 19, 2018 Share Posted May 19, 2018 On 5/11/2018 at 12:19 PM, Superorko said: Hi there! hope everyone is good! I am an Helix LT user and i use it for several different things: guitar sounds, effects, bass sound, but mostly to midi map and control ableton live. It happen though few times that if i am mapping an ableton live scene launch (play a particular scene ) and stop all scenes and set the Helix button properly most of the times it works fine but it happen (even at a gig!! :(  ) that the Helix button changes the polarity of the switch so instead of letting the sound play when i press the switch, it let it play when i release the switch causing a obvious delay in the sequence to start. Now i generally solve this issue recalling the Helix patch and generally works fine afterwards but is very annoying. Then often the Helix software crush if it is open at the same time of Ableton. Another thing that would be great to have is about the looper: Can it be midi syncable? I would love to have the looper in a patch that is sync'd to my Ableton rig and receiving midi tempo so when i start and stop a loop that i'd played live it will sync' the amount of bars to the time of the midi. That would be an impressive feature for all the poly instrumentalists like me that often need to loop parts on the fly on sequence or a midi bpm....  Hope this stuff will be sorted out in the next firmware!!!  Thanks and keep the great work up! any news?  Quote Link to comment Share on other sites More sharing options...
RainerG Posted May 31, 2018 Share Posted May 31, 2018 I am debating to go for a new Helix, Helix LT or even BOSSÂ GT-1000 (the display of my old GT-5, which has served me very well for over two decades, is not 100% reliable anymore) I have had some experience with Line6 products (Flextone III) and a few issues with the software (sudden patch changes). A helpticket suggested to reinstall the firmware, but eventually it did not solve the problem alltogether If I scroll through 28 pages of Helix Bug reports, I am getting worried if I should purchase yet an other L6 product. All the software issues sound a little to frightening to me..... help me guys and convince me... Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted May 31, 2018 Share Posted May 31, 2018 47 minutes ago, RainerG said: I am debating to go for a new Helix, Helix LT or even BOSS GT-1000 (the display of my old GT-5, which has served me very well for over two decades, is not 100% reliable anymore) I have had some experience with Line6 products (Flextone III) and a few issues with the software (sudden patch changes). A helpticket suggested to reinstall the firmware, but eventually it did not solve the problem alltogether If I scroll through 28 pages of Helix Bug reports, I am getting worried if I should purchase yet an other L6 product. All the software issues sound a little to frightening to me..... help me guys and convince me... Firmware/software updates are a BREEZE. The updates you read about are very minor bugs that they solve with firmware updates. The Helix is a solid piece of equipment that sounds incredible. I've never had anything with more flexibility and sound quality. Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 31, 2018 Share Posted May 31, 2018 55 minutes ago, RainerG said: I am debating to go for a new Helix, Helix LT or even BOSSÂ GT-1000 (the display of my old GT-5, which has served me very well for over two decades, is not 100% reliable anymore) I have had some experience with Line6 products (Flextone III) and a few issues with the software (sudden patch changes). A helpticket suggested to reinstall the firmware, but eventually it did not solve the problem alltogether If I scroll through 28 pages of Helix Bug reports, I am getting worried if I should purchase yet an other L6 product. All the software issues sound a little to frightening to me..... help me guys and convince me... Â First of all, not all the posts here where people report a supposed bug are actually bugs. Sometimes it's people misunderstanding how a feature is designed to work. There are, of course, legitimate bugs posted in this thread, and there are quite a few instances of multiple people posting about the same bug. There's also plenty of responses in that thread where people are discussing bugs or supposed bugs rather than reporting them... I guess what I'm getting at is that thread has been up for over two and a half years now, and it's not like it's just one long list of bugs. Â Beyond that, though, every product using firmware and/or software has bugs - no exceptions. The GT-1000 has bugs (Boss doesn't really have an official forum, but people have reported them over at TGP). Â I've had my Helix for over three years (was an early beta tester), and it has been nothing but reliable for me for that period. I have personally never really had an issue with a bug that's been more than a minor annoyance. There hasn't been anything that's prevented me from using the Helix for a gig or anything like that. Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 31, 2018 Share Posted May 31, 2018 1 hour ago, RainerG said: I am debating to go for a new Helix, Helix LT or even BOSS GT-1000 (the display of my old GT-5, which has served me very well for over two decades, is not 100% reliable anymore) I have had some experience with Line6 products (Flextone III) and a few issues with the software (sudden patch changes). A helpticket suggested to reinstall the firmware, but eventually it did not solve the problem alltogether If I scroll through 28 pages of Helix Bug reports, I am getting worried if I should purchase yet an other L6 product. All the software issues sound a little to frightening to me..... help me guys and convince me... As was mentioned this thread is very old, and several firmware updates have been released since it was started. I expect that some of the bugs reported early on are now solved, though I haven't done any investigation to quantify that claim. Quote Link to comment Share on other sites More sharing options...
