Helix Bug Reports
HonestOpinion
On 2/20/2022 at 12:42 AM, jamkid said:
Hardware: HX Stomp
Firmware/Editor: Firmware 3.15
Bug:  CC71 (engages the MODE switch) does not work after the update to 3.15
Have tried sending the CC command using multiple midi controllers. All the other commands are working fine, but CC71 does not do anything.
CC71 works fine in 3.15. Are you remembering to send a Value of 0-5 to select the specific mode?
ex: CC#71 Value 3 = Snapshot mode
Footswitch Mode (0=Stomp, 1=Scroll, 2=Preset,
3=Snapshot, 4=Next footswitch mode, 5=Previous
footswitch mode)
  • Upvote 2
13 hours ago, molul said:
A strange thing I noticed is that after importing the setlist, when I turned the Helix LT off and on again, the rebuild presets process occurred again. Not sure if it's something normal after importing setlists, as I hadn't done it yet.
This is normal - consider that your HX device is essentially a computer. If you add presets that differ from the ones installed, the “Rebuild” routine will run to ensure that all your presets are fully compatible with the current firmware. The rebuild will occur if it is either a single, or many preset slots that are modified, so sometime the process is quicker than others. Regard it as the Helix is “housekeeping” and keeping everything tidy.
Hope this helps/makes sense.
On 2/12/2022 at 7:02 AM, datacommando said:
Is what you are experiencing something possibly related to this.
From the release notes
Bypass Assign > EXP Pedal 1/2 now has a new Behavior parameter to control how bypassing is handled.
The default value "Toggle" behaves as this feature always has - bringing the pedal past threshold will toggle the block's bypass state from what it is currently (i.e. enable if currently bypassed and vice versa). "Toe Down" and "Heel Down" always bypass the block at the designated position, regardless of the block's starting state. So with "Heel Down" selected, the block will always enable when you cross the Position threshold and bypass when you return below it
I made a video for the support guy.  It's here, in case you want to see the bug:
On 2/20/2022 at 6:20 PM, molul said:
The new "change snapshot" command seems to have a problem.
I have a setlist with 10 songs programmed with the new "change snapshot" command. This works alright.
Now, I exported that setlist and imported it onto another setlist (I want to have a clone for tweaking stuff while having the original intact), and on that new imported setlist the "change snapshot" command doesn't work 100%. When I press a FS to change to another snapshot, it does change (I can see it in the top right corner) but it doesn't update the screen with what the footswitches are supposed to do.
Has anyone experienced this?
Fixed. The problem was that I cloned the setlist on another computer with HX edit 3.11 and not 3.15. I updated and exported/imported, and all went fine.
On 2/11/2022 at 7:47 PM, theElevators said:
In 3.15, HX Edit appears to be saving several presets by itself, when you change the Bypass Behavior in a different preset.
Pre-req:
Set Snapshot Edit: Discard.  Expectation is that if you re-enter the preset/snapshot, any changes that you made will be discarded.
Bug:
1. in HX Edit, go to a block of any preset, e.g. wah-wah
2. Go to Bypass/Controller Assign and locate the "Bypass" parameter.
3. Change the newly-added "Behavior" parameter to "Heel Down" or "Toe Down".
4. Move the expression pedal up/down a few times
Go to a different preset, then come back.
1. you will see the change you made has been saved for you.
2. you will see the same change appears to be applied to other presets as well.  It appears that identical or nearly-identical presets are updated all at the same time.
Expectation: No changes should be auto-saved, if you have Snapshot Edit disabled.  This bug only applies to Bypass Assignment Behavior change.  Other changes are discarded as they should be.
Interestingly enough, I am experiencing essentially the opposite behavior (more evidence this is a bug): After saving a change to the new Behavior parameter, upon leaving and returning to the preset, the "saved" change is reverted / was apparently not saved.
This occurs for me on all presets with an EXP bypass.
Probably another preset is affecting this behavior.  This is what happens when people test things on only one preset :)  Gotta expand the scope of testing.
Also, maybe the EXP 2 vs EXP 1 makes a difference as well.  Either way, this is a scary bug.
