line6jonb
Members-
37 -
Everything posted by line6jonb
Line 6 Digital Wireless System Comparison Documents
line6jonb posted a article in XD-V Wireless Products
Below are all the 2nd and 3rd generation wireless products in one document: Wireless Comparison Sheet.xlsx -
VIDEO: Setting up a SD card for Line 6 StageScape M20d
line6jonb posted a article in StageScape M20d Mixer
- line 6
- stagescape
- (and 6 more)
M20d band setups.pdf
- m20d
- stagescape
- (and 4 more)
Attached to this document is a list of all 200+ DSP presets that are available in the StageScape M20d. M20d presets.pdf
- stagescape
- m20d
- (and 5 more)
Wireless Audio: Remote Antenna Placement
line6jonb posted a article in General XD-V/Relay Information
Deutsche Version. Version française. Preparing the Room: Remote Antennas This guide outlines the steps involved in preparing the room so that you and your customers get the full performance benefits of Line 6 digital wireless systems. In order to maintain optimal antenna coverage and the best possible line of sight, it is sometimes necessary to mount the antennas remotely from the receiver chassis. Line 6 offers two remote antenna options, P180 directional and P360 omni-directional. Both the P180 and P360 have built-in amplifiers and are switchable for +3dB, +12dB or +23dB of gain, which correspond to approximately 16', 65' and 124' makeup gains for LM-195 cable. Greater cable distances can also be achieved with low loss cable such as LMR-400 (6.8dB per 100 feet) or 9913 (7.7dB per 100 feet). Directional antennas are recommended for precision reception of one or more transmitters on a stage. Omni antennas are recommended for general reception of transmitters in a wider space such as audience mics. ANTENNA ORIENTATION During setup, it is best to P180 directional antennas on boom mic stands angle the paddles down toward the performer and the area that the performer tends to move around in. Try to keep the antennas reasonably close together and overlap their coverage patterns as much as possible for redundancy and also to take advantage of the system’s time and space diversity, but they must be at least 5 inches apart. The following sections outline typical deployment examples. INSTRUMENT TRANSMITTER COVERAGE To cover a single transmitter used by a guitar player, the two remote antennas should be located at the edge of the stage as close to the performer as possible, pointed downward toward the guitar player’s bodypack, and angled slightly outward from each other in order to cover other parts of the stage that the performer may use. Above is a side view of the mounted remote antennas pointed toward the guitar player. Below is a stage view that shows the orientation of the remote antennas to the performer. MICROPHONE TRANSMITTER COVERAGE To cover a single microphone transmitter used by the lead vocalist, the two remote antennas could be located on either side of the drum set, pointed downward toward the singer’s microphone, and angled slightly inward in order to cover the main singer position as well as the other parts of the stage that the performer may use. MULTIPLE PERFORMER COVERAGE Use remote antennas together with the XD-AD8 antenna distribution system to cover multiple performers. The two remote antennas could be located on either side of the stage pointed toward the performers. The above illustrations are simply to offer general recommendations. In all cases it is recommended to walk your intended coverage area and check performance. Small adjustments can yield big improvements. Remember, antenna patterns should be selected with the thought of including or rejecting pickup of a selected area. Antenna Height and Angle Your remote antennas should be placed at least three feet above the floor in order to minimize RF reflections, and ideally the antennas should be raised just over the heads of your audience, but not too high overhead or up near the ceiling. Antennas placed too high up tend to pick up more undesired signals while increasing the distance from the performers you are trying to cover. Proper antenna height will maximize the range of your wireless system. The overall goal is to place the antennas as close to the performers as possible while also being as far away from any interference sources as you can. For example: if there is a WiFi router mounted to a wall or ceiling in the same room as the performance space, point the directional antenna away from the WiFi router and toward the performer. Antenna Distribution System Line 6 also offers the XD-AD8 antenna distribution system. The system