donmr Posted June 1, 2018 Share Posted June 1, 2018 8 hours ago, RainerG said: I am debating to go for a new Helix, Helix LT or even BOSS GT-1000 (the display of my old GT-5, which has served me very well for over two decades, is not 100% reliable anymore) I have had some experience with Line6 products (Flextone III) and a few issues with the software (sudden patch changes). A helpticket suggested to reinstall the firmware, but eventually it did not solve the problem alltogether If I scroll through 28 pages of Helix Bug reports, I am getting worried if I should purchase yet an other L6 product. All the software issues sound a little to frightening to me..... help me guys and convince me... I have both the Helix Floor and the new Boss GT1000. Bought the Boss in the hope it would be a smaller, lighter option and it is. Both have theirs advantages but overall if size and weight are not important, I would tend to side with the Helix. The helix user interface is LIGHTYEARS ahead of the Boss which does however have a Bluetooth iPad/iPhone editor which makes up for that to some degree. The Boss IR feature was only added as an afterthought after meeting much indignation at NAMM and it shows! You can only loads in 5 IRs where the Helix can load many more. IRs are becoming increasingly important to many of us. The other huge problem with the Boss is the foot buttons only have Latch and Momentary modes of operation where the Helix adds Long Press to these two. This is a MAJOR OVERSIGHT from Boss! If you want 1 button for Tap Tempo and Tuner access your out of luck. Not to mention the man, many other uses for this feature. One very nice thing about the Boss is it is FAST! No lag time between changes. Mind you this has never been a real problem for me but I know some users have had issues with this on the Helix. The Boss does sound great as does the Helix but as I mentioned, its limited IR facility is a real bummer for customizing your sounds. There are no wonderful forums like this for Boss aside from a few small Facebook groups. I actually have 2 Helix floor units and have used them extensively in different parts of the world without a single problem. Too early to tell with the GT1000 but Boss is usually great on the reliability score. While I love having the IOS and computer editing options for the Boss, they are all BUTT UGLY looking like something designed in the 80s in North Korea! They work though, which is great. Some of the Boss time based FX have the edge over the helix I think. Dirt boxes are very decent and I have my favorites on both platforms. The built in EXP pedal in the Boss seems to have an unusually short throw which I find annoying but it functions well other than that. I prefer the Helix pedal by a long margin. I’m keeping both for now especially in the hope that Boss will increase the IR capability and add long press option to the buttons on a future firmware update. Cheers Don Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted June 1, 2018 Author Share Posted June 1, 2018 10 hours ago, silverhead said: As was mentioned this thread is very old, and several firmware updates have been released since it was started. I expect that some of the bugs reported early on are now solved, though I haven't done any investigation to quantify that claim.  Definitely many of the bugs listed here have been fixed and quite a few turned out to be issues where the user just required further assistance rather than being an actual bug. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted June 5, 2018 Author Share Posted June 5, 2018 Are folks still finding the bug in the Mix parameter on the new mono versions of the reverbs where at 50% the reverb is not adequately in the mix? For some reason I thought I remembered a quote from Line6 staff saying this would be fixed in the 2.54 firmware but it does not appear to be. At least not for me. I hope the fix is coming in the soon to be delivered spring update(2.60?). Quote Link to comment Share on other sites More sharing options...
