TV-OD Posted February 26, 2018 Share Posted February 26, 2018 Hi I thought my helix had crashed at start up after installing 2.5 but when looked carefully the helix was rebuilding the presets. It took ages to finish btw Quote Link to comment Share on other sites More sharing options...
pomor Posted February 26, 2018 Share Posted February 26, 2018 Hi I thought my helix had crashed at start up after installing 2.5 but when looked carefully the helix was rebuilding the presets. It took ages to finish btw Thanks, I saw this too - I waited until it finished and went to the home screen, I even played it a little and then I turned it off and then back on later - that's when it hung. Quote Link to comment Share on other sites More sharing options...
RufusOnFire Posted March 1, 2018 Share Posted March 1, 2018 Well phil_m, forgive my anxiety, but an update that breaks important functionality is no good. I hope you're right about the release day. I never even installed 2.3 because I didn't need its' features on my live rig. I only updated to 2.5 for the legacy FX. I only use amp modeling via Helix native on my DAW. My helix floorboard is used strictly for FX and switching of my amp, so at best I'm back to my old tap dance. Here's a few more exclamation points in case you run out.!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! FYI - I did successfully upgrade to 2.52 while it was up and live. In fact I'm still running that firmware. The bug for MIDI CC Messages and snapshots I mentioned is present in 2.50 and 2.52. Unless they have additional fixes for the next patch I don't think the issue my passionate friend above and I are experiencing will be resolved. Please help. I'm spoiled after replacing my pedalboard with this setup, and I'm not a fan of tap dancing, even if I use fewer exclamation points to make my case. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 1, 2018 Author Share Posted March 1, 2018 This could be completely unrelated to the new firmware but I am on HX Edit 2.52 as well as the 2.52 firmware. At rehearsal this evening I hit the amp button on my Helix to jump to the amp block and for the first time ever my screen went completely blank. I had to restart to restore normal operation and everything worked normally for the rest of the evening. Hopefully a one-time glitch and quite possibly unrelated to the update. Disconcerting though. Quote Link to comment Share on other sites More sharing options...
goat-n-gitter Posted March 3, 2018 Share Posted March 3, 2018 FYI - I did successfully upgrade to 2.52 while it was up and live. In fact I'm still running that firmware. The bug for MIDI CC Messages and snapshots I mentioned is present in 2.50 and 2.52. Unless they have additional fixes for the next patch I don't think the issue my passionate friend above and I are experiencing will be resolved. Please help. I'm spoiled after replacing my pedalboard with this setup, and I'm not a fan of tap dancing, even if I use fewer exclamation points to make my case. I updated to 2.53 this morning, and the bug for MIDI CC message transmissions not working when changing snapshots has not been fixed. So you still cannot switch external devices via CC messages when changing snapshots. CC messages do work in stomp mode. I have downgraded back to version 2.21 to restore the CC message in snapshot capability. I guess I'll have to wait to get back all my old M13 effects :( (look, no exclamation points) Quote Link to comment Share on other sites More sharing options...
Indianrock2020 Posted March 6, 2018 Share Posted March 6, 2018 The new HX Edit seems to have an issue -- you can export the current setlist but not from the File menu -- it's greyed out. You can do it from the section that says Setlists Import Export Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 6, 2018 Author Share Posted March 6, 2018 The new HX Edit seems to have an issue -- you can export the current setlist but not from the File menu -- it's greyed out. You can do it from the section that says Setlists Import Export I don't think this is a bug but more of an operational quirk in the current editor(2.52). If you double-click a preset after selecting a setlist such that there is a preset actively selected in that setlist; then the "Export Setlist" entry in the menu is no longer greyed out and works properly. Quote Link to comment Share on other sites More sharing options...