allows multiple wireless receivers to share the same pair of antennas, giving greater flexibility in the configuration of multi-wireless installations. With rack-mounted wireless systems, setup is easier and the wiring connections are uncluttered, with the added convenience of powering the receivers from the AD8. L’installation des antennes Que vous organisiez une installation permanente, un événement ou une tournée. Vous devez installer vos antennes correctement pour assurer que systèmes sans fil performent parfaitement. Ce manuel décrit les étapes nécessaires pour recevoir le meilleur résultat des appareils Line 6 possible pour vous et votre client. Antennes à distance Pour avoir une couverture antenne optimale et une meilleure ligne de mire, parfois, c’est nécessaire d’utiliser des antennes à distance. On place des antennes à distance du récepteur. Line 6 offre deux options ici : L’antenne P180 directionnelle et P360 omnidirectionnelle. L’un et l’autre on des amplificateurs intégré qui sont changeable de +3dB, +12dB ou +23dB que correspond à 5m, 20m et 38m de câble LM-195. Si vous avez besoin des plus grandes distances, vous avez besoin du câble faible perte comme LMR-400 (6.8dB par 30m) ou 9913 (7.7dB par 30m). Nous recommandons les antennes directionnelles pour une réception précise d’un seul ou plusieurs émetteurs sur scène. Nous recommandons les antennes omnidirectionnelles pour une réception générale des émetteurs dans un espace plus large. Orientation de l’antenne Pendant la configuration, il est préférable de visser une P180 sur un pied de micro. Oriente l’antenne vers le bas vers l’interprète et la région dans laquelle l’interprète se bouge. Essayez de garder les antennes rapprochés et essayez de chevaucher la couverture des antennes pour assurer la redondance. Les systèmes doivent avoir d'au moins 13cm de distance. Les exemples suivants montrent des déploiements typiques. Couverture d’émetteur Pour un joueur de guitare placez deux antennes à distance au niveau du bord de la scène le plus près de l'artiste possible. Orienté vers le bas et vers le body pack de l’artiste aussi un peut vers l’extérieur pour couvre autres parties de la scène que l'artiste pourrait utiliser. Antennes à distance fixés et orienté vers l’interprète. Et le vue de la scène : Couverture de l’émetteur de microphone : Pour couvre un seul émetteur microphone utilisé par le chanteur, vous pouvez mettre les deux antennes à distance en position par exemple de chaque côté de l’ensemble de batterie. Orienté vers le bas vers le microphone du chanteur et incliné vers l’intérieur pour couvre la position du chanteur mais aussi les autres parties de la scène que l'artiste pourra utiliser. Couverture pour plusieurs artistes : Utilisez des antennes à distance avec le système distribution XD-AD8 pour couvre plusieurs artistes. Les deux antennes peuvent se trouver de chaque côté sur scène orienté vers les artistes. Les illustrations ci-dessus sont des recommandations générales. Dans tous les cas, c’est recommandé de testé tous la région de couverture pour assurer que vous avez un signal partout. Des ajustements mineurs peuvent produire des résultats grands. Sélectez un modèle de couverture des antennes pour les artistes d’être capable de bouger librement. Hauteur et angle de l’antenne : Placez vos antennes à distance au moins 1 mètre au-dessus du sol afin de réduire les réflexions RF. Les antennes doivent être soulevées un peu au-dessus des têtes de l’auditoire mais pas trop élevé près du plafond. Antennes placés trop élevés sont trop loin de l’artiste et ramassent des signaux non désirés. Une hauteur propre maximise la gamme de votre système sans fil. Essayez de placer les antennes aussi proche à l’artiste que possible mais aussi loin que possible des interférences. Par exemple, s'il existe un routeur WiFi monté sur un mur ou au plafond dans la même chambre que l'espace de représentation. Orientez l’antenne directionnelle à partir du routeur WiFi et vers l’artiste. Système de distribution d’antenne: Line 6 offre le système de distribution d’antenne XD-AD8. Le système permet à plusieurs récepteurs sans fil pour partager la même paire d'antennes que vous offre une grande flexibilité pour configurer des installations sans fils multiples. Avec un système sans fil monté en rack, l’installation est facile et les connections de câblages sont épurés. En outre, vous pouvez faire fonctionner les récepteurs à partir de l’AD8. Vorbereitung des Raums: Remote-Antennen Diese Anleitung wird Ihnen Schritt für Schritt zeigen wie Sie den Raum so vorbereiten können, dass