TRENDKILLCFH333 Posted June 14, 2018 Share Posted June 14, 2018 I discovered this bug last night.   I have a Mesa TC-100 and set the following programs via MIDI up.   1 - Clean with Reverb, Effects Loop On 4 - LO Channel with Reverb, Effects Loop On 5 - LO Channel with Reverb, Effects Loop On, Solo Boost engaged 8 - HI Channel with Reverb, Effects Loop On 9 - HI Channel with Reverb, Effects Loop On, Solo Boost engaged  I have a preset where foot switches are assigned these program numbers as a "master" preset for midi programs.   I've created another preset for use with the Mesa TC-100, with programs 1, 4, and 8 assigned to certain foot switches. They work flawlessly.   The problem is when I'm in Snapshot mode. Every snapshot that has the Solo Boost engaged (via instant command) does not engage the Solo Boost on the Mesa TC-100. All other snapshots work as expected. This only happens in Snapshot mode and only when I've selected a snapshot with the solo boost engaged.   Edit: I should note that when in Snapshot mode and the snapshot with the Solo Boost is selected, the Solo Boost light on the Mesa TC-100 comes on momentarily (like about half a secound) and then goes off. It does not behave this way with my midi program preset - only in snapshot mode. Quote Link to comment Share on other sites More sharing options...
BigBob-Irwin Posted June 15, 2018 Share Posted June 15, 2018 I am not sure I am posting this in the right place as it is not so much a bug with the Helix but the last 2 times I have updated to the latest firmware my google browser gets completely reset. It loses all the saved passwords and is as if I had loaded the browser for the first time also the @ and " key seems permanently reversed that is if you press the quotes key you get the at sign and visa versa. I have run a virus check but there are none found, anyone else have this issue. Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 15, 2018 Share Posted June 15, 2018 7 minutes ago, BigBob-Irwin said: I am not sure I am posting this in the right place as it is not so much a bug with the Helix but the last 2 times I have updated to the latest firmware my google browser gets completely reset. It loses all the saved passwords and is as if I had loaded the browser for the first time also the @ and " key seems permanently reversed that is if you press the quotes key you get the at sign and visa versa. I have run a virus check but there are none found, anyone else have this issue. Â That is freaking weird... I've never heard of anyone having that sort of thing happen. I can't even fathom how such a thing would be possible. What type of computer and OS are you using? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted June 15, 2018 Share Posted June 15, 2018 26 minutes ago, BigBob-Irwin said: I am not sure I am posting this in the right place as it is not so much a bug with the Helix but the last 2 times I have updated to the latest firmware my google browser gets completely reset. It loses all the saved passwords and is as if I had loaded the browser for the first time also the @ and " key seems permanently reversed that is if you press the quotes key you get the at sign and visa versa. I have run a virus check but there are none found, anyone else have this issue. Perhaps Helix has indeed become self aware and doesn't want you wasting your time surfing the web when you could be making music... Â Quote Link to comment Share on other sites More sharing options...
BigBob-Irwin Posted June 15, 2018 Share Posted June 15, 2018 Hi Phil I am using windows 10 on a pc with dual I5 processors 16 gig ram and a SSD to boot up the os Quote Link to comment Share on other sites More sharing options...