I am always cautious when I upgrade the Helix.  I have my main gigging Helix on the previous version still and will not upgrade it until this is sorted out.  Last thing I need is to have weird glitches on stage in front of a lot of people.  Ugh.
Hmm, thanks for posting, if you have a moment, more details please. Will help in figuring out why different users seem to be getting different results:
Which HX Device do you own?
Are you using the attached Wah pedal or an external one?
Did you do a factory reset and restore after your upgrade to 3.15?
Which EXP(1, 2, 3?) are you using for Wah?
What is your global setting (Global, Per Snapshot, or Per Preset) for 'EXP Pedals' --> 'EXP * Pedal Position'?
What is your global setting (Discard or Recall) for 'Preferences' ---> 'Snapshot Edits'? Is the Behavior setting persisting between snapshots? Between presets?
What is the 'Behavior' setting (Toggle, Heel Down, or Toe Down) that is not persistent when returning to the preset? Or is it any/all of them that behave this way?
Do you click the expression pedal toe switch to use the Wah, or is the preset/snapshot already on the EXP(1,2, or 3) setting corresponding to the Wah?
Hit my first show-stopper level 3.15 issue today (Helix Floor):
I like to run Stomp/Snap mode, with four snapshots on the bottom row and four stomps on the top (for my live style, it just works best for me). However, on some presets, I end up using more than 4 snapshots. Rather than manually having to remember which presets to hit bank up+down to switch to 8-snap display, I’ve taken to assigning snapshots to some of the top row stomp switches via command center. This worked great through 3.11, but at least one of those presets went berserk today on 3.15.
snapshot1 looks & behaves totally normal (first image), but when I hit snaps 2-4, the upper row flips to SNAPSHOT^ on all buttons.
To fix this, I had to enable “recall” for snapshot edits, and walk through every snap in the patch, manually fixing the command center setting, then re-save. Basically, I’m saying something broke my preset in the 3.15 preset rebuild & only retained the snapshot setting metadata for the first snap in these kind of patches. The rest knew there was a cmd center event, and knew it was a snapshot event, but overwrote it with “1” (Next).
Yes, I did a full factory reset & restore from backup when upgrading, including letting it rebuild all of my presets after the restore.
EDIT: even stranger, it only appears to have affected this one preset. All of my others (which only have one cmdCenter snap saved as a stomp vs the 4 here) are fine
EDIT #2: You know what, I apologize. I just went back and decoded/parsed all of my setlist backups for the past year. This issue has been in my patch since at least last August, which tells me something different, but equally interesting: this must've been a bug in previous firmware, where snapshots didn't honor different parameters on CommandCenter settings from one snap to the next that they fixed in 3.15. I don't see anything specifically tied to it in the release notes, but perhaps it was related to some of the other CommandCenter bug fixes. So, yeah. The firmware is actually doing what it's supposed to now. *shrug*
Edited by shmaque
Added new info; not a bug but rather a bug-fix.
@HonestOpinion Thanks for the quick reply! For context, I use the EXP1 or EXP2 position bypass for a different delay block (either Ducked Delay, Ping Pong, Transistor Tape, or Vintage Digital) on various presets—not Wah. On any preset with a Wah block, the Wah is set to EXP Pedal Toe bypass. Responses are inline.
On 2/26/2022 at 1:20 PM, HonestOpinion said:
Which HX Device do you own? Helix Floor
Are you using the attached Wah pedal or an external one? I use an external pedal for EXP3, but that is not used in any of the aforementioned settings (EXP3 is only used to control a Volume block on every preset).
Did you do a factory reset and restore after your upgrade to 3.15? Yes, factory reset and restore after upgrading, including one round of "Rebuilding presets..."
Which EXP(1, 2, 3?) are you using for Wah? I use EXP1 for Wah blocks, but the issue occurs on presets w/EXP1 or EXP2 w/position bypass with or without a Wah block. I have also tried changing the Wah block position control to EXP2 (again, I am using position bypass for Delay blocks, not Wah), but the issue persists.