Sie eine best-mögliche Leistung aus Ihren digitalen und kabellosen Line 6 Geräten bekommen können. Um den Raum optmal abzudecken und eine Sichtlinie zwischen Antenne und Transmitter zu haben müssen oftmals Antennen an anderen Position aufgestellt werden als die des Empfängers. Line 6 bietet hier zwei verschiedene Antennen, die P180 gerichtete Antenne und die P360 Rundstrahlantenne. Sowohl die P180 als auch die P360 haben eingebaute Signalverstärker welche auf +3dB, +12dB und +23dB eingestellt werden können. Diese entsprechen einer zusätzlichen Kabellänge von 5m, 20m und 38m LM-195 Kabel. Für größere Kabeldistanzen brauchen Sie Spezialkabel mit geringem Verlust wie das LMR-400 (6.8dB auf 30m) oder das 9913 (7.7dB auf 30m). Ausgerichtete Antennen empfehlen wir für einen präzisen Empfang für einen oder mehr Transmitter. Rundstrahlantennen empfehlen wir für allegemeinen Empfang auf größerem Raum wie z.B. Publikumsmikrofone. Die Antennenausrichtung: Während der Aufstellung ist es oft am Besten die P180 ausgerichteten Antennen auf Mikrofonstative mit Galgen aufzusetzen und die Antennen dann nach unten in Richtung Künstler zu winkeln. Versuchen Sie außerdem die Antennen relativ nah nebeneinander stehen zu haben damit die Abdeckungen sch überschneiden. Die Antennen sollten jedoch mindestens 13cm voneinander entfernt sein. Die folgenden Kapitel schildern typische Einsatzbeispiele: Instrument Transmitter Abdeckung: Um einen eizelnen Transmitter, der von einem Gitarrenspieler verwendet wird abzudecken sollten beide Remote-Antennen an der Kante der Bühne aufgestellt werden, so nah wie möglich am Gitarrenspieler. Die Antennen sollten in Richtung des Bodypacks gerichtet und leicht nach außen gedreht sein damit die Antennen auch Teile der Bühne abdecken, in den der Spieler bewegen könnte. Oberhalb befindet sich eine Seitenansicht der Remote-Antennen und unterhalb eine Bühne auf der man die Orientierung der Remote-Antennen erkennen kann. Mikrofon Transmitter Abdeckung: Um einen einzelnen Mikrofon-Transmitter eines Sängers abzudecken können sich die beiden Antennen auf einer Seite des Schlagzeuges befinden. Die Antennen müssen dann nach unten in Richtung des Mikrofons und leicht nach innen gerichtet werden um so den Bereich abzudecken in dem sich der Sänger bewegt. Antennenabdeckung für mehrere Künstler: Nutzen Sie dazu die Remote-Antennen sowie das XD-AD8 System. Beiden Antennen könnten sich in diesem Falle jeweils links und rechts an der Kante der Bühne befinden und in Richtung Künstler gedreht sein. Die obrigen Illustrationen sind Vorschläge. In allen Fällen ist es wichtig die Bühne abzulaufen und zu überprüfen ob die Künstler überall Empfang haben. Kleine Änderungen können hier großes bewirken. Die Abdeckung der Antennen können Sie hier anhand der Ausrichtung selbst bestimmen. Antennenhöhe und –Winkel Ihre Remote-Antennen sollten Sie mindestens einen Meter über dem Boden positionieren um RF Reflektionen zu minmieren und idealerweise sollten die Antennen über den Köpfen des Publikums plaziert werden jedoch nicht zu hoch oder nah an der Decke. Antennen, die zu hoch plaziert sind nehmen oftmals mehr unerwünschte Signale auf. Die korrekto Höhe der Antenne wird die Reichweite Ihres kabellosen Systems maximieren. Das Hauptziel ist es die Antennen so nah wie möglich beim Künstler und gleichzeitig weit weg von Interferenzen aufzustellen. So kann zum Beispiel ein WLAN Router, der an der Decke des Raumes installiert ist das Signal stören. Richten Sie in diesem Fall die Antenne auf den Künstler und nicht in die Richtung des Routers. Antennenverteilersystem Line 6 bietet außerdem das XD-AD8 Antennenverteilersystem an. Das System es mehreren Empfängern das selbe Paar Antennen zu benutzen, welches Ihnen mehr Flexibilität für Ihre Aufstellungen mit mehreren Empfängern bietet. Mit Rack-Wireless Systemen ist die Einrichtung einfach und nicht überladen. Zusätzlich können Sie die Empfänger vom AD8 aus betreiben. -
Solutions For Mounting And Lights
line6jonb replied to SiWatts69's topic in StageScape Mixer / StageSource Speakers
Very cool and well done guys. You both look like you're definitely bringing the party. Keep it up and thanks for the pictures. Just FYI, if you plan on 'flying' or hanging the StageSource speakers, we always recommend using the Eyebolt Suspension Kit that you can find here: https://www.globalfulfillment.net/gfsnet/line6/10Expand.aspx?ProductCode=98-037-0005 And ALWAYS be sure to contact a rigging professional. Thanks again for the pics!- 15 replies
- l3s
- pole mount
(and 2 more)
Tagged with:
People Always Ask Me...