kapaguitar Posted July 2, 2018 Share Posted July 2, 2018 Hello Guys, I've been trying to use Ableton and Helix to create the ultimate live looping rigs, but have encountered many problems...  I have dedicated buttons on the Helix to:  Rec Looper 1 Undo Looper 1 Rec Looper 2 Undo Looper 2 Clear All Loopers Stop All Loopers Go to Previous Scene Go to Next Scene Launch Scene Stop Transport.  The Footswitches are sending the following MIDI Note On/Off:  1:D9   2:C#9   3:C9   4:B8   5A#8  6:G9   7:F#9    8:F9    9:E9  0:D#9  I have successfully played a gig like this, but realised that i needed some improvements. So i have "Select next scene on launch" active and I am trying to have scene Launch automate loop Overdubs and use dummy clips to automate preset changes on the Helix, and this is where the problems start!   Sometimes when launching a scene, the helix preset won't change, and ableton won't select the next scene.  I would assume this was an ableton issue, but i've realised that in this situation the helix controller footswitch light stays on permanently, and when it's a note on/off command the footswitch light should only be on when pressed.  Also, on some presets, sometimes the controller notes that i've assigned on the Helix change back to C-1 without my intervention...  I am going crazy with this so if you could shed some light it would be very much appreciated.  I have attached a faulty preset.  Thank you so much LEAD LIVE.hlx  Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 2, 2018 Share Posted July 2, 2018 6 minutes ago, kapaguitar said: Hello Guys, I've been trying to use Ableton and Helix to create the ultimate live looping rigs, but have encountered many problems...  I have dedicated buttons on the Helix to:  Rec Looper 1 Undo Looper 1 Rec Looper 2 Undo Looper 2 Clear All Loopers Stop All Loopers Go to Previous Scene Go to Next Scene Launch Scene Stop Transport.  The Footswitches are sending the following MIDI Note On/Off:  1:D9   2:C#9   3:C9   4:B8   5A#8  6:G9   7:F#9    8:F9    9:E9  0:D#9  I have successfully played a gig like this, but realised that i needed some improvements. So i have "Select next scene on launch" active and I am trying to have scene Launch automate loop Overdubs and use dummy clips to automate preset changes on the Helix, and this is where the problems start!   Sometimes when launching a scene, the helix preset won't change, and ableton won't select the next scene.  I would assume this was an ableton issue, but i've realised that in this situation the helix controller footswitch light stays on permanently, and when it's a note on/off command the footswitch light should only be on when pressed.  Also, on some presets, sometimes the controller notes that i've assigned on the Helix change back to C-1 without my intervention...  I am going crazy with this so if you could shed some light it would be very much appreciated.  I have attached a faulty preset.  Thank you so much LEAD LIVE.hlx    You should install the 2.60 firmware update that was just released like 10 minutes ago and see if this is resolved. There were a bunch of bug fixes involving MIDI commands in the Command Center. Quote Link to comment Share on other sites More sharing options...
kapaguitar Posted July 2, 2018 Share Posted July 2, 2018 7 minutes ago, phil_m said: Â You should install the 2.60 firmware update that was just released like 10 minutes ago and see if this is resolved. There were a bunch of bug fixes involving MIDI commands in the Command Center. Â MAAAAN, that's GREAT NEWS!!! :D :D :D Â Thank you so much for the info! Quote Link to comment Share on other sites More sharing options...
kapaguitar Posted July 2, 2018 Share Posted July 2, 2018 @phil_m I've just updated my Helix and the problem still persists...  I've realised that if I turn off the midi track that's sending the Program Changes to Helix, everything works normally... Does this raise any flags?  Thanks for the help!  Quote Link to comment Share on other sites More sharing options...
RufusOnFire Posted July 3, 2018 Share Posted July 3, 2018 So the MIDI CC Toggle bug that was reported in 2.5x is still present. I've been waiting since March for this update and it has utterly failed.  Helix, Helix Rack/Control, Helix LT only: In some cases, Command Center CC Toggle messages are not sent when selecting snapshots — FIXED NOPE. Not fixed in the slightest.   I currently have my Helix set up to control my RJM analog loop switcher which accepts CC commands. The assigned switches control the gizmo as expected. When changing between snapshots the lights work as intended but no MIDI CC command is sent. This bug was reported in February or March. Come on Line6, get it together! Quote Link to comment Share on other sites More sharing options...