What is your global setting (Global, Per Snapshot, or Per Preset) for 'EXP Pedals' --> 'EXP * Pedal Position'? Per Snapshot (for EXP1, EXP2, and EXP3)
What is your global setting (Discard or Recall) for 'Preferences' ---> 'Snapshot Edits'? Is the Behavior setting persisting between snapshots? Between presets? Discard. The Behavior setting persists between snapshots. After switching to a different preset & back, the Behavior setting is lost.
What is the 'Behavior' setting (Toggle, Heel Down, or Toe Down) that is not persistent when returning to the preset? Or is it any/all of them that behave this way? Since Toggle is the default setting, Heel Down and Toe Down do not persist when returning to the preset. This occurs whether I save w/Behavior as Heel Down or Toe Down.
Do you click the expression pedal toe switch to use the Wah, or is the preset/snapshot already on the EXP(1,2, or 3) setting corresponding to the Wah? Yes, for problematic presets in which I use position bypass (for a Delay block) with a Wah, the Wah is set to EXP Pedal Toe bypass. However, I have tried switching the Wah block position control between EXP1/2 and removing the Wah block when it exists, and the issue persists.
  • Thanks 2
Thanks for the incredibly detailed reply! As, or if, more of these posts pop up, maybe we can start to see a pattern as to why different users seem to be getting different results. As with so many other features or bugs where there are variances between the reported behavior, it often it seems to be related to users having different settings, or sometimes amounts to no more than differences in the way people describe what they are observing, or actual differences or errors between various testers in their testing methodology that go unnoticed.
I tested my Helix with all of the global settings set to be identical with yours, even set up the volume block on EXP 3 with an external expression pedal per your settings. I was unable to replicate your results. The 'Behavior' setting always stays persistent for me, no save required. One thing I noticed during my test, across snasphots or presets, the 'Behavior' setting stays persistent per EXP (1, 2, or 3 on the Helix), but each EXP can be set differently (Toggle, Heel Down, or Toe Down). If you have bypass/Wait set up for example on both EXP 1 and EXP 3, then the 'Behavior can be set to 'Toggle' on EXP 1 and 'Toe Down' on EXP 3, but it will be the same for that EXP in every preset/snapshot. So, what I am finding is that the 'Behavior' value stays persistent for the EXP number(1, 2, or 3) that it is set on, with only one 'Behavior' option available at any given time on that EXP. The set value is the same in every preset/snapshot, however, it need not be identical across different EXPs.
The reason I mention this, besides it being another relevant detail of how the 'Behavior' parameter works currently, is that it can skew the results of your testing if you don't keep a close eye on which EXP the block you are examining is assigned to. Is it possible that you were looking across EXPs during your testing?  I noticed when I did this in error a couple of times when running the tests (with your described setup) it would appear as if the 'Behavior' was flipping back to 'Toggle' when actually it wasn't. I was in fact comparing the 'Behavior' on two different EXPs when I switched presets/snapshots, rather than comparing the values on the same EXP.
Anyway, the more I test this, as I have mentioned previously, the more I notice how many individual scenarios need to be tested - different EXPs, every combination of pertinent global settings combined with all the new 'Behavior' options, legacy and new presets, HX Edit preset/snapshot switching as well as manual switching on the device, ensuring that HX Edit reflects the same value as the device, and other stuff I haven't thought of yet. To be thorough, all of this needs to be tested across setlists, banks, presets, and snapshots. Makes my head spin. This really is one of those features that is complicated enough to be best vetted, systematically with a test harness by Line 6 that can run through a ton of possible variations and check to ensure proper and repeatable results.
I imagine Line 6 has been, and continues to test this in-house, as well as looking at the reports of user experiences with it in the wild. If not, then I hope they will. The 'Behavior' option would benefit from further clarification/documentation, and perhaps a fix if it is not functioning as intended.
Thank you for the additional details and attempting to reproduce on your device. I checked again, and my experience is: After saving the Behavior setting (as Heel Down or Toe Down) for one block on a preset, upon leaving the preset and returning, the Behavior setting reverts to Toggle.