line6jonb replied to BucF16's topic in StageScape Mixer / StageSource Speakers
We hear of you here :) You may want to try our contact page as well. http://line6.com/company/contact/ -
Using A Stage Source L3t As A Bass Rig
line6jonb replied to dazbec's topic in StageScape Mixer / StageSource Speakers
With the L3t or L2t you can plug your bass directly in to either of the mixer inputs on the side. These inputs offer gain and EQ controls. That will be the best inputs for your instruments. Since these are full range speakers, you can plug guitar, bass, or vocals directly in to those inputs. -
VIDEO: Creating Custom DSP Presets on StageScape M20d
Get the New V75-40V Microphone with Earthworks Capsule for Your XD-V75 Digital Wireless System What is it? The V75-40V combines industry-leading Line 6® digital wireless technology with the renowned Earthworks® WL40V premium hyper-cardioid capsule, delivering stunning performance and unmatched sound quality. Premium Sound Quality The Line 6 XD-V system is the only wireless platform that can transmit the stunning sound of the celebrated Earthworks WL40V capsule. The result is the world's most inspiring vocal wireless microphone, providing exceptional clarity, precise response and unmatched sound quality. Earthworks WL40V Capsule Designed to deliver studio-quality performance to the wireless world, the premium hand-tuned and tested capsule from Earthworks deliver features lightning-fast impulse response, high SPL handling and a wide frequency range. The textbook-perfect hyper-cardioid polar pattern provides exceptional clarity and detail. Your vocals have never sounded this amazing. Does the V75-40V have microphone modeling like other Line 6 microphones? No, the V75-40V does not have any microphone modeling on it. When using a Line 6 handheld microphone with the Earthworks WL40V capsule attached, the mic modeling will display "OFF" on the modeling page of the microphone's user interface. Can I use a V75-40V Earthworks capsule on other Line 6 handheld microphones? Yes, the Earthworks WL40V capsule is interchangeable to use on other Line 6 handheld microphones, provided the handheld microphone being used has been updated to firmware version 2.10. Firmware version 2.10 is required for Line 6 handheld microphones to utilize the Earthworks WL40V capsule. Is the V75-40V part of a Line 6 wireless system? The V75-40V with Earthworks WL40V capsule is sold as a separate component from other Line 6 wireless systems. The V75-40V does NOT come with a receiver or power supply to power the receiver. Any customer without a Line 6 wireless system will need these components when purchasing a V75-40V. 24-bit Performance Featuring 24-bit precision, 10Hz–20kHz full frequency response, and wide dynamic range, our digital wireless system transmits the stunning sound of the WL40V with total transparency and accuracy. Clear Visual Status The clear LCD screen provides essential system info at a glance. Select channels and check your battery level—instantly. Tour-Tough Construction With a durable metal body and custom hard-shell touring case, V75-40V is ready for the rigors of the road. How do I get it? Visit your local Line 6 retailer today to check out V75-40V. V75-40V combines industry-leading Line 6® digital wireless technology with the renowned Earthworks® WL40V premium hyper-cardioid capsule—delivering performance previously found only in the highest quality wired studio mics. Features include: Premium Earthworks WL40V capsule Textbook-perfect hyper-cardioid polar pattern for exceptional clarity and detail Crystal-clear, compander-free, 24-bit precision The widest dynamic range of any digital wireless transmitter—118dB Rugged, tour-tough metal body Includes custom hard-shell touring case with soft inner padding Up to 14 channels for maximum flexibility 10Hz–20kHz frequency response Backlit LCD display for fast and easy operation 8 hours battery life with 2 AA batteries Lockout switch to prevent changes during performance Transmitter Naming for identifying transmitters in a multi-system application Compatible with XD-V75, XD-V55, and XD-V35 receivers running v2.0 firmware or later Part number: 98-033-0057
StageScape M20d Firmware 1.20 Update Information