Roberttheprole Posted July 3, 2018 Share Posted July 3, 2018 19 minutes ago, RufusOnFire said: So the MIDI CC Toggle bug that was reported in 2.5x is still present. I've been waiting since March for this update and it has utterly failed.  Helix, Helix Rack/Control, Helix LT only: In some cases, Command Center CC Toggle messages are not sent when selecting snapshots — FIXED NOPE. Not fixed in the slightest.   I currently have my Helix set up to control my RJM analog loop switcher which accepts CC commands. The assigned switches control the gizmo as expected. When changing between snapshots the lights work as intended but no MIDI CC command is sent. This bug was reported in February or March. Come on Line6, get it together! Ahhh!!!!! What the F! I haven't had enough time to confirm weather or not it's working right. Wondering if taking another 4hrs or more to reprogram the snapshots will work? Ugh... Yeah, come on guys, this is a major let down, major!!!!!!! Quote Link to comment Share on other sites More sharing options...
kimnjorgensen Posted July 3, 2018 Share Posted July 3, 2018 my hx, is wierd after update, it wont recieve midi pc commands from external device,and even if i unhook the external device and reboot hx,i can screw up and get stucked when changing presets, i did the factory reset of global settings,im reverting to older firmware. Quote Link to comment Share on other sites More sharing options...
meshax Posted July 3, 2018 Share Posted July 3, 2018 After update to 2.6Â all the effects that were on path 1 ( top row )Â Â disappeared. After restore from backup got this message What to do next ? Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 3, 2018 Share Posted July 3, 2018 57 minutes ago, kimnjorgensen said: my hx, is wierd after update, it wont recieve midi pc commands from external device,and even if i unhook the external device and reboot hx,i can screw up and get stucked when changing presets, i did the factory reset of global settings,im reverting to older firmware. Â Did you check Global Settings>MIDI/Tempo>Page 3, "MIDI PC Rx"? Quote Link to comment Share on other sites More sharing options...
Roberttheprole Posted July 4, 2018 Share Posted July 4, 2018 On 7/2/2018 at 11:18 PM, Roberttheprole said: Ahhh!!!!! What the F! I haven't had enough time to confirm weather or not it's working right. Wondering if taking another 4hrs or more to reprogram the snapshots will work? Ugh... Yeah, come on guys, this is a major let down, major!!!!!!! Ok, wait a sec... midi commands set to footswitches in snapshots seem to be working, as long as you only try to control one device with them I think? So not such a let down after all... Quote Link to comment Share on other sites More sharing options...
nhoven Posted July 4, 2018 Share Posted July 4, 2018 3 hours ago, Roberttheprole said: Ok, wait a sec... midi commands set to footswitches in snapshots seem to be working, as long as you only try to control one device with them I think? So not such a let down after all...  No, it doesn't. Yes, you can assign CC toggles to footswitches, but they are not recalled correctly (or sometimes at all) when recalling snapshots. Also, the lit and unlit values (usually 127 and 0) get mixed up, and sometimes I've even seen bogus values like 4 or 6 being sent. It's a total mess and completely broken. Quote Link to comment Share on other sites More sharing options...
RufusOnFire Posted July 4, 2018 Share Posted July 4, 2018 This is exactly what I'm experiencing. Basic toggling of a footswitch works fine, snapshot recalls are completely bonkers. I've tried setting up completely new patches and using my existing patches. Same result. It's completely unacceptable for a software defect to exist this long. I enjoyed the Helix but Line6 support is completely awful. Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 4, 2018 Share Posted July 4, 2018 54 minutes ago, RufusOnFire said: This is exactly what I'm experiencing. Basic toggling of a footswitch works fine, snapshot recalls are completely bonkers. I've tried setting up completely new patches and using my existing patches. Same result. It's completely unacceptable for a software defect to exist this long. I enjoyed the Helix but Line6 support is completely awful.  Oh come on now, this is one bug... Line 6 support has actually been phenomenal with the Helix. I've seen them do crazy things to help customers. I imagine once they are aware of this, they will try to fix it quickly. It looks like it slipped through testing. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted July 4, 2018 Author Share Posted July 4, 2018 1 hour ago, RufusOnFire said: This is exactly what I'm experiencing. Basic toggling of a footswitch works fine, snapshot recalls are completely bonkers. I've tried setting up completely new patches and using my existing patches. Same result. It's completely unacceptable for a software defect to exist this long. I enjoyed the Helix but Line6 support is completely awful.  If this is indeed the case then Line6 should release a quick fix. Ostensibly the reason this update contained less in the way of new features was primarily to provide an editor for HX Effects and to squash bugs. How does something like this slip through the cracks? The bugs in the MIDI functionality have been outstanding for a while now and have been extensively covered on the forum and probably directly with support. I have to echo phil_m's sentiment here and say Line6 support is generally excellent! It seems to be the QA process that continues to need shoring up (assuming this is actually confirmed as a bug).  I understand the incredible challenge of catching every bug on such a complex product but if there was not a thorough process in place for testing the MIDI output during preset and snapshot use then one should be implemented. It is a simple proposition to monitor MIDI output so this bug might well be repeatable and easily detectable. Firmware versions with broken MIDI functionality should not continue to be pushed out (stating the obvious). The Helix makes such an amazing MIDI controller, it is almost worth the money just for that functionality alone. Let's squash this thing already! Quote Link to comment Share on other sites More sharing options...