For additional troubleshooting, I exported a few presets and opened the corresponding .hlx files in a text editor. The particular values of the corresponding '@behavior' param for a given block may help reveal the bug to Line 6:
  • After saving as Toggle and exporting the .hlx, '@behavior' is 0
  • After saving as Heel Down and exporting the .hlx, '@behavior' is 1
  • After saving as Toe Down and exporting the .hlx, '@behavior' is 2
  • After leaving the preset, returning, and exporting the .hlx, '@behavior' is occasionally true
    • This occurred several times (but not every time) upon re-exporting a previously saved preset. Regardless of whether '@behavior' reverted to 0 or was true, in HX Edit and directly on my Helix, the corresponding EXP Behavior setting is Toggle.
  • Upvote 2
footswitch mode)
Sorry, I meant CC# 73, to toggle between Play and Edit screen.
and yes, CC#71 is working for my HX stomp.
I am having the same type of issue (Helix LT)  I changed the wah (exp1) bypass on a bunch of presets (most of them built from the same template) from bypassing with the toe switch to bypass the wah with 99% position, 1000 Msec, and Toe Down behavior. I save each of the presets with the change. Upon opening any preset that I haven't made the bypass change from the toe switch yet, going back to the any of presets that I've made the above change to, the behavior is reset from Toe Down to Toggle.  This happens when I open unmodified presets regardless of whether I modify or save the preset .  But if I then change the behavior on just one of the modified bypass presets back to Toe Down, even without saving, most of the presets I've modified change back to Toe Down.  But some stay on Toggle. I can't figure out what causes some to change back to Toe Down, and why some stay on toggle.
I did a backup/reset/restore, with the EXP1 parameters as above, behavior toe down. After restore, all of the presets had the behavior reset to Toe Up (not toggle, and not toe down as they'd been saved)).  Changing them back to toe down, save, and go to another preset, and SOMETIMES it is reset. But not always. I haven't been able to figure out any pattern to it. All I can say for sure it that the bypass behavior setting is not stable.
If I reset the exp bypass as above, and open a preset that doesn't have a wah or block that uses EXP1, there is no change to the behavior parameter. But if I create a preset with just one block of any type, and assign EXP 1 with the above parameters,  the behavior parameter will change in multiple presets as I change it, regardless of saving.
If there is a test someone at Line 6 wants me to do, I'm game.
  • Upvote 4
When was this feature added? I was just looking at the 3.15 release notes and didn't see it?
Never mind, I found it. Testing.
I was wondering what you meant by "engages the Mode Switch".
You're talking about the HXSXL, right, NOT the HXS?
The HXS does not HAVE a Mode switch.
Maybe that's why it's not working?
Just this evening I too started to get this message popping up. It is repeatable by selecting the same preset. A preset I have multiple copies of and works without the issue when they are selected. It happens if I select the present through HX Edit or if I choose it directly on the Helix LT. Note that I have installed and used the new 3.15 the day it came out and only now is this starting to happen. (Kicking myself, I usually wait and let others break new software or have it break them.)
I see one person on here mentioning this issue, anyone else out there? Any suggestions?
Is there somewhere a definition of what is included in a 'Backup File'?
I followed the update to 3.15 procedure to the letter. Including backup/update/reboot/Factory reset/rebuild/power cycle/ restore from backup.
I just had a gig die an utter and horrible death because none of my automation worked, levels were wonky, on and on.
Yeah, my bad for not testing before the heat of battle.
Let's cling to at least one well-defined problem in the above process: Base MIDI Channel is different from before the recommended update process to after the recommended update process. Why?
And... Is there any hope to get back to the state of the unit before the update?
Not really - a backup file is absolutely everything that is in your hardware at the time the  backup is made.
Yes, run 'Restore From Backup' available from under the File drop down Menu. Then you choose which back up file to restore from - it usually has the Date and Time stamp of the last backup you made. When you choose your backup file you can then select which items you would like to restore to your hardware. Example, Global Settings, Impulse Responses, Favourites, User Model Defaults and your Preset setlists.
This is usually an Indication that the Globals have not being restored properly.
First rule of Firmware updates is - never update to a new version prior to a gig, or recording session.