Indianrock2020 Posted March 7, 2018 Share Posted March 7, 2018 That worked Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 7, 2018 Author Share Posted March 7, 2018 That worked Good catch though and it should probably be addressed at some point. Quote Link to comment Share on other sites More sharing options...
flop54 Posted March 8, 2018 Share Posted March 8, 2018 Hello, I do the last update and I m'a happy to see the new Fx like the patern tremolo or panner but for me there is a big probleme to use it with midi sync because the helix can change the tempo even if this tempo is giving by a computer so with the midi sync the rythmic fx is useless because sometimes the tempo is good and sometimes not.. For me it's a really big problem. The tap led become blue when you have a tempo sync. the led lights on and off on the same beat than the computer but if you change to another snap the light change so the tempo too. and the fx is not sync with the computer. it is the same tempo but the helix's beat and the computer's beat are not together. Sorry for my bad english. Quote Link to comment Share on other sites More sharing options...
sigitar Posted March 8, 2018 Share Posted March 8, 2018 HX Effects Bugs: - The LFO of the Bleat Chop Trem and the Legacy Pattern Trem ist not re-syncable! By the way I think the Bleat Chop Trem is not in time... :wacko: - I cannot assign the time to an my expression pedal when time is divisible via tap footswitch Quote Link to comment Share on other sites More sharing options...
hikurangi Posted March 10, 2018 Share Posted March 10, 2018 Placater Dirty Amp isn't on my Helix running 2.53, wasn't on 2.50 either. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
PeterHamm Posted March 10, 2018 Share Posted March 10, 2018 Placater Dirty Amp isn't on my Helix running 2.53, wasn't on 2.50 either. What am I doing wrong? Are you trying to get to them through the front panel of Helix or through the Editor. If the front panel, re-install firmware. Something is wrong. If the Editor, de-install whatever editor you have and re-install HX Edit, the very latest version. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted March 12, 2018 Author Share Posted March 12, 2018 Placater Dirty Amp isn't on my Helix running 2.53, wasn't on 2.50 either. What am I doing wrong? Are you trying to get to them through the front panel of Helix or through the Editor. If the front panel, re-install firmware. Something is wrong. If the Editor, de-install whatever editor you have and re-install HX Edit, the very latest version. What PeterHamm said ^^^. It sounds like you either have not upgraded to the 2.52 version of HX Edit. You will have to do this to see the new models in the Editor. If you are not seeing them on the Helix then most likely your firmware version is not updated to 2.53. When you bring up HX Edit and and click on the icon of the Helix on the bottom of the screen or click the "About Helix" entry under Help in the menu, what firmware and editor version are you seeing? Quote Link to comment Share on other sites More sharing options...
geetar_geek79 Posted March 20, 2018 Share Posted March 20, 2018 On 2/19/2018 at 2:57 PM, geetar_geek79 said: Using a Helix rack here and control. When a loop is playing at half-speed, moving an effects block around the looper plays the phrase at full speed even though the display says half speed. Pressing 1/2-full button to say "full" then pressing it back again to say 1/2 speed returns it to normal (normal in this case is half speed). edit: I'm on 2.53 Quote Link to comment Share on other sites More sharing options...
plexi71 Posted March 23, 2018 Share Posted March 23, 2018 I just upgraded my Helix from 2.53 to 2.54 I have a tuner plugged in send 3 and set the Helix to send the guitar signal to send 3/4 in Tuner Mode (default is MUTE). It works with the 2.53 firmware but doesn't work anymore with 2.54. So i went back to 2.53 and it's ok again, in tuner mode, same settings, my polytune receives the guitar signal from send 3. Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted March 23, 2018 Share Posted March 23, 2018 5 hours ago, plexi71 said: I just upgraded my Helix from 2.53 to 2.54 I have a tuner plugged in send 3 and set the Helix to send the guitar signal to send 3/4 (default is MUTE) It works with the 2.53 firmware but doesn't work anymore with 2.54. So i went back to 2.53 and it's ok again, in tuner mode, same settings, my polytune receives the guitar signal from send 3. Please open a Support Ticket with Line 6 to be sure they are aware of your findings (in case they have yet to see your post). Quote Link to comment Share on other sites More sharing options...
plexi71 Posted March 23, 2018 Share Posted March 23, 2018 3 hours ago, MusicLaw said: Please open a Support Ticket with Line 6 to be sure they are aware of your findings (in case they have yet to see your post). Done. Thanks ;) Quote Link to comment Share on other sites More sharing options...