Version française. Deutsche Version. The 1.20 firmware update for the StageScape M20d features a new fader view for enhanced control on touch screens and Artist Presets. ****Please be aware that if you are updating from firmware 1.00 directly to 1.20, the update file will state that you are installing version 1.32. This is a typo that will be fixed in the future and it will have no affect on your firmware 1.20 installation or functionality.**** IMPORTANT NOTICE: This version of the StageScape firmware works only with StageScape remote app v1.10. Please update your StageScape remote app on your iPad when updating your StageScape firmware. When updating firmware, have ONLY the SD card or USB drive that is being used to install the update plugged into the StageScape. This update is available from this web address http://line6.com/software/index.html. Be sure to select StageScape M20d under All Products, click the red Go button, and you will be able to download the Firmware 1.20 update. You will have to download this file and save it to a SD card or USB thumb drive. Insert that device into your StageScape M20d, go to the i menu, Show System Settings, Update M20d, Update System Firmware. The update file will have to be in the top hierarchy of your media device. Firmware install files will not be recognized if they are placed in a folder. Be sure to unplug any other media device (USB, SD card or PC) from your StageScape that is not being used for the firmware update. New Features Bug fixes: Output preset recall resetting output level Minor bug fixes Fader View: With the new 1.20 firmware, the perform mode now has a fader view option on the touch screen of the StageScape M20d. This allows you to view and manipulate levels for your inputs, monitors, global FX, and main mix as virtual faders on the touch screen. You can also control your trim, pan, and global FX send levels with the rotary encoders under each virtual channel strip. Artist Presets: Brad Madix and Daniele Di Giovanni Brad Madix: Rock Kick - Aggressive rock bass drum. Sits in the mids when you really lay into it, somewhat more natural when played quietly. Rock Snare - A "fat" rock snare with a bottom that is shaped using the dynamic eq. Pushes up the low end for that "arena rock" sound. Drum Buss Crush - Crush a drum sub mix. Really pumping compression. Scary on its own, but blend it back in with the uncompressed drums and the whole kit will come forward. A little goes a long way. Rock Bass - Big mid boost to get the bass to pop out in the mix Rock Guitar - Bright and cutting. Best for leads. Vocal - Bright and clear without sibilance using the de esser Brighten up that male vocal without it getting too "essy". Daniele Di Giovanni: Grand Piano (PianoMic)- Earthworks PianoMic at its best Attention, cette version du firmware StageScape a une nouvelle vue fader pour un contrôle augmenté sur les écrans tactiles et les presets Artistes. ***Si vous installez firmware 1.20 sur 1.00, la mise à jour indique que vous installez version 1.32. C’est une faute de frappe. Ignorez ca. Il n'aura aucun effet sur ​​votre firmware 1.20 ou l’installation.*** Attention, cette version firmware fonctionne uniquement avec l’application StageScape Remote 1.10. Donc vous devez mettre à jour l’application StageScape pour l’utiliser avec la nouvelle version du firmware. Débranchez tous les appareils USB de votre StageScape sauf l’appareil avec le nouveau firmware. Vous pouvez trouver la mise à jour ici : http://fr.line6.com/software/index.html. Sélectez le StageScape M20d sous « All Products » et cliquez « Go ». Téléchargez le Firmware 1.20 et sauvez le fichier sur une carte SD ou clé USB. Insérez la carte ou la clé dans votre M20d et cliquez sur le menu « i », « Show System Settings », « Update M20d » et « Update System Firmware ». Placez le fichier directement sur la carte SD ou clé USB et pas dans un dossier sur la clé/la carte. L’appareil ne trouvera pas le fichier si vous le placez dans un dossier. Débranchez tous les autres dispositifs du StageScape M20d que vous n’utilisez pas pour la mise à jour. Corrections des bugs mineurs. Fader View Avec la mise à jour du firmware 1.20 le mode perform a une option Fader View sur l’écran tactile qui vous permet