On 2/12/2022 at 6:02 AM, datacommando said:
This may explain why my Mission Pedal on my Rack Floor board doesn't save correctly anymore. And the pedal doesn't recognize a switch between EXP 1 and 2.
When you say it doesn’t save correctly, what do you mean, exactly?
My Mission Engineering pedal’s toe switch is working fine with my Rack still. The toe switch on the Rack has never switched between EXP1 and EXP2, fwiw. That’s never been a feature that’s existed for the Rack.
This is from the release note of 3.10
New MIDI message (Helix LT, HX Stomp, HX Stomp XL): CC 73 toggles between Play and Edit views
This was working before the latest firmware update. Maybe someone can help to test? Hopefully it is not isolated issue to my device
I tried it just to see if it did anything. It didn't. But, since the HXS doesn't have a MODE SWITCH per se (it's called VIEW), perhaps I'm not using the MIDI message properly.
I tried it as a toggling CC (127/0). When it was working for you, how were you using it?
OK. I got a confirmation from Line 6 support that this is a bug.  Well, we knew it was, but just to know we're not crazy.  The new "behavior" behavior is buggy.  I dowgraded to 3.11 and will upgrade when this bug is sorted out.  To me, the new legacy synth sounds + a new amp are not needed.
The downgrade process was very simple.  I just ran the line 6 installer and selected 3.11.
Cheers.
Hello. Hopefully you guys can help me out.
Line 6 HX Stomp XL
Firmware 3.1+ (tried the 3 most recent ones)
HX Edit a- I’ve tried the 2 most recent updates
Windows 10
Currently, I’m experiencing no sound when the unit is FULLY booted up. I hear a dry signal when you first turn the unit on, but once the unit is booted it cuts out.
The weird thing is, I 100% know that this is a software issue. Everything worked before I did a factory reset so I could sell it. Having 2nd thoughts, I was going to give it another go. I installed all the lastest firmwares and started trying to make a patch. I get no sound, none of the stock presets work. It’s pretty much just bricked.
i uninstalled everything and tried again, didn’t work. Reverted back to older firmwares, nothing worked. Updated the older firmwares to the latest ones, no luck.
Am I missing something here?
Cheers.
"Behavior" behavior, lol. Yes, that choice of parameter naming led to a bit of redundancy in my posts detailing my test results. Were you able to submit a repeatable test case to Line 6? So far, I have not found one after admittedly limited testing in comparison to what I think is required to thoroughly QA this feature. From my limited testing I was able to get predictable results. Clearly others are not having the same experience. Would still like to have a better understanding of exactly what the issue is. As I mentioned in an earlier post, perhaps the bug is showing up under certain combinations of settings and presets. Testing this is beyond my scope and probably any single user's. Hopefully it will be resolved for everyone in the next update. Until then I am staying with 3.15, I can live with it.
I showed the video, and describe what was in the video.  They said at first they could not reproduce on Windows 10, but then said they did, and reproduced and forwarded it to their QA team.  Maybe it's an issue with the Mac HX Edit... I don't know and don't care lol.  3.11 works just fine.  Ain't broke, don't fix.  If I literally have no need for the new features, and am perfectly happy with 3.11, I will continue to use it.
Thanks for providing your info. Me and one of my colleagues were able to reproduce it. I've forward the issue to our QA team for further review. Most likely it will be fixed on the upcoming updates if they're able.
Regards,
Pete
1 hour ago, MatthewMcGhee said:
I have Helix Floor on 3.15... expression pedal is lowering volume by itself out of nowhere down to 70-80%s. Anyone experienced this? I just did a complete reset.
EDIT: Can anyone provide instructions on downgrading firmware please?
Download Helix updater.  Run it.  Select 3.11.
Line 6 HX Stomp XL
Windows 10
Bump
1 hour ago, FearTheAbyss said:
Bump
1) In regard to the following - make no assumptions. JUST DO IT!
2) DL and install HX Edit 3.15.
3) Do a factory reset.
If that doesn't fix it:
4) Re-flash your FW using the Line6 Updater, the latest version of which installs with HX Edit.
     FOLLOW THE DIRECTIONS!
5) FOLLOW THE DIRECTIONS!