MarkeG Posted March 24, 2018 Share Posted March 24, 2018 On 3/22/2018 at 8:07 PM, plexi71 said: I just upgraded my Helix from 2.53 to 2.54 I have a tuner plugged in send 3 and set the Helix to send the guitar signal to send 3/4 in Tuner Mode (default is MUTE). It works with the 2.53 firmware but doesn't work anymore with 2.54. So i went back to 2.53 and it's ok again, in tuner mode, same settings, my polytune receives the guitar signal from send 3. Same problem here I have a rack tuner plugging into send 1 on the Helix and the helix tuner output set to send 1/2 and not getting any signal from the helix rack tuner is not working tested outputs 3/4 not working also Quote Link to comment Share on other sites More sharing options...
plexi71 Posted March 24, 2018 Share Posted March 24, 2018 Yep, must be related to: Bug Fixes - Pop noise can occur when exiting Tuner in four cable method setup with FX loop block engaged and audio playing upon entering and exiting Tuner -FIXED Quote Link to comment Share on other sites More sharing options...
RafterRattler Posted April 7, 2018 Share Posted April 7, 2018 Without using Snapshots, I have several patches where I have footswitches configured to toggle multiple effects - ie: turn some on, and some off with a single press. While it functions perfectly, the state of the footswitch on/off indicator that gets assigned seems to be rather random. For example, suppose I want to bypass one amp and turn on another with one switch, and I want the switch to be bright & the scribble strip solid when I select the second amp. I've tried various block assignment procedures - such as making sure the last block I assign to the switch is in the state I want the footswitch to show....but it seems to randomly change on it's own sometimes after the fact. At this point I'm assuming it's a bug. Correct? Quote Link to comment Share on other sites More sharing options...
twisteddrag0n Posted April 8, 2018 Share Posted April 8, 2018 Using a Helix Floor unit with the 4CM, and was working pretty well until i upgraded to 2.54. As soon as I did, I'm getting almost no volume going back to the amp, and the master volume knob has zero effect on the output. If I bypass the fx loop, it goes back to normal volume, and the volume control works normally. The amp control still switches channels appropriately, unlike some others I've seen, But unless I can figure out the volume issue I'll have to roll back to a previous version for it to be useable. Any suggestions welcome :). Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted April 8, 2018 Share Posted April 8, 2018 17 hours ago, RafterRattler said: Without using Snapshots, I have several patches where I have footswitches configured to toggle multiple effects - ie: turn some on, and some off with a single press. While it functions perfectly, the state of the footswitch on/off indicator that gets assigned seems to be rather random. For example, suppose I want to bypass one amp and turn on another with one switch, and I want the switch to be bright & the scribble strip solid when I select the second amp. I've tried various block assignment procedures - such as making sure the last block I assign to the switch is in the state I want the footswitch to show....but it seems to randomly change on it's own sometimes after the fact. At this point I'm assuming it's a bug. Correct? I've been reporting this bug in ongoing fashion. It goes way back, and was thought to be fixed, but has not. It seems to be either be mainly or exclusively to do with multiple assignments wherein amps are being switched. I've had other function switches which don't change amps, just other functions/parameters, and they don't seem to 'forget' their LED status. Each time there was a firmware update, I enjoyed putting it in, but loathed the fact that I'd have to go through all of my amp block-related function switches and fix their LED status every time (and I had at that point used a great many of them, especially since this predated the Snapshot feature). So, 'seconded' (I've honestly lost track of how many times I've brought this up or reiterated or supported it as I am right now). Quote Link to comment Share on other sites More sharing options...
RafterRattler Posted April 8, 2018 Share Posted April 8, 2018 Thanks Monkey - I've opened a ticket as well. RR 1 Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 8, 2018 Share Posted April 8, 2018 5 hours ago, MGW-Alberta said: My issue is that in the months` I have owned my Helix I have been unable to maintain a connection to my computer. The device will connect to the Edit software but as soon as I try to do anything, and I mean anything, the software says the connection is lost. It will stay connected as long as I don't try to do anything. What type of computer and what OS? Quote Link to comment Share on other sites More sharing options...