de voir et manipuler les niveaux des entrées, moniteurs, Global FX et du mix principal comme curseurs sur l’écran tactile. Vous pouvez aussi contrôler Trim, Pan et Global FX niveaux d’envoi avec les encodeurs rotatifs dessous les canaux. Presets Artistes: Brad Madix et Daniele Di Giovanni Brad Madix: Rock Kick: Grosse caisse rock agressive. Très naturel si vous le jouez doucement. Rock Snare: Basses formés avec l’EQ dynamique. Augmente les basses pour un son « arena rock ». Drum Buss Crush: Compression massive. Jouez-le avec une batterie non compressée. Rock Bass: Un boost pour les mis. Rock Guitar: Très bien pour le joueur principal. Vocal: Pour on son très clair. Daniele Di Giovanni: Grand Piano (PianoMic) – Le PianoMic de Earthworks à son meilleur. Das Firmwareupdate 1.20 für StageScape M20d erweitert Ihr M20d um zusätzliche Schiebregler für mehr Kontrolle und neue Artisten Presets. ***Achtung, wenn Sie von Firmware 1.00 auf 1.20 aktualisieren wir das Update Ihnen anzeigen, dass Sie Version 1.32 installieren. Dies ist ein Schriftfehler, der in Zukunft behoben wird. Ignorieren Sie diesen Fehler, denn er beeinträchtigt die Funktionalität des Updates nicht.*** Achtung, diese Firmware Version funktioniert nur mit der StageScape Remote App 1.10. Wenn Sie die Firmware aktualisieren, entfernen Sie bitte zuerst alle anderen SD Karten und USB Sticks abgesehen vom USB Stick oder SD Karte, auf welcher die neue StageScape Firmware abgespeichert ist. Dieses Update können Sie auf der Internetseite http://de.line6.com/software/index.html finden. Wählen Sie das M20s unter All Products aus, klicken Sie dann auf Go und dann sollten Sie das Update auch schon sehen. Laden Sie sich hier dann Version 1.20 herunter. Speichern Sie es dann auf einem USB Stick oder einer SD Karte ab. Stecken Sie diese dann in den M20d. Auf dem M20d gehen Sie dann auf das i Menu, Show System Settings, Update M20d und Update System Firmware. Die Datei muss sich direkt auf der SD Karte/USB Stick befinden un dort nicht innerhalb eines Ordners. Fehlerbehebungen: Kleinere Fehlerbehebungen. Neue Schiebregler: Mit der neuen Firmware Version 1.20 ist der Perform Modus um ein Set Schiebregler erweitert worden. Mit diesen können Sie Input, Monitor Global FX und Main FX Pegel auf dem Touchpad einstellen. Außerdem können Sie Trim Pan und Global FX Pegel via der normalen Drehknöpfe verändern. Artisten Presets: Brad Madix: Rock Kick: Agressives Rock Schlagzeug. Klingt sehr natürlich wenn man es ruhig spielt. Rock Snare: Die niedrigen Frequenzen sind per dynamischem EQ geformt. Drückt den Bass außerdem nach oben für den typischen Arena Rock Sound. Drum Bass Crush: Extreme Kompression. Mischen Sie diese dann mit unkomprimiertem Schlagzeug um einen einzigartigen Sound zu bekommen. Rock Bass: Boost für die Mitten. Rock Guitar: Perfekt für den Lead. Vocal: Für klaren Sound. Daniele Di Giovanni: Grand Piano (PianoMic): Earthworks PianoMic.-
- stagescape
- m20d
- (and 6 more)
USB 3.0 Interference with 2.4GHz Radios
USB 3.0 computer cables and peripherals, including hard drives, are known to emit radio frequency interference throughout the 2.4GHz band, which results in reduced range and/or performance for any 2.4GHz device in its proximity (including wireless keyboard or mouse, WiFi, etc.). We recommend placing any digital wireless receivers at least two meters away from the USB 3.0 device and its cabling. Below is a link to an study by Intel regarding this interference. http://www.intel.com/content/www/us/en/io/universal-serial-bus/usb3-frequency-interference-paper.html Interferenzen zwischen USB 3.0 und 2.4GHz-Geräten USB 3.0 Computerkabel und –geräte sind dafür bekannt Interferenzen bei Radio Frequenzen im 2,4GHz Bereich zu erzeugen was zu verringerter Reichweite und Performance für alle 2.4GHz Geräte (inklusive kabellose Tastatur oder Maus sowie WiFi und viele andere) in der Nähe führen kann. Wir empfehlen alle digitalen Kabellosempfänger mindestens 2m von den USB 3.0 Geräten und deren Verkablung weit weg zu plazieren. Nachstehend können Sie einen Link zur Untersuchung von Intel über Interferenzen mit USB 3.0 finden: http://www.intel.com/content/www/us/en/io/universal-serial-bus/usb3-frequency-interference-paper.html Interférences entre USB 3.0 et appareils 2.4GHz Les câbles et périphériques USB 3.0 sont connus pour émettre des interférences de fréquence radio dans la bande 2,4 GHz, que cause une gamme et/ou performance des appareils 2.4 GHz réduite dans la proximité. (Y inclus sont les claviers ou souris sans fil, WiFi, etc.) Nous recommandons de placer le récepteur sans fil numérique au moins 2 mètres loin des appareils USB 3.0 et ses câbles. Voici un lien vers une étude réalisée par Intel au sujet de cette interférence: http://www.intel.com/content/www/us/en/io/universal-serial-bus/usb3-frequency-interference-paper.html -