6) See 1)
7) If, after having done all of that while FOLLOWING THE DIRECTIONS, contact support. There's nothing anyone here can do for you.
My LT has locked up/froze several times now while trying to get to a certain preset.  The only fix is to reboot and try again, but subsequent attempts yield the same result until I found a workaround.  Here are some details:
So far, it only seems to happen when I try accessing a certain preset.  If it matters, the preset I’m going to has a new 3.15 addition, the Tesselator.  In addition, this preset contains Shuffle Looper and some CPU-intensive effects like the Poly Capo.  Safe to say that this preset is on the brink of being “maxed out” in terms of CPU availability…if that could be part of the reason.  That said we ALL have some presets that are maxed, or near-maxed.
Here’s how it all goes down-  I’ll be on a given preset and then I’ll use the bank footswitches to get to the back that holds the preset in question.  When I tap the preset’s corresponding foot switch, nothing happens, and then it freezes up.  Doesn’t matter what footswitch or button I press, the screen is locked showing all of my presets in that particular bank.
Through trial and error, I’ve found that I can access the preset via the Preset wheel/knob, but there’s just something about using the foot switches that it’s not liking.  Sometimes it lets me, but most of the time it doesn’t.  I know it isn’t the footswitch (that corresponds to the preset) itself, because the switch gives me no issues within other banks.
FWIW, this isn’t a case where I had just updated to 3.15, created the new preset, and then all of this started happening.  I updated weeks ago, and created the preset within a few days later, so there’s that.
3.15 update - Using Ext Amp (EXP 2) Instant Commands with My HX Effects, and changing the command from tip, ring or whatever to change amp channels, seems to effect (EXP1) My expression pedal in EXP1 stops working on all presets.
6) See 1)
I’ve already submitted a support ticket. Here’s what I’ve done so far.
Reset to factory settings and wiped PC with all Line 6 software with intent to sell.
Had a friend that was interested, so I tried to install the latest firmware via line 6 updater and the newest HX Edit.
No signal, bricked.
Wiped PC and reset to factory settings. Installed HX Edit first, then installed the firmware via HX Edit. Nada, no go.
I am able to reproduce this and have logged a bug for it. It seems to go all the way back to 3.00.0 if not further.  It does not seem to happen if you use EXP1 for the ext amp control and EXP2 for expression. For now I would recommend using this configuration as a workaround.
Thanks for confirming. Thanks a lot
I have experienced this identical issue and am trying to work through it with a number of presets.  I have never experienced anything like this in any previous firmware versions.
After doing some trouble shooting on my end, the only thing that worked for me was to open HX Edit to the problem patch, then also open the "Command Center".  I then would click on the button I was programing in Command Center, in my case it was button number 3, and I was programming it to select Snapshot #5 to that button in the "HX Snapshot" control menu of the command center.
I would then select each snapshot using the dropdown menu/list at the top of HX Edit and I would see the snapshot assignment for that button change/revert back to "next snapshot" instead of Snapshot #5 that I initially programmed onto that button.  I would then manually change it from "next snapshot" back to "Snapshot 5" that I wanted on that button, then I would save the patch.  I would then select the next snapshot from the dropdown list at the top of HX Edit and continue to do that same process for each snapshot.  Once I did this the changes were saved on all the snapshots and the patch would work correctly.
This is definitely a bug, or if not a bug, a severe unintended consequence to the new ability to stack snapshots on one button.
I have some work ahead of me to change a number of patches to get them to work correctly.
  • 3 weeks later...
Does anyone else has noises when using any Pitch changer preset? Doesnt matter if simple or poly-Pitch. If you down-Pitch even by 1 Semitone, i get a wobbly noise.
Use it for bass. You can hear it at lot in super low tunings but even from a simple D->C is noticable.
I was using the Simple-Pitch for Years now, but since 3.15 it makes those noises.
The lower the more noticable.
Are you putting the pitch change FIRST in the chain?
Help me please.  There was a problem. Version 3.11 was installed. After that, the settings were reset and version 3.15 was installed. The problem has not been resolved. Did a reset again and installed version 2.82. did not help. Now it costs 3.10.