Flameout12 Posted April 14, 2018 Share Posted April 14, 2018 Purchased a brand new HX Effects unit and it arrive Tuesday, 4/10/18. I intended on using this in the EFX loop of my amp and controlling it via a MIDI controller. It was intended to be a replacement for G-Major unit. After I plugged it in, it worked fine and I was able to use some of the EFX. Next I plugged the MIDI into it, and the whole thing died. I then went back and checked all the MIDI set up in the manual (there's not much to it), and tried again. After about the 3rd try, the whole unit refused to boot up. It's now be returned. I would have loved to make this unit a part of my rig. I'm not the only one who's experienced this problem based upon some reviews. Call me disappointed. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 14, 2018 Share Posted April 14, 2018 37 minutes ago, Flameout12 said: Purchased a brand new HX Effects unit and it arrive Tuesday, 4/10/18. I intended on using this in the EFX loop of my amp and controlling it via a MIDI controller. It was intended to be a replacement for G-Major unit. After I plugged it in, it worked fine and I was able to use some of the EFX. Next I plugged the MIDI into it, and the whole thing died. I then went back and checked all the MIDI set up in the manual (there's not much to it), and tried again. After about the 3rd try, the whole unit refused to boot up. It's now be returned. I would have loved to make this unit a part of my rig. I'm not the only one who's experienced this problem based upon some reviews. Call me disappointed. Did you ever try to update the firmware? That's really the first thing you need to upon powering it up. Try holding down the left two footswitches (the tap and the one to the left of it) while powering it up. That will initiate a factory reset. After you do that, try installing the new firmware with Line 6 Updater. Quote Link to comment Share on other sites More sharing options...
jws1982 Posted April 16, 2018 Share Posted April 16, 2018 Helix Floor, 2.54. I noticed that on a 10-band EQ block, the initial change from 0 to -0.1 doesn’t show the “-“ symbol. The symbol doesn’t appear until you get to -0.2. I havent’t checked to see if it does it on other EQ blocks. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted April 17, 2018 Author Share Posted April 17, 2018 10 hours ago, jws1982 said: Helix Floor, 2.54. I noticed that on a 10-band EQ block, the initial change from 0 to -0.1 doesn’t show the “-“ symbol. The symbol doesn’t appear until you get to -0.2. I havent’t checked to see if it does it on other EQ blocks. It shows up like that everywhere. This bug has been reported previously. Hopefully they get around to fixing it at some point. Quote Link to comment Share on other sites More sharing options...
jandromontero Posted April 17, 2018 Share Posted April 17, 2018 On 4/9/2018 at 8:51 PM, MGW-Alberta said: High Sierra 10.13.2 HX Edit 2.52 Are you plugged directly into the computer or a usb hub? I’ve noticed HX Edit is prone to crashing when using anything besides the USB port on the Mac/pc. Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted April 20, 2018 Share Posted April 20, 2018 BUG Description If path 2a (stereo folded back) is used and then in path 2b you attempt to move stereo effect blocks to 2b second path, the stereo effects end up mono event tough they show stereo. In 2A Using (1) amp block then add another to 2a and move it to the second path (panning at the relative mixer sections) then fold 2a (1-2) back to mixer (hard panned then send to path 2b, from 2b add effects in stereo and pull those to 2b (#2) you expect the effects to stay stereo but then turn mono. Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 20, 2018 Share Posted April 20, 2018 6 minutes ago, MarkJarvis said: BUG Description If path 2a (stereo folded back) is used and then in path 2b you attempt to move stereo effect blocks to 2b second path, the stereo effects end up mono event tough they show stereo. In 2A Using (1) amp block then add another to 2a and move it to the second path (panning at the relative mixer sections) then fold 2a (1-2) back to mixer (hard panned then send to path 2b, from 2b add effects in stereo and pull those to 2b (#2) you expect the effects to stay stereo but then turn mono. Having a little trouble visualizing this... Any chance you could put up some screenshots? Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted April 20, 2018 Share Posted April 20, 2018 Yeah..in a few thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 23, 2018 Share Posted April 23, 2018 23 minutes ago, MGW-Alberta said: Directly into a USB port. I do have a hub but I find a lot of things don't like hubs. So ... since being here last I managed to stay connected long enough to update my Helix software (the OS?). That apparently was a big mistake. The unit has never crashed on me since I got it. Now it just stops taking input from me until it is rebooted. Still makes sound, just completely unresponsive to me. Buttons, dials, whatever. What if I had noticed this the first time while on stage? This is NOT cool. Line 6 needs to work on reliability before fancy new functions. Reliability is everything on a unit like this. These things are not inexpensive. People are not buying them as amusing toys or diversions. They are tools. They need to work ALL the time. No exceptions. Ever. So are you saying that the HX Effects is crashing when you connect it to HX Edit still? Have you opened a support ticket? https://line6.com/support/tickets/add.html Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 23, 2018 Share Posted April 23, 2018 7 minutes ago, MGW-Alberta said: To answer your query, I got the unit updated but now when I use it to play guitar, the on-board editing features and switching on the unit are unresponsive. It plays fine for a while and then stops taking input. I don't create patches on the computer, I create them on the unit. As I said in my earlier post, it doesn't want to stay connected to the computer. That's why I don't edit on the computer. The connection issue is now a moot point for me. It's at the bottom of my list of priorities. I need a pedal board that works. I can't be standing on stage and have the board quit on me mid-song. That's not acceptable. It used to be reliable before the update. Is there any way to go back to a previous version of the software? You can roll back to the previous firmware using Line 6 Updater if you want. Do you have any presets that you've created and saved on the unit yet? If not, before you rollback, I would try doing a factory reset. To do that, you just hold down the two lower right hand footswitches (the Tap and one to the left of it) while powering up. This will unfortunately delete any presets you've created and saved. But it might be worth trying. Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted April 24, 2018 Share Posted April 24, 2018 Line 6 Technical Support is your friend. Quote Link to comment Share on other sites More sharing options...
Guitarmaniac64 Posted May 4, 2018 Share Posted May 4, 2018 Possible bug in FW 2.5.4? Dont know if this have been reported before? I bought Fremens 2.30-2.50 update presets And since i in some cases will use another order of the snapshots then what he had in his presets I wanted to swap those snapshots using the touchfunction on Helix floor footswitches. I also wanted to colour them to my liking. So if he have some snapshots named Crunch,Big Chrunch,Clean.Rythm,Lead1,Lead2 i want to have them in this order Clean,Rythm,Crunch,Big Crunch,Lead1,Lead2. So when i held my fingers on say Big Crunch and Crunch snapshot and the "Swap Snapshot" window appeared on the big screen and i pressed the OK button and look down and see TWO snapshot next to eachoter named Crunch so instead of swapping snapshot it seems to have copy one snapshot. Now that didnt happen always only a few times maybe 3 or 4 and since we had that old bug where the last block in the chain turnes off when you change snapshot which i of course forgot so i had to load in a few presets again and start all over with my "swapping" of snapshots i started to make sure i hit saved twice after i colour and swaped them. Dont know if this is a bug but it sure look like that as i dont know if there is a copy function when you touch two snapshots footswitches at the same time. If it happens again i gonna take a photo of before and after as i never know when it appear. "Edit that last block turn off is a real annoying issue anything you do to alter a preset like volym adjustment (Fremen has been lazy on this topic lately the first one i bought from him i only had to adjust volym on a few presets now many have different volym) seems to activate that bug." But it is just a matter of reloading the preset and make the adjustment colour the rings and save every snapshot again. Quote Link to comment Share on other sites More sharing options...