I'm sorry this happened at your gig. I have not seen this type of failure previously with the mixer. I'm aware that you are referring to XLR input, so does that mean if you plug in a guitar 1/4" into inputs 1-12 it will work? This happens only with XLR? Please contact our service department and register your unit for expedited service. We would like to take care of this for you as soon as possible. Thank you for your patience and understanding. Regarding the light showing from around the outside of the MUTE ALL and MUTE MIC buttons, that is correct. The light will show out around the edges of the buttons when they are engaged - similar to a halo.
L3t Fbs While Using L6 Link
line6jonb replied to hamkom's topic in StageScape Mixer / StageSource Speakers
Also, keep in mind that the best usage of the FBS system on your L3/L2 speakers will be the GREEN setting for the vast majority of uses. Only if you are using the green mode and find that does not sufficiently reduce feedback should you move up to the orange/amber setting... or possibly to the red setting. Using a FBS setting that is too aggressive may cause undesired audio artifacts. -
The HD500 master volume may not work when L6 linked to a L3/L2 speaker, however the channel volume on your HD500 will affect your volume. The reason the master volume is disabled on the HD500 in this example is because the master volume on your L3/L2 truly is your master volume. Adding a 2nd master volume could add the possibility of overly gaining your signal and inadvertently blasting yourself with a signal that is way louder than you had anticipated. Regarding the ability to change speaker modes, you are correct that they would have to be saved as part of your tone preset beforehand. A possibility for working around this could be that you save multiple instances of the same preset but with different speaker modes. For example, 1A is electric guitar, 1B is acoustic guitar, 1C is for monitor mode (to take away some low end), and 1D is reference PA - all of those settings are on your speaker, but the tone is the same for each. Frankly, I'm not entirely sure why you would want to do this, and I believe that you may find that the electric guitar setting that the speaker defaults to will generally be the best setting for your electric guitar. Of course different effects and settings may create a nice little change in tone, but feel free to try it out. Different settings do have different EQ's.
Yes, all vocal presets will have FBS on them, however some instruments will not. Individual drums, for example, do not have FBS on them. Instruments that say direct also will not have FBS, however any instrument that is mic'd or says mic'd will have FBS. Instruments that have amps or cabinets will have FBS on them as well. Instruments that have a 1/4" input in the top right of their icon in the galley - which runs across the bottom or the stage in setup mode will not have FBS, because that 1/4" input is meant as a direct input. Any instruments that have a direct input and are not mic'd will not have FBS - but, again, drums won't have FBS either. FBS can be found in the Tweak mode, in deep tweak, in the input section. I hope this is helpful.
We have heard a number of requests for IEM systems from the previous forums. Please create a product feedback ticket in the product feedback section of the Line 6 website at the following web address: http://line6.com/company/contact/productfeedback/. At this time, I'm not aware of any IEM systems in development, but we are aware of your request. Creating a product feedback ticket will only increase the visibility of your request.