nhoven Posted July 4, 2018 Share Posted July 4, 2018 41 minutes ago, phil_m said: Â Oh come on now, this is one bug... Line 6 support has actually been phenomenal with the Helix. I've seen them do crazy things to help customers. I imagine once they are aware of this, they will try to fix it quickly. It looks like it slipped through testing. Â While I agree that the support is great for the most part, you can hardly call this bug slipped. I filed a ticket for this in November 2017, and the bug was acknowledged (with a three week delay after I filed the ticket, I might add). In my ticket I was promised a "quick fix" since 2.40. Didn't happen. Â Fwiw, it took me about 20 minutes after I unboxed my Helix to discover this bug. Q&A should have caught that easily. Â Leaves kind of a foul taste, because this bug really is a deal breaker as far as using external gear is concerned. Makes me wonder if they really only care to look good to the "more more more" users, the "how many amps and pedals" stastistics and those who stay within the L6 eco system... that's my tinfoil hat theory anyway. Quote Link to comment Share on other sites More sharing options...
RufusOnFire Posted July 4, 2018 Share Posted July 4, 2018 4 hours ago, phil_m said:  Oh come on now, this is one bug... Line 6 support has actually been phenomenal with the Helix. I've seen them do crazy things to help customers. I imagine once they are aware of this, they will try to fix it quickly. It looks like it slipped through testing.  Respectfully, I disagree. There were 52 bugs specifically listed plus another bullet that stated "many other fixes and optimizations". The 2.4 patch was released many months ago so these bugs have been present in their shipped software while they were working on new models. I completely support product development, especially since I own the product, but I have some experience working with large software development operations, and when teams prioritize shipping new features over fixing broken features it's a sign of serious problems in the software development process.  "Slipped through testing" isn't a reasonable response in today's world. Most of these tests should be automated and run every time a developer checks in code. If an existing feature breaks it gets fixed then and there. Yes, I've shipped software with defects. I'd also expect serious questions if I shipped software claiming to fix a defect that had been out in the wild for months and it was still present.   1 Quote Link to comment Share on other sites More sharing options...
goat-n-gitter Posted July 4, 2018 Share Posted July 4, 2018 5 hours ago, phil_m said: Â Oh come on now, this is one bug... Line 6 support has actually been phenomenal with the Helix. I've seen them do crazy things to help customers. I imagine once they are aware of this, they will try to fix it quickly. It looks like it slipped through testing. Â While I generally think Line 6 support is outstanding, I am hugely disappointed that the CC functionality in snapshots is still an issue. Since I use my Helix as a control center and multi FX for my amp rig, I've been forced to stick with V2.21. I sure would like to get all those cool added FX, but if I can't switch all my amp functions using snapshots, I'm sunk. I've been waiting patiently since March. Quote Link to comment Share on other sites More sharing options...
Thenizze Posted July 5, 2018 Share Posted July 5, 2018 Since update 2.60: Snapshot renaming doesn't hold. Not by HX edit or by Helix LT unit itself. It does hold if you save (2x save) after change. Quote Link to comment Share on other sites More sharing options...