MarkJarvis Posted May 6, 2018 Share Posted May 6, 2018 So as far as i can tell this is a bug! Description Dual path on 2A merge mixer panned hard right left Add delay (stereo) and move to 2b Make sure the split mixer in 2b panned hard left and right The reason to do this is like in a single path you want the amp sound a bit more separated from the effects (as in not send the amp through the efx) Excpected Effects should stay stereo Actual Effects, even though stereo and two signals are present only one side does anything. See attached preset. ex_no_stereo.hlx Quote Link to comment Share on other sites More sharing options...
phil_m Posted May 6, 2018 Share Posted May 6, 2018 1 hour ago, MarkJarvis said: So as far as i can tell this is a bug! Description Dual path on 2A merge mixer panned hard right left Add delay (stereo) and move to 2b Make sure the split mixer in 2b panned hard left and right The reason to do this is like in a single path you want the amp sound a bit more separated from the effects (as in not send the amp through the efx) Excpected Effects should stay stereo Actual Effects, even though stereo and two signals are present only one side does anything. See attached preset. ex_no_stereo.hlx I loaded the patch and there are two issues. The first is the Merge Mixer on Path 2. Since you have that hard panned, you're only getting the right side from the effects on Path 2B. If you leave both paths panned center, you'll hear the reverb on both sides. The second issue, and the reason you don't hear the delay on the left side, is the Split block at the beginning of Path 2. You have it hard panned so Path 2A is only getting the left side of the signal going to it and Path 2B is only getting the right side. The Dual Delay block is a true stereo effect, so if it's only getting signal on the right side, you're only going to hear delay on the right side. The reverb is a stereo effect, but the wet signal from the reverb is a blended stereo effect, meaning that a signal just on the right side will produce a wet signal that affects both sides. If you just use and A/B Split there, you'll get a parallel stereo path with both sides going to the delay like you want. The main thing to remember is that when you create a split, it creates two stereo paths, so unless you want to isolate each side to a path for some reason, you don't need to hard pan. Because you have the Merge Mixer in Path 1 and have that hard panned, the amps are already split with one on the left and the other on the right. They will keep that separation through successive splits and merges as long as you don't use any mono blocks. 1 Quote Link to comment Share on other sites More sharing options...
Guitarmaniac64 Posted May 6, 2018 Share Posted May 6, 2018 On 2018-05-04 at 12:13 PM, Guitarmaniac64 said: Possible bug in FW 2.5.4? Dont know if this have been reported before? I bought Fremens 2.30-2.50 update presets And since i in some cases will use another order of the snapshots then what he had in his presets I wanted to swap those snapshots using the touchfunction on Helix floor footswitches. I also wanted to colour them to my liking. So if he have some snapshots named Crunch,Big Chrunch,Clean.Rythm,Lead1,Lead2 i want to have them in this order Clean,Rythm,Crunch,Big Crunch,Lead1,Lead2. So when i held my fingers on say Big Crunch and Crunch snapshot and the "Swap Snapshot" window appeared on the big screen and i pressed the OK button and look down and see TWO snapshot next to eachoter named Crunch so instead of swapping snapshot it seems to have copy one snapshot. Now that didnt happen always only a few times maybe 3 or 4 and since we had that old bug where the last block in the chain turnes off when you change snapshot which i of course forgot so i had to load in a few presets again and start all over with my "swapping" of snapshots i started to make sure i hit saved twice after i colour and swaped them. Dont know if this is a bug but it sure look like that as i dont know if there is a copy function when you touch two snapshots footswitches at the same time. If it happens again i gonna take a photo of before and after as i never know when it appear. "Edit that last block turn off is a real annoying issue anything you do to alter a preset like volym adjustment (Fremen has been lazy on this topic lately the first one i bought from him i only had to adjust volym on a few presets now many have different volym) seems to activate that bug." But it is just a matter of reloading the preset and make the adjustment colour the rings and save every snapshot again. Still working on changing order and color those snapshots in that preset package It has happend again 2-3 times that the snapshot have copy itself instead of swapping order so i can now confirm its a bug The annoying thing is i really dont know when its gonna appear. Workaround solution for the last block turn off when either swap (Oh another bug perhaps?) or change snapshot by hitting the FS (I dont want to use the editor other than to rename some of the snapshots for this task as i have to use the unit to colour the rings anyway) is to copy over the same preset again from Fremens bundle and swap the snaps around then color the FS rings then hit save. Quote Link to comment Share on other sites More sharing